Question about Olympus Cameras
How do I install card? - Olympus Cameras
  • 203 Answers
Most new models card installs next to battery
Posted on Aug 18, 2008
How do i install video cards in my emachines ET1352G-03W?
Your machine will accept a PCI-e x16 Graphics card. If you are going to go to high high-end, high-power card, ensure that you have the proper power connectors for the card. Mainstream video cards are powered from the PCI-e slot itself. Also, be advised that your machine only has a 220W power supply, so high-end cards may draw too much power from an already anemic source.
To install the new card, simply power off the PC and unplug it. Open the case and locate the PCI-e slot (closest to Power Supply). Take out the proper blank at the rear of the machine to allow the card to be installed. Install the card and secure it with a screw (or whatever means the case provides). Hook up the card's power connector (if equipped). Secure the case. Move your monitor's cable from the onboard video connector to the one on the new card. Power up the PC and watch the bootup. The Operating System should detect the new graphics card and will install, at a minimum, a generic driver for it. To install the drivers supplied with the card, install the CD/DVD and run the install setup program.
Dec 09, 2013 | Computers & Internet
I have a dell dimension 4400 and the original graphics card thats came with it but yesterday i when too turn on my computer and the screen is not picking up and image from the CPU is there anything i can...
OK, I am curious how are you going to install a new graphics card without installing a new graphics card? "picking up and image from the CPU is there anything i can do to install a new PCI graphics card with out having too install the new graphics card"
You can install a different graphics card in the computer assuming you have an open expansion slot. If the Current Graphics card is actually installed in the AGP slot open the Main CPU unit and remove it then install the new card. If when you started the computer you saw anything on the screen, the DELL logo or Bios setup, the problem most likely is not the graphics card being bad but possibly that the settings in windows some how changed and it is set to something it can't support or the monitor has gone out. If it is the graphics card and it is built onto the motherboard you will have to install the new card and when the computer starts enter the Bios to change the BIOS settings to disable the on board card or it will give you problems with conflicting resources. Most graphics cards use the same resources so two cards in the same computer will conflict with each other and neither will work. I would test with a different monitor before replacing the graphics card.
Dec 13, 2010 | Dell GeForce2 MX, (32 MB) Graphic Card
How to instal sound card
i cant understand what you exactly want ??? sound card installation or sound card driver installation ??? if u want to install sound card driver then just put a CD given with sound card into drive n simply install it and if you want to install sound card into your laptop then you have to go to manufacturer's service center ok??? ahope this will solve your problem...
Jul 07, 2010 | Dell Inspiron 6000 Notebook
ASUS ENGT240 Graphic card installation failure
try installing the driver first then disable the motherboard display adapter then then shut dowm computer put card in . change montior cord to card  boot up   ( make sure that resoluting in card driver software is right for you before you do alll the above .some time the card defalt at install is to high for montior to handel by card maker wants to show off) it should work .sonetimes windows plug and pray can be flaky hope this helps should work unless you card chipset is not complable with motherboard
Apr 03, 2010 | ASUS NVIDIA Graphic Card
How to install graphic card my computer\nr
Try to plug the graphic card in daughter card slot of mother board Then start your system, if you are using windows xp, Vista and windows 7 Then may be possible that it will automatically install the driver other wise you can insert the graphick card installation disk in cd/dvd drive and install the driver then reboot the system and it will work fine.
Mar 19, 2010 | Intel XFX GeForce2 MX400 (64 MB) Graphic...
Replacing ethernet PCI card 10/100 by gibabit 1000
When you replace and install LAN card you need to install also the driver. Be sure that your onboard ethernet PCI card are disabled in BIOS. So that the new install LAN card are working.
Sep 26, 2009 | Dell Ethernet Card Network Adapter
Where can i download a sound card driver for ATI
Go to the website fo rthe name of the card. Download the driver for your operating system. Install the driver for the card according to instructions. Most can be installed after the card is installed. Some may require installing the drivers before installing the card.
Sep 26, 2009 | ATI Computers & Internet
I want install my sound card by net c97 now
Hy i'm Kabeer Khan for installing sound card it is first required AMR(Audio Modem Riser) slot on your motherboard. AMR slot is 64 pin very smal slot is like as PCI(Peripheral Compnent Interconnect) If it avialable then open your sound card and try to set your sound card. Remember one thing during installing card it must be considered that the cuts of slots should be matched according to your card alignment. After installing card bind you CPU and install driver that would be given with your sound card packet for this open conrol panel and found add hardware icon and double click on it then install driver from CD option would be selected and click next. When wizard is finished you will be able to use your sound card.
Kabeer Khan
Apr 20, 2009 | M-Audio Audiophile Sound Card
I am not able to install driver for D-link wifi card
The card could be bad. I've found over the years that most of these desktop wireless cards work best when the software is installed before the card is installed. Meaning uninstall all the software. Turn off the machine. Remove the wireless card. Turn back on the machine. Install the software. Once installed, shut down the machine. Install the card. Turn back on the machine and lets Windows find the card and the software.
Mar 22, 2009 | D-Link AirPlus Xtreme G DWL G520 802.11g/b...
TV Tuner Card is not working on DG31PR Motherboard
You should always install mainboard drivers first.
Remove tuner card, install all other drivers, then add in Tuner card.
Aug 05, 2008 | Intel DG31PR Motherboard
Cameras Logo
13 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
