Question about Epson RX620 All-In-One InkJet Photo Printer
RX620 printer will not scan--gives a hi pitched wail but no error message
I have used this printer for a long time and it always has worked well. Recently, while scanning slides, the unit gave out a loud fairly hi-pitched wail, but no error message! If I try to scan the wail repeats.
Now this is a strange one!
Regards.
Gordon
Cycle the transportation lock on and off a few times--that should fix it. Dunno why
Regards.
Gordon
Posted on Aug 26, 2008
Printer error see documation
This work for rx600, am not sure about rx620 but you can give it a try,
press all the following buttons at the same time: Power+B&W+Color
then you will see a message on your printer's screen
turn off the printer
Feb 18, 2010 | Epson Stylus Photo RX620 All-In-One InkJet...
Changing ink reservor on Epson rx620
Are you often to used refilled cartridge? That's possible your waste tank has been fulled. Hold down the 'Stop' AND the 'B&W' button while powering up. This seems to clear the error message and restore the printer. Worked for me--dunno how long it will last tho!
Please rate me SOLVED.
Regards.
Nov 20, 2007 | Epson RX620 All-In-One InkJet Photo...
Possible to soak up excess ink on the 'pads'?
Hi Macddcam...
You have to remember that the pads are designed to be ultra absorbent so it's going to be very difficult to get them to give up their ink unless you have something even more absorbent.
Trying to mop up or syringe out pads is really a bit of a losing proposition in terms of time, effort and ink mess so really the smarter option is to redirect the waste flow (ie: install an external tank) and allow the ink base (ie: water in the RX620) to slowly evaporate off over the course of the printers life..
If you need information on the process for the RX620 then you can find it here
Mar 28, 2009 | Epson RX620 All-In-One InkJet Photo...
Epson Photo Stylus 950 not functioning
when ever you want to refill ink make sure, that the ink you refill decompressed for about 30min before you fix it into the printer.
Another thing is that you uninstall the software of the printer and reinstall again, and check the power supply of the printer is working perfectly.
Dec 03, 2008 | Epson RX620 All-In-One InkJet Photo...
Epson Stylus Photo RX620 Printer
Hi
If its E-90 error then there is a hardware problem with the printer already.
Hope this helps
Oct 13, 2008 | Epson Stylus Photo RX620 All-In-One InkJet...
Service repair printer
I had this problem also. What i did was hold down the 'stop' and the 'B&W' buttons while powering up. this erased the error message and now I am up and running fine again.
Aug 24, 2008 | Epson Stylus Photo RX620 All-In-One InkJet...
Rx620 stylus printer
Where are you located? US or UK? if you are in US go to this link so that it will give you the information for that error message
http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp
Please read the FAQ then fill forms so that you can Download a utility for it
If helpful, pls dont forget to rate solution. Thanks!!
Apr 22, 2008 | Epson Stylus Photo RX620 All-In-One InkJet...
RX620 "Ink Cartridges cannot be recognized"
Found the solution at
http://www.fixyourownprinter.com/forums/printer/54833
Try pressing down on the cartridges after inserting them and closing the top of the cartridge carriage. Worked like a champ on my R320 printer!
Cleaning the contacts on the cartridge with a soft tissue may help too.
Mar 21, 2008 | Epson RX620 All-In-One InkJet Photo...
Error message
Hi-
Its the operating system on the computer since it won't accept this types of images in your computer. Try saving the scanned document on a different folder/ or in your desktop. If everything fails, reformat your computer.
Hope this helps
Mar 16, 2008 | Epson Stylus Photo RX620 All-In-One InkJet...
RX620 Error Message
This message comes up after about 40000 registers on a use counter. I posted what I did on the Epson RX620 forum. Look it up. Basically I bought a repair manual on the net for about $10.00 I used this to take the RX620 apart down to the waste ink catch pads which I removed cleaned dried and replaced. It was a long job the first time and you need the manual in order to figure out how to do it. My pads were only about 1/3 used but I live in a dry climate. So punch those override buttons and keep going. You might put a plastic sheet or pan under the printer to catch the waste ink when it actually does leak out.
Jul 30, 2007 | Epson RX620 All-In-One InkJet Photo...
Epson RX620 All-In-One InkJet Photo Printer Logo
294 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
