Question about HP iPAQ RX3115 Pocket PC
Screen locked up
My screen is locked up on the calendar page. It beeps everytime I do a function and won't allow me to do anything on the screen.
Went online to Hp Pocket PC, I downloaded their troubleshoot info. Solve my problem.
Thanks for your quick reply.
Posted on Aug 19, 2008
SOURCE:
Our oven is beeping no error code.I switched off breakers, but now only a few buttons work
Usually, this is a keypad problem, keys are internally shorting intermittently causing the beep at odd times. Touch controls are still available for this model, enter your model# on a parts supply site and find your color....
Feb 23, 2016 | Amana AEW4630DDS Electric Double Oven
Iphone task and calendar alerts disappear when I enter password
Depending on the OS you are running they are in Notification Center(iOS 6 and Later). You can access Notification Center by swiping down from the very top of your screen in iOS 7. You can change Notifications on an app by app basis in Settings, Notification Center.
Jun 03, 2013 | Apple iPhone Cell Phones
Forgot the combination to the lock. Is there a way to retrieve the combination or return it to its factory default combination 1, 2, 3, 4, 5
The instructions below are copied from the programming instructions (page 11):
ERASE ALL PROGRAMMING
(The "out of box" factory default will be restored)
1. At the back of the lock, remove the screw at the bottom of
the lock housing and remove the cover.
2. Take out the battery pack and remove battery power by disconnecting
the battery pack.
3. Plug in the (provided) male shunt connector into the yellow
wire female connector.
4. With shunt connector connected, re-connect the battery
pack. The lock will immediately sound 3 short beeps (if
these 3 beeps are not heard, then restart at step 2).
5. The lock will then sound more slow beeps, 1 beep for every
second it takes to clear the memory.
6. After a few more seconds, the LED will slowly alternate between
flashing red and green--disconnect the yellow wire
shunt connector.
7. The LED will continue to slowly flash green and red for 25
seconds. To enroll Function Cards, proceed immediately
as follows:
• With the lock LED slowly alternating between flashing
red and green, present the Function Card #1
to the lock. The lock will sound 5 slow beeps.
• The lock LED will flash green rapidly. The lock is
ready to enroll the Function Cards.
• Re-present Function Card #1 to the lock. The
lock LED will flash green then red, with two beeps
(indicating the card was enrolled successfully).
• Present Function Card #2 to the lock. Again, the
lock LED will flash green then red, with two beeps.
• Continue to present, in order, Function Cards 3-
9. Each time a new Function Card is presented, the
After the 9th Function card is presented, the lock LED will flash
green twice, sound two beeps, and will then remain silent,
ready for use. Note: If the lock continues to beep after presenting
the 9th Function Card, check to verify that the yellow
wire shunt is disconnected.
Note: If you only wish to use the first 3 Function Cards, simply
allow the lock to "time out" after 30 seconds.
Here is the link to the complete instructions, in PDF form. You will need Adobe Acrobat or equivalent to view them:
http://napcosecurity.com/download/PL3000_WI1280A.04_PROG.pdf
Good luck-and please provide feedback if this helps!
Nov 04, 2011 | Trilogy ALARM LOCK PL3000 Series T3 Prox...
I have a wide screen Acer monitor, yet am unable to view my whole web site without scrolling down. I have adjusted the resolution to allow the font to fit on the page, and can see it perfectly with IE,...
Sounds like either your display resolution needs to be set higher or when you bring up firefox after the page loads press and hold the ALT key and Click View, ToolBars and select Menu Bar. This will keep it at the top everytime you open firefox. Now under View you can zoom in and zoom out. You can also select Full Screen. *** Before doing anything did you click the middle box at the top right hand corner of the screen between the - and red x? This toggles between full screen also.
Feb 25, 2018 | Acer X243W 24" TFT wide format screen 24...
I HAVE AN ITOUCH AND USE YAHOO CALENDAR. HOW DO I SYNCH THEM? SHOULD I USE MOBILE ME?
If you are running iOS 4.x software or newer
  1. Go to the ipod touch settings application
  2. Tap Mail, Contacts, Calendars
  3. If you have a Yahoo mail account setup click on that account and turn on the calendar sync option
  4. if you don't have an account setup, click Add Account and then click Yahoo
  5. Fill in the fields requested and click Next
  6. If you are successfully logged in you will be allowed to turn on and off specific sync services. make sure that calendar is in the on position
  7. The next time you open up your ipod touch calendar you will see a page allowing you to select which Yahoo Mail layer you would like to view or edit
If you are running iOS 3.x
  1. Go to your iPhone or iPod Touch settings application.
  2. Tap Mail, Contacts, Calendars.
  3. Tap Add Account.
  4. Tap Other and then tap Add CalDAV Account.
  5. For the Server you can simply type yahoo
  6. Now enter in the Yahoo! ID and password you use to sign in to your Yahoo! Calendar
  7. Once you click save, the iPhone or iPod Touch will verify your Yahoo! ID and password.
  8. The next time you open up your iPhone or iPod Touch Calendar you will see a page allowing you to select which Yahoo! Calendar layer you would like to view or edit.
Mar 01, 2011 | Computers & Internet
Calendar events from iPhone delete after syncing
when in itunes look at the iphone page, click on calandar on the tabs on top, when you see that click "dont sync" that should do it.
May 10, 2010 | Apple iPhone Smartphone
How can I prevent my E Machines logo from loading everytime I start my computer. I have Windows XP.
Press and hold the F2, F12, or F8 function key (one of the three at a time) after jhearing a single beep following a restart. One key (usually F2) will allow you to change the BIOS settings. (If the computer boots normally, restart it again and try the next function key.)
BE CAREFUL. Don't change anything you are not sure of because doing so can make your computer inoperable!
You will eventually get to the BIOS settup utility. You will have to use the keyboard to navigate to the setting that disables the splash screen. (You may have to enable something like "detailed boot report" or "OEM settings", depending on the computer.)
My American Megatrends (AMI) BIOS has a "BOOT" section that contains a "Full Screen Logo" setting. I "Disabled" it to do what you want to.
Incidentally, the splash screen doesn't really slow the boot process much, since you are simply substituting a static picture for the BIOS boot information.
Aug 25, 2009 | eMachines EL1210-11 PC Desktop
Alarm beeping
Not sure, but the 1x active may have to do with some time of alert that you may have accidentally set in your calendar or alarm clock. Check your calendar and alarm for active alerts.
Dec 24, 2007 | Kyocera KX2 Cellular Phone
Calendar function
The IR-500 allows you to display pictures in a calendar. When still pictures and movies are shot, the camera automatically sets the pictures to the calendar according to the shooting date. The calendar can be displayed in three ways: as a one-month display, 12-month display, or multi-year display. Select the desired date, month, or year from each calendar display.
Sep 01, 2005 | Olympus i:robe IR-500 Digital Camera
Open Questions:
See all HP iPAQ RX3115 Pocket PC Questions
HP iPAQ RX3115 Pocket PC Logo
125 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
