Question about Frigidaire FMV156DC Microwave Oven
Door is loose, microwave won't cook
Door is loose and microwave won't cook
  • 3 more comments
  • ruthbellan Aug 21, 2008
    special tape has been wound around the two hooks that close the door. If I hold the door stronly upwards, the turntable rotates and it will heat, but stops if not held. There must be a better way My condo caretaker tried to fix it. It's the 2nd time the door activater doesn't work in the last year.
  • lushtf Aug 31, 2008
    I have the same problem. It seems the door is sagging - if I push up from the hinge side, the microwave begings working. When I release it, it stops.
    The microwave is only 2 years old and I probably won't buy another Frigidaire microwave. Biut I need to know if there is a part I need to replace.
  • Steve Grabowski Oct 22, 2008
    Same problem with me door, I actually shimmed the bottom hings but now the microwave is not working at all when you push up on the door. You can hear the switch clicking when you push up but it's not cooking. Can someone help?
  • jguere Nov 28, 2008
    Same exact problem here... not sure how to fix it yet... when I do, I'll post it here...
  • eskanazy Jan 20, 2009
    my ge model jkp77g (j1) has a sticking door. my diode is blowing and the microwave doesn't work; i think i need new switches, but also an adjustment of the door...any thoughts?
  • Frigidaire Master
  • 9,174 Answers
The door switch mounts and possibly the door hinges need to be adjusted them tightened.
Unplug the oven, remove the cover if it's a counter top type or remove the grille and control panel if it's an over range type.
Then close the door and watch how the door latch heads on the door mesh with the door lathes and door switches.
Also check the hinges.
If the door latch heads are not activating the upper & lower door switches, then adjustment will be needed.
For many brands, you can find helpful exploded view diagrams and order parts by entering your full model number here.
There is often a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Please reply back with your brand and model number if you need more help.
Posted on Sep 02, 2008
SOURCE:
Microwave door alignment is off, will count down but won't cook
My microwave will not heat up its in a defrost mode. How do I change it?
Jul 27, 2013 | Sharp R-1505 Microwave Oven
My Panasonic 1300w microwave will not turn off. It doesn't cook but won't turn off without actually unplugging it or opening the door and leaving it open. Any help?
You may have a shorted door switch or a shorted relay on the control board.
You can see a help file on door switches here.
Dec 01, 2012 | Panasonic NN-SN657SMicrowave Oven
I pulled the door off my advantium today to clean it after I cleaned the vent grille. I set the door carefully on it's side so I thought but a small little plastic piece broke off where the door...
Glue won't work, the part must be replaced.
We have the service manual at our site and you can download it free here.
You can order parts from the Pros here, our favorite supplier.
Jul 07, 2011 | GE Advantium 120 Convection/Microwave Oven
Hinari microwave doesn't cook
hello mam
i am having the solution for this problem check the lock terminals for loose connection and if its working and check the magnetron which produses the heat inside the microwave.
Sep 25, 2009 | Microwave Ovens
Microwave not cooking
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
The best place to order parts is Tritronics. You can also call them at 866-779-5835
Nov 21, 2008 | Panasonic NN-T990SA Microwave Oven
I would say you have a bad door switch or door switch mount, or your door is loose or out of alignment.
But since it's new, and under warranty, I would contact Goldstar (LG) customer service to have them repair it free.
Contact LG at 1-800-243-0000 or http://us.lgservice.com
We're happy to help and we appreciate your thoughtful rating of our answer.
Feb 28, 2008 | Microwave Ovens
GH7145XFB-1 not heating properly
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Nov 16, 2007 | Whirlpool GH7145XF Microwave Oven
Frigidaire FMV156DC Microwave Oven Logo
403 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Ekse
Marvin
Marvin
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
