Had same problem....Its fixed now working great....had 2 blown capacitors.Cost me two bucks and about an hour to fix.Look at the capacitors on the main power supply they should be flat...I you need help email me [email protected]
With most startup issue with this model there usually is a blink code sequence on power led on front of set. regardless of sequence though you would want to isolate problem by disconnecting y main from power supply and check voltages on power supply and if they come up replace the y main and y buffer boards located on left side of tv looking from back and if voltages do not come reconnect y main and disconnect x main and check voltages again and if still not coming up reconnect and verify vs on command on pin 2 of logic interconnect and if 3 volts present replace power supply and if 0 volts present replace ssb
When I plug in the core a GREEN led comes on then when I hit the on switch A RED led blinks 7 times & continually repeats the blinking sequense..WASSUP WIT DAT?
I have the same problem. Cant power it on or anything. Any one have any advice on this...
