Question about Cameras
My camera was dropped and now the lense is jammed in. and it will turn on and say lense erro. and it will shut off. is there anything that i can do with out having to go to a shop?
  • jenspaz Sep 22, 2008
    I have the same problem. A 3 year old got a hold of my camera tonight, and ended up dropping it on the floor. The lens is jammed in on one side, and I couldn't get it to work right again. It gives the lens error message as well. Just wondering if anyone has found a simple solution to this problem, or if it needs a repair shop (I was concerned because Im not in an area with a shop nearby).
  • Anonymous Jan 07, 2009
    I got hit with a basketball and my camera fell and it said i have a lense error and then went blank. tried to take out battery and memory card but did nothing!
    Anything to help????
I suggest you call Nikon Support and ask them to replace your lens motor. If your under warranty, you might as well get a replacement. Otherwise, you can ask a repair shop to replace your lense.
Posted on Dec 25, 2008
My lens is stuck out and it will no longer take pictures. It is brand new!
The lens has either been hit, dropped against something, or the camera allowed to turn on while in a pocket/purse/case. The lense drive gears are plastic and not entirely substantial and require care - which most people especially teens and 20's don't give them. Once in this condition, they're done for. You can attempt to contact Fuji for repair, but you'd be responsible for the cost unless they're feeling especially nice that day, since there's simply no way for the lense to become jammed during normal operation - unless the lens is bumped or hit while open.
Since these camera require total disassembly, from the back forward, to get to the lense assembly, it'll be cheaper or near it to replace it than to repair it. Take it as lesson learned, and treat the next one with more care. NEVER touch the lense when open, NEVER allow it to bump anything, NEVER drop it, NEVER place it in your pocket or purse unless the power button is protected from being accidentally turned on.
Aug 22, 2011 | Fuji Photography
CAMERA DROPPED AND LENSE IS STUCK OUT AND CAMERA
your len's mechanism is damaged or jammed. It would be too expensive to repair!!Hopefully this helps
Jul 24, 2009 | Polaroid i631 Digital Camera
Camera got dropped now it won't turn on.
The only way to sort it properly is to dismantle and reassemble. Because it has sustained damage you will have to check for any internal damage caused by the drop. Now the lens is jammed open would suggest the guide pins have either come out of their slots preventing movement or something is obstructing them.
Jun 20, 2009 | Panasonic Lumix DMC-LZ7 Digital Camera
Camera will shut off then the shutter will close
Yes it could. It is possible a small dirt get on the side of the lense and it prevents the lense to close all the way in. Clean it up and while turning the camera off, push the lense in. Not too hard. You might have to repeat the step a few times. Do not drop your camera, if you did make sure you clean the sides of the popped off lense. If they did not help, some mechanical part of the lense is shifted or broken.
Good Luck
Jun 08, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
Lense Erroe 126,1,0,-7
if you know howto detatch the lense just clean it with pranella cotton with lense cleaner!!!!!!! if it not work just go to the service station near you>>>. god bless you
Apr 05, 2009 | Kodak Easyshare C813 Digital Camera
I dropped my Nikon L18 and it now says lens error when I turn it on. And the lens wont go back in.
you jammed the lense neds to be taken to a camera repair person It needs a new lense assmbly .
Jan 01, 2009 | Nikon COOLPIX L18 Digital Camera
Jammed lense
Same, one day i was just taking a photo and the lens jammed.
I took the camera from the place i bought it and asked for it to be repaired ( warranty repair) it took them 3 months to repair it. Now when i got it back the SD card won't fit in. l am demanding for a new camera.
Best get it repaired. Thanx Devin
Mar 04, 2008 | Samsung Digimax S500 Digital Camera
Dropped camera now it will not power up or anything battery is charged
You probably blew a fuse. Maybe the lens jammed and the motor could not overcome the jam so it shut itself down to protect itself. I dropped my first camera, under AMEX warranty and it came back with 3 fuses repaired, no physical damage-just wouldnt turn on.
Feb 22, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Jammed Lense)
Make sure the lense is not bent. If so, gently straighten it. This worked with mine.
Nov 28, 2007 | HP Photosmart R717 Digital Camera
Cameras Logo
229 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
