Question about Pentax Optio S5i Digital Camera
Camera begins start up sequence, but doesn't complete
Got my camera wet on a raft trip. Dried it out, but now it will not complete start up sequence. Camera beeps and shutter opens part way, but gets stuck there. Have I ruined it?
    Master:
  • 623 Answers
Yes!
Posted on Aug 17, 2008
  • ritchie dempacco
    ritchie dempacco Aug 17, 2008
    take it to a shop to see what they can do!!!
My camera sony dsc-t77 was merged in swimming pool so it doesn't work completly
Maybe the battery of your camera is wet. Try to quickly dry your camera's battery in sunlight and then put the whole camera ( excluding battery ) in sunlight. This may work as the moisture in your camera would dry out and chances are there that it may start working.
Sep 24, 2012 | Sony Cyber-shot DSC-T77 Digital Camera
Camera dropped in water
If you had immediately fished it out, removed the batteries, and let it dry thoroughly before even attempting to turn it on again, then the camera MAY work again. If you had left the batteries in or tried to turn it on again while wet, your chances are much less.
If your camera doesn't turn on after it's dried out, then you have to either replace or repair it. Given repair costs and the expected life cycle of digital cameras, it's probably more economical to replace it with a newer model. Of course, since you neglected to specify the model of your Canon camera, I can't make that decision for you.
May 09, 2012 | Canon Cameras
My D3100 got dunked, it works but images seem cloudy
Bob, Your camera may stop working very soon as corrosion begins. You should place all parts that got wet in a pillow case and put in a large container of dry, uncooked rice for a day or two (or longer). The rice will will draw out the moisture from all the affected parts.
Next, you'll need to do a "wet cleaning" of the sensor. This is not for the faint of heart - but can be done at a camera shop for under $100 if you'd rather have them do it. I'd wait a couple of weeks before doing that - as the camera may fail as a result of the corrosion I mentioned earlier. It doesn't make sense to drop $100 into a broken camera - right?
The lens will need a thorough cleaning - but may be better / cheaper to buy a replacement. This is not an "end user" job - it will need to be sent out - but consulting a local camera shop first would be best.
Nov 18, 2011 | Nikon D3100 Digital Camera
I had my nikon s4000 in a zip lock bag INSIDE a ziplock bag and went rafting....I fell in the water and some water got into the bag with the camera. First solution is-never take a camera on a rafting trip...
Hello
Yes, i second you on the first solution...
But, now that it is done already, we need to try something else to resolve theproblem.
OK, firstly you will need to understand that water damage is a very bad thing. That is why the brand companies don't give warranty on this particular problem.
OK, firstly, you need to take out the battery and the memory card.
Place the camera in a sealed container filled with 2 cups of rice. Keep in the container for about 48 hours.
If this does not work, it is most probably a circuit error, die to water damage.
Please let me know if this works. Also, do not hesitate to let me know if you have any questions.
Kind regards
Andrea
Sep 19, 2010 | Nikon Coolpix S4000 Digital Camera
How do I get a alingment test
HP PSC 1200 and 1300 series:
  1. Turn on the HP PSC 1200 or 1300 series product.
  2. Disconnect the USB cable from the all-in-one.
  3. Press the sequence of front panel buttons below to start the print cartridge alignment process. The button-press sequence must be completed within ten seconds. It might take several tries to complete the sequence within ten seconds.
    1. Press and hold Cancel .
    2. While holding Cancel , press On .
    3. When the Check Paper and Check Print Cartridge lights begin to blink simultaneously, release both buttons.
    4. Press Cancel again.
    5. Press Copies .
    6. Press Paper Type .
    7. Press Color Start Copy . The alignment page will begin printing. If the alignment page does not print, repeat the button-press sequence in this step.
  4. When the alignment page has printed, place the page face down on the scanner glass and press Scan . The alignment is complete when the On light stops blinking.
  5. Reconnect the USB cable.
Jan 14, 2009 | HP PSC 1210 All-In-One InkJet Printer
Nikon Coolpix digital camera got wet and stop working
i spilled soda on my nikon camera its a touch screen camera,( small red one) what do I do to fix the problem. I take a piccture it shows kind of black or gray. Should I open it or take it to a store
Dec 26, 2008 | Cameras
Actually for a HP deskjet 990cxi
Alignment:
1. Turn on the HP DeskJet.
5. Press Copies .
Jun 03, 2008 | HP DeskJet 940c InkJet Printer
Powershot sd400 elph,got wet
If you tried turning the camera on while the electronics were still wet, it may be too late to offer any help.
Assuming you do this again, any piece of electronics that is immersed in water may begin to corrode immediately upon exposure to air, and if you don't want to take the chance of corrosion, you should take your camera to a professional repair depot.
Without disassembling the camera and drying out the pieces manually, there's nothing you can do except open every available crevice (lense, battery area, CF memory slot), remove the battery and memory card (which can then be dried CAREFULLY by hand), and hope that all pieces of the camera will eventually dry out (I'd leave it in a dry, warm environment for at least 3-4 days - longer if you can wait).
Nov 30, 2007 | Canon PowerShot SD400 / IXUS 50 Digital...
Pentax Optio S5i Digital Camera Logo
49 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
