Question about Sony RDR-VX525 DVD Recorder/VCR
Will not reset to the easy menu as to change DVD 1 setting
I have tried to unplug the vx525 but it will not go back to the easy setup menu.
  • Anonymous Aug 24, 2008
    I cannot use the remote to the Sony DVR-VX525 anymore. It says DVD1 no matter what button I push on the remote. I tried pushing the Enter button and the number 3 button at the same time for up to 5 minutes and it still would not reset. Any other solutions out there?
  • Anonymous Sep 23, 2008
    ya it keeps saying dvd 1 its so annoying
Try putting fresh batteries in the remote and then:
1. Push and hold "Enter"
While
2. Push and hold "1"
Keep them down for about 5 sec.
Your remote is now in mode 1 and will talk to your RDR VX-525.
In the EZ Setup are you can change the unit back to remote command mode 3 if you wish. The remote will stop working again, but you just have to repeat the setps above using button "3" instead of "1".
Posted on Dec 15, 2008
  • supertiti Jan 11, 2011
    Mojomolina..You are the best!..I even buy another remote that didn't work either. So, is the program between the remote and the unit. When I change batteries, I did have to perform the MAGIC procedure to have the new working too.
Mojomolina's right this worked for me except my RDR VX-525 was saying "DVD 3" every time I tried to do anything with the remote. I think as long as you choose the same mode as what's on your RDR VX-525 it should work. Example:
Unit shows
"DVD 3" "hold Enter and 3"
"DVD 2" "hold Enter and 2"
"DVD 1" "hold Enter and 1"
Thanks again Mojomolina
Posted on Jan 29, 2010
Is their a manual way to change dvd1 to dvd3
Posted on Mar 27, 2010
Dvd recorder
The following should give you access to a service menu containing controls for macro-vision and region coding. You can change the regional settings from there.
1. Set your player to Standby
2. Press Title, Clear and Power
Jul 05, 2008 | Sony RDR-VX525 DVD Recorder/VCR
When dubbing dvd to vhs, the vhs has no color. recording from tv and playing vhs tapes color is ok.
On your remote Press the System Menu botton when open scroll down to Setup, press Enter, scroll down to Video and press enter another menu will open. Scroll down to Personal and press enter and play with settings while watching the Video you want to make changes to, until you are Satisfied__!
Jul 18, 2011 | Sony RDR-VX525 DVD Recorder/VCR
Remote RMT-D240A not working with RDR-VX525 DVD Player that it came with. Only get DVD Screen saying DVD 3, will not even turn ON/OFF.
You may have to reset the remote to the current command code. Here is the link for how to do that. http://community.sony.com/t5/Remote-Controls/RDR-VX525-Changed-to-DVD3-on-command-control-and-remote-won-t/td-p/158777
Dec 17, 2010 | Sony RDR-VX525 DVD Recorder/VCR
My Sony RD-VX525 DVD Recorder got set to DVD1, is there any way to set it back to DVD3 so I can use the remote again?
On the remote press the System Menu botton when opened, press Enter and scroll down to Option and press Enter then scroll down to Command, press enter and you'll find DVD1,DVD2 and DVD3 scroll down to it press Enter set or reset your unit as desired!
May 17, 2010 | Sony RDR-VX525 DVD Recorder/VCR
Device locked up
Check dvd recorder remote that has 3 dvd mode switch DVD-1, 2 and 3
set it to DVD-1 and remote will work with dvd recorder.
May 17, 2009 | Sony RDR-VX525 DVD Recorder/VCR
DVD player set to the wrong TV type and I can't see the menu
if you have a component connection, switch the yellow video cable into the component BLUE connection. You will get am image, just reset the unit or undo the setting.
Nov 11, 2008 | Televison & Video
Dvd1
Try this: Unplug the reoreder from power source for about 5 minutes and then reconnect. It will ask you to go through the Easy Setup first. Once you do this, you can set up the command mode.
Standby
Try this: Unplug the recorder from power source for about 5 minutes and then reconnect. It will ask you to go through the Easy Setup first. Once you do this, you can set up the command mode.
Remote is Stuck in DVD 1 mode
I had this same problem (DVD1). Resolved as follows: With DVD player on, pointed remote at DVD player, pressed and held the 1 key and then pressed and held the enter key (both at same time) until I saw the DVD1 on the DVD player display disappear. Now everything works.
Jun 23, 2008 | Sony RDR-VX525 DVD Recorder/VCR
Sony RDR-VX525 DVD Recorder/VCR Logo
462 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
