Question about Kenmore 22422 Top Load Washer
Need help fast w/ older Kenmore...
We have a nearly 40 year old Kenmore machine that has suddenly stopped feeding fabric...any suggestions?
Our Jenome has gone down also & have several orders that must go out within days.
Thanx so much, in advance!
  • 943 Answers
Hi thanks for the question you mean liquid fabric softener in agitator if this the case if the fabric softener stayed in agitator this means it did not spin check the spin cycle to see if it spins thanks the appliance doc
Posted on Sep 27, 2008
Fabric feeds crooked when sewing
Would suggest taking your machine for service. Could be the feed dogs need adjustment or realignment. Also, make sure you are using the correct presser foot for your machine. With all the new machines that have 7mm and 9mm presser feet (most older machines have 4mm or 5mm), using the incorrect width presser foot may cause the fabric to skew.
Nov 16, 2017 | Brother Sewing Machines
The feed dog is up but has stopped feeding
Are the feed dogs moving at all--like moving toward the back of the machine, dropping down below the needle plate, moving forward, rising, and then moving toward the back of the machine? Make sure the stitch length is set high enough to actually move the fabric--not set at zero or near zero. If the feed dogs stay below the needle plate, then most likely they have been dropped for darning.
If the feed dogs are frozen, not moving, and it is an older mechanical machine, they may be seized due to old oil.
Wheel on right side that controls the needle up and down is very tight...
Or, the feed dog mechanism is broken.
Sep 01, 2017 | Sewing Machines
My kenmore suddenly stopped feeding. The feed dogs are going up and down but not forward and back.
What model is your Kenmore? Older mechanical machines need frequent oiling. If your machine is computerized, you should probably take it for service.
Jan 24, 2017 | Kenmore Sewing Machines
I have an old Kenmore Convertible 1785 machine. It is working fine except it won't pull fabric thru. Any suggestions on what could be wrong?
Are the feed dogs in the up position? Is your fabric very slippery or silky? If it is you need to use a tear away for the feed dogs to grab on to I order to move the fabric forward.
Nov 26, 2016 | Kenmore Sewing Machines
I just got an old Sears Kenmore Sewing machine model 385.17781. Everything is working fine except the reverse stitch. When the reverse button is pressed, the fabric doesn't move or sometimes movin
it sounds like the feed dogs & the reverse button need to be
checked at a repair shop,
to see why they are not responding to each other.
Sep 08, 2012 | Sewing Machines
I have a zig zag dressmaker and i have tried puting my tension on every setting, flossing the thread, made sure my feed gogs where in the up position. and i use european thread. My thread keeps wrapping...
may I suggest to put a new needle in
clean the bobbin area where the feed dogs are for lint & also use that can of air for pc's in the bobbin area
some machines have a problem in the bobbin area & can pull the fabric in the bobbin area when the thread comes off the thread take up lever
I hope my suggestion help you
Nov 20, 2010 | Kenmore Drop-In Bobbin 16231 Mechanical...
I have the Scandia probably 5 yrs old...feed dog is up but wimpy...not moving fabric....it's sporatic...many times the fabric stops and the needle sews in place and then is will move a little - stitch...
The feed dog motor needs re-calibrating. If recalibrating does not resolve the problem, the feed dog stepper motor may need to be replaced. These tasks have to be done by a certified Husqvarna Viking service technician. Suggest that you take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Jan 08, 2010 | Husqvarna Viking 1
Feed dogs are not pulling the material back
White sewing machine model 510, feed dog problem; fabric is not moving; I must firmly pull fabric through.
The feed dog is moving; fabric is not.
The fabric is not feeding properly; the fabric goes back and forth. However, the fabric does not continue to move away from me.
The feed dog is positioned up and is not smooth, it feels rough when I touch it with my fingers.
Because I had not used this sewing machine for a couple of years, before sewing, I cleaned the inside with the wire brush that came with the machine.
In an attempt to trouble shoot the problem, I applied varying pressure foot levels and stitch lengths.
Does anyone have any suggestions as to what may be the problem?
Jun 27, 2009 | Kenmore Sewing Machines
My kenmore 385 won't feed fabric
Check to see what pattern is selected. Be sure it isn't the buttonhole.Select straight stitch.Move the stitch length setting to 4.Turn the handwheel and see if the feed dogs move forward. Press the reverse lever and see if they move backwards. Select straight stretch stitch and turn the wheel to see if the feed dogs move forward and backward.Check the presser foot release on top of the machine and make sure there is pressure on the foot.
Sometimes the reverse assembly on this machine stops working because it has the wrong type of grease on it and it turns into a hard gummy mess that won't let it work.
sewman7
May 14, 2009 | Sewing Machines
Fabric not feeding and jamming occurs
When this happens it is because the thread tension was not right so it gets stuck under the bobbin case and the feed dogs. Use a bigger lint brush and take out the bobbin casing and clean out the shuttle. When you rethread pull slightly on the thread before you feed it through the needle. This will make sure the thread is properly in the tension discs.
Jun 13, 2006 | Kenmore 19233 Computerized Sewing Machine
Kenmore 22422 Top Load Washer Logo
78 people viewed this question
Sal De
fordexpert
 Brian Main
Brian Main
