Question about AOpen MX3W Pro-E (91.88210.241) Motherboard
Aopen MX3W PRO MOTHERBOARD (-V) pin location for power on
Need to know specifically were the pins are
    President:
  • 2,351 Answers
Hi enoschan,
Download the pdf manual AOpen MX3W Pro motherboard. Click on this link: http://download.aopen.com.tw/Default.aspx
Fill in the three drop down menu's as follows.
Motherboards
MX3W PRO
Manual
Choose, click on: English manual for MX3W Pro, MX3W Pro-E, MX3W Pro-V. 6200Kb, (They all share the same manual). A pop-up window will open. Under Mirror Sites click; USA, San Jose.
You may have to wait a few minutes before the pdf manual will open. Do not download this manual unless you already have Adobe's pdf reader installed. If you need the Adobe reader, download it for free from here: http://www.adobe.com/products/reader/
Once the ftp: pdf manual opends go to Motherboard Map for the location of the pins you have in question. To connect your case LED's to the motherboard goto page 29 in the pdf manual.
I hope this information is whay you are looking for.
If you need more help with anything just let me know.
Good luck enoschan!
Mike
Posted on Aug 18, 2008
I have aopen ax4bs motherborad and i don't know where the power sw goes
If you look at the picture below, I have circled in red the two parts you have to connect for your power supply to the motherboard.
Nov 24, 2010 | AOpen AX4BS Pro (91.89J10.001) Motherboard
I m using A open MX3W pro -v motherboard ... In that pentium 3 processer is not working ... But celeron is working
Try adjusting the CPU Frequency in Bios Setup for your processor. You can also try downloading the lastest BIOS release from http://global.aopen.com/userdownload_List.aspx?RecNo=2931&Model=244
May 13, 2010 | AOpen MX3W Pro-E (91.88210.241)...
I m using A open MX3W PRO -V motherboard ... in that pentium 3 processer is not working ... but celeron is working
The processor socket type must match the board design - The P3 processor may not be the equivalent type.
Mar 23, 2010 | AOpen MX3W Pro-E (91.88210.241)...
I need a schematic (pin-out)of the MX4-ge motherboard
You can download the manual for you're AOpen MX4GE motherboard from the link provided below; ftp://ftp.aopen.com/pub/manual/mb/mx4ge/mx4ge-ol-e.pdf
You'll need Adobe reader installed to view the *.pdf file above.
Download Adobe @ http://www.adobe.com/products/reader/
Open manual to page 33. Here you'll see the layout for the front panel motherboard pins. The view towards the left shows where to connect the jumpers coming from the case to the motherboard. The view on the right shows where each positive wire and negative wire connects. The common colored wire for each jumper will be used as negative. Except for the internal speaker 4-pin jumper. Normally positive wire is red in color and ground is black in color and connects to pins 16 and 19 only. Pin 1 is shown. Pin 2 is to the right of pin 1. Pin three is below pin 1 ECT.
Cheers'
Mike
Mar 03, 2010 | GE AOpen AX4GE-N (NMBA0102) Motherboard
Were are the jumpers to disable the on board videofor aopen mx3w pro-E
Why do you need to disable the onboard video??
If you have added a new graphics card it should automatically select this new card.
If it doesnt, you can go in to the bios and disable the onboard graphics card from there.
For example, Onboard graphics can usually be refered to in the bios as PCI, so if you've added an AGP card or PCI-E card then you would just need to select either one of these from the bios menu.
Not sure what bios your using but it may even have ann option to disable onboard graphics.
Oct 23, 2008 | AOpen MX3W Pro-E (91.88210.241)...
How to connect Remote to computer
Hello Nairy, Install infrared module onto IrDA connector, and enable function from the BIOS setup. Make sure you have the correct orientation when you plug into the motherboard. Location: Towards rear of motherboard, next to first PCI slot, on AGP side. The number one pin is closest to rear of board. Pin Configuration: 1. +5V 2. NC 3. IRRX 4. GND 5. IRTX 6. NC Please let us know how this works for you, and if we can help you in any other way. Best regards, nightdiver
Sep 20, 2006 | Acer AOpen AX 59 Pro II (91.87810.402)...
AOpen MX3W Pro-E (91.88210.241) Motherboard Logo
571 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
