Question about Philips 26MF231D 26 in. LCD Television
I can't get my tv to turn on... nothing but blinking red light
I have a 50" Magnavox 50MF231D Plasma HDTV.. I go to turn it on and it will show the green power on light for only a few seconds then it swithes to a blinking red light next to it.. the red light blinks four times and then a pause... after the blinking red light has taken over I can not even power down the tv without pulling the power plug... I have tried what others have suggested... I have pushed the menu button while the green light is still on and nothing... (I have tried this over and over) I have also ran a power cord to another outlet in the house ... same thing... I need some help please!! Thank you
  • 4 more comments
  • damien_polan Sep 24, 2008
    Same thing. 4 flashing red lights. No picture, no sound, nothing.
  • helenamirao Oct 10, 2008
    I have the same problem with my tv... did you find a solution?
  • Anonymous Nov 08, 2008
    I too have the same problem they say it is internal
  • Anonymous Nov 15, 2008
    Same Problem here... help me girls!
  • Anonymous Jan 21, 2009
    same problem, plug it in, get a green light, then it blinks red forever. cant get it to power up at all. Help ME!!!!!
  • Anonymous May 02, 2009
    same problem. unplugging it and plugging it back in about 20 times works then the next time it takes 30 or doesnt work and I let it set for 2 hours and start the process over again. HELP
    Genius:
  • 1,003 Answers
Replace mainboard or power supply.
Posted on Feb 03, 2013
    Sniper:
  • 63 Answers
Thats nots it its bad caps.....
need to replace 3300uf 10V with 3300uf 16v or higher. A couple of bucks in parts and some soldering.
Fixed both of my 50" sets
Posted on Feb 16, 2009
Dont know if this will work for you or not, but my brother gave me his because of the same problem. It would power up and a green light would come on, then after 10 -15 seconds it would change to a red blinking light. I plugged a usb cable into the service port on the side and left the other end unplugged. Then plugged the tv back into the power. i took a small screwdriver and ran across the contacts in the end of the usb cable until both the red light and the green lights came on. I did this several times listening fot the clicking noises in the TV. after doing this for approx 20 seconds, i pressed the power button and the TV worked fine. 5 days now and no problems. Only thing I can think is I somehow reset the software and now it is working fine. Hope some of you can figure this out and give it a try. if the TV is just sitting, you have nothing to lose
Posted on Jan 21, 2009
2 Suggested Answers
SOURCE:
  • 1779 Answers
SOURCE: Magnavox 50 plasma Model # 50MF231D dead no power.
Well, if you are going to troubleshoot it, what voltages do you have out of the PS and do you have 5v standby. If your not able to do this then I would take into your local service center.
Posted on Aug 26, 2009
I have a 50pf7321d 50"
Oh. It's Great. Never show it to anybody!!!!!
Jun 29, 2017 | Philips 50PF7321D 50 in. Plasma HDTV
We have a Magnavox, 50 inch plasma TV, model 50MF231D/37. Recently when the TV is powered off and an attempt to power it back on again has been made, we get a red blinking light. The light blinks six...
Your problem is caused by a power supply issue it sounds like a capacitor is leaking or has vented and will need to be replaced if your comfortable you could check the power board for a can shaped electroletic cap that has vented it will be puffed up on the top the value is printed on the side you can or have someone replace it that should take care of your problem the power board is the one where the AC cord plugs to or leads to
Dec 10, 2009 | Televison & Video
I have a 50' Plasma HDTV and when I turn it on
First thing to try is replace any swollen capacitors on the power board.
Nov 01, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
I have 50 in plasma phillips magnavox 50mf231d-37, will not come on red light flahses 4 times
this is some info that some one else had found
get a memory stick( flash drive) and up load their soft ware from their site. I plug the stick into the computor and uploaded the software. I then plugged the stick into my TV on the side. A screen came up and the software loaded on the TV successfully. The red light then turned to green. However, I now have to unplug and plug the TV several times for it to turn on. It works fine but once the TV is turns on, but when I turn it off and it cools for a while I have to repeat the same proceedure off plugging and unplugging
Jul 12, 2009 | Philips Magnavox 27MS343S 27" TV
50' plasma, does not turn on,
still nothing, tried twice last night and second time tv worked, this morning nothing
Feb 14, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
50" Magnavox Plasma TV will not turn on - Red LED blinking 4x
When you have the red light that blinks four times on the 50" Magnavox Plasma Model 50MF231D/37, you should look for the capacitors on the power board in the center of the of the TV. Look for two 3300uf, 10V, 105c capacitors that have a build up of pressure that has caused the top of the capacitor to look rounded instead of the flat top that will be on all of the other capacitors. Changing these two capacitors fixed the problem of the TV not coming on.
I had more trouble finding the capacitors than changing them. I could not find them locally so I went to an on-line electronics supply store where they were $1.65 each and $8.99 to ship.
Jan 03, 2009 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Philips 26MF231D 26 in. LCD Television Logo
1,785 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
