Question about Canon PIXMA MP210 Photo All-In-One Printer
Cartridges band fell off
Band that pulls the cartridges fell off when i changed them does anyone know where they go and how it fix it?
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
The folks at canon field and tech support do. this is not a user friendly fix
Posted on Aug 19, 2008
When I put the paper in, and push the refill button, the paper goes down in the printer crookid, I need help does anyone know what I could possibly do?
Leading cause of paper jams or misfeeds is debris / foreign objects that accidentally fell into the paper feed area. Please try this approach to fix the problem:
  1. Remove the sheets of paper from the feeder.
  2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
  3. If you're willing and physically able, you may also carefully turn the printer over. Any debris should just freely roll out from the feeder.
  4. If feeder is clear, place the printer on the table. Open the printer cover and remove the cartridges.
  5. Check the cartridge area for any obstructions in the paper path.
  6. Close the printer cover.
  7. Re-brick your printer by pulling out the power supply - the black box where the power cord is plugged into. Re-plug after 30 seconds.
  8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again to verify that the problem is fixed.
Oct 07, 2011 | Lexmark X2500 All-In-One Printer
Cartige is not installed properly
Hello.
Be certain that the # cartridge is the correct one for your printer. Examine the cartridge to see if the protective tape has been removed. And, remove and reinsert the cartridge so that it snaps in place.
Hope this helps.
Jun 24, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Jura F9-inside part fell off while pulling the tray. Cannot fix.
Kris I have this same problem. Did you figure out how to replace the flap or did you have to take it in for repair.
Does anyone else know how to replace this plastic flap?
Feb 24, 2010 | Jura Capresso Impressa F9 Espresso Machine
When I receive a fax it has a large, dark black line down the middle of the page....does anyone know what this is and how to fix it?
Most likely you have a bad drum unit. Remove the cartridge and turn it upside down, swing back the shutter; you should see the large band on the drum.
Aug 18, 2009 | Office Equipment & Supplies
The carriage stuck and I found this band with hole in both ends hanging loose. I need to know how to reconnect this band so printer will work. I cant see where this connects
You can reattach this band yourself. There are two springy hooks on each side of the printer. They are slanted so that you can position the band with the right side forward.
The band engages in a slot in the cartridge carriage, you have to slide it through. I don’t know whether you can fix the band on the right without taking off the cover of the printer. If you must, then follow the procedure:
1. Open the top cover and unscrew the two screws you find there.
2. Open the back of the printer, locate the two release latches left and right press them and lift the back a couple of millimeters (1/8”)
3. Through the top opening locate the two front latches (plastic tongues) release them by putting a screwdriver blade in the catch and pressing forward.
4. Pull the cover gently there are cables attached to it…
Jul 27, 2009 | HP DeskJet 970cse InkJet Printer
Hp 4600 noise problem
when power on the main board do initial devices:
1) the cartridge include toner unit and photo drum unit
2) fuser unit and all paper road include motors and sensors through the paper road.
the noise at power on you may check:
1) the toner unit that maybe over life cycle to mak much more obstruction, you may take out the cartridge and turn the gears if felling very hard so need to change the cartridge.
2) the toner unit gears damage a little that could make noise, you may check all gears on the cartridge. attention other side drive gears.
3) check the fuser unit gears do same thing above.
hope you fix it and feedback the result thanks
May 06, 2009 | HP LaserJet 4600dn Color Printer
Vertical middle badly printed band
Hello sir; Make sure the glass is clean before you change another new cartridge.
Mar 31, 2009 | Sharp Office Equipment & Supplies
Mechanism, belt came off.
Turn your machine upside down and give it a shake. Most likely, a small spring will fell out. The same thing happened to us and sure enough, it was the spring. This spring will give the tension you need to hold the belt on the plastic piece.
Sep 23, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Loud clicking noise
Power the machine on with drum and toner removed, check for noise....
It will be either the Fuser, Toner or the drum.
If it is non gen. or refill toner, fault found.
The drum is a normal consumable that you change every 3 to 4 toner cartridges, so if any of you have used more than 4 toners and havent changed the drum, I'd say that we have found your problem.
......now to the hangers on .....
Fuser, thats the hot bit at the back, these have a gear that cracks because the whole fuser assemble is old, brittle and stiff, you can pull it all apart and change the gear and be off, but soon it will more than likely break again, I know cause if I do that as the fix they come back within 6mnts.
Replace fuser, or have it replaced
f9d929d.jpg LINK to P/n and price
the gear that breaks/cracks
9b32a46.jpg LINK to gear info
Fuser is a HiVolt, HiTemp part. Caution!!!!
Nov 16, 2007 | Brother HL 1440 Laser Printer
Canon PIXMA MP210 Photo All-In-One Printer Logo
123 people viewed this question
old marine
old marine
