Question about Cooktops
Jenn-air cvg2420w will not ignite - Cooktops
  • Anonymous Sep 08, 2008
    My cooktop ignites but the electrode igniter contiues to fire constanly
  • jmolleja Jan 24, 2009
    Ignitor continues running after flame is on
Why do Jenn-Air cooktop igniters click when the exhaust fan is on med-high and the burners are on low flame setting ? ?
Igniters sense flame temperature, and if the fan cools the temp sensor down, your cooktop thinks the flame has gone out, so it clicks to reignite it.
Sep 02, 2014 | Jenn-Air Cooktops
3 of the 4 burners clicks and sparks when I try to
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Jul 27, 2010 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
I have a Jenn-air, C206-C model grill-range cooktop. Three of the 4 burners have stopped working. Any solutions?
heatman101
Jun 04, 2010 | Jenn-Air JED8230 Electric Cooktop
I have a jenn-air sealed gas cooktop jcg8430 only 1 burner lights
you have a problem with the ht leads or spark electrodes
Aug 18, 2009 | Jenn-Air Cooktops
Jenn-Air JGC8536 Gas Cooktop ignitor replacement
One burner doesn't consistently light. Igniter sparks but not the same as the other - "good" burners spark at top of igniter and moves around to light, "bad" burner sparks toward the bottom and doesn't move much. I can use the burner by lighting with a match and it works fine. Have tried cleaning with a toothbrush without much success
Dec 12, 2008 | Jenn-Air JGC8536 Gas Cooktop
Replacement Vale/ignition Switch for Jenn-Air CVGX2324
The best place that I think has the best prices and customer service is:
http://www.vvapplianceparts.com/
1-800-743-3682
Call them and they will help you!!
Hope this help!
Eddie Rentas
Tupper Lake
Jul 30, 2008 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Igniters will not turn off
Your switch assembly on the valve shaft has come loose or has broken. Have a look.
May 23, 2008 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Cooktops Logo
238 people viewed this question
Top Cooktops Experts
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
