Question about Mitsubishi VS-50605 50" Rear Projection Television
Repair help My Mitsubishi VS-50605 projector TV shows a totally black screen but the audio is still working. The menu screen does not show when I try to access it through the remote (which tells me it is not a PIP problem). Could this possibly be a "do-it-yourself" fix issue? I would rather give it a try than to get rid of it. Unfortunately, I don't know the first place to troubleshoot. Please help....
  • maryabauer Mar 05, 2009
    have almost the same problem. no video but do have sound. if I use the menu option on the tv, it shows the current channel in the upper right hand corner fine (picture, i.e.) but when I click off menu , I have a black screen again. also, when I click on Input, only get input a and b whereas I use to get option of DVD, SAT, etc.
  • 927 Answers
Good Day, limao247;
Your TV may fluid on the PCB's. Remove the speaker grill, the small panel and look closely for fluid on the boards towards the front. Always unplug the TV for your SAFETY. If you find fluid clean board with acetone. Good Luck, big IRISH.
Posted on Aug 30, 2008
The colors aren't matching up I have green semi
Yoy have convergence issue with tv,try the magic focus/touch focus or manual adjustment in the menu under convergence, if can't be adjusted then your convergence ckt is the problem,you will need a tv tech to repair it.
Mar 19, 2010 | Mitsubishi VS-50605 50" Rear Projection...
Screen is black
sounds like it was enough to pop something in the tv, smell the back of the tv smell if anything smells burnt or hot. unplug the tv and let stand for about a hour unplugged then trying it again but if it does smell chances are you will have to see if your still under warrenty and have the unit replaced.
Aug 09, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-50605 - no vertical control until it warms up and it is now starting to flash to a black screen
Dec 29, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi big screen tv
Do the self test first find the error code. Look on here or
Jan 02, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-50605 - Colors separated
You have a convergence problem and need to reset
Nov 26, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Cleaning the Inside
pull front speaker grill it snaps on take 5 or 6 screws out just under screen lift screen by sides straight up entire screen will come off exposing mirror
Nov 19, 2007 | Mitsubishi VS-50605 50" Rear Projection...
VS-50605 Screen
might measure the opening and buy a piece of plexiglass, wont look quite as good, but cheaper than a new one and usually available at glass shop.
Jul 06, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Timer light flashes 3 times
the code means that your tv power supply is not functioning your tv needs to be repaired call the tech.good luck
Apr 26, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-50605 50" Rear Projection Television Logo
158 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
