Question about Dell Latitude CpX Laptop PIII 500 Mhz 13.3" TFT 10 GB HD 128 MB RAM CD Floppy 56K Modem Internet and... (DCPX500CD) PC Notebook
Can't start windows
When I start my computer, it says
"Primary hard disk drive 0 not found"
"No bootable device selected"
"strike F1 to retry boot, F2 for setup utility"
It actually booted to windows before but suddenly now it doens't work
  • fmfranchise Aug 18, 2008
    It stopped working yersterday. In the bios it says none for primary hard drive. Can this mean my hard drive crashed? What do I have to change in bios?
  • Anonymous Mar 19, 2014
    Apparently I need to replace my hard drive. How I can do it?
  • 35 Answers
The issue you are having is that your computer is not seeing the harddrive or the boot drive. This could be a simple fix from the bios by telling the computer what device it needs to boot from which in this case is your hard drive.
You say that it did work and it was working how long ago was that? It also could be more serious in which you hard drive has crashed or exceeded its MTBF (which means "mean time before failure").
Posted on Aug 17, 2008
No bootable device detected
If you strike F1, the system retries as said in the comment. That does'nt solve anything. Rather strike F2 which allows to enter the setup menus of your computer.
In this area you should understand what you are doing. Any update of setupdata may prevent further restart. At least take note of values and changes. You exit setup via a question "update Y/N". Then the computer restarts.
Anyway, in the setup menu you may inspect the devices and see if you the system identifies the disk. If not it may come from a bad connection of hard disk (sata pins, ...) or from low level disk information (format information).
With setup menu you may get in the boot order menu, that allows for the selection of an alternate boot media. You may boot on an installation media, ( install DVD generally, like originall windows install DVD) in order to understand and repair the situation, or from a rescue system like UBCD. You may also try Ubuntu from the CD without installing, just to verify if you may see the disk in the configuration.
Regards
Jul 09, 2014 | HP Computers & Internet
My Laptop is Dell Latitude D600 (A16) Everytime I tried to power up, Splash screen appears with blue bar and when going into next screen this message appears " No bootable devices--strike F1 to retry...
Check your BIOS, by pressing F2 and see if the hard drive is recognized. It should indicate the MFR next to the hard drive listing. If it's not there, then you might have a bad hard drive. If it is there, try re-installing the operating system with the set-up disk. You can also go to the Dell website, enter you service tag number, and get technical support for your particular laptop. It might have a recovery partition in the hard drive to recover to factory settings.
Oct 26, 2010 | Dell Latitude D600 Notebook
When i turn on the laptop computer, a message appears: primary hard disk drive not found, fixed optical drive not found. No bootable devices: strike F1 to retry boot;F2 for set up utility. I tried but...
Your BIOS is looking for a drive to "boot" from and does not see your harddrive or CD-rom.
You may have a harddrive failure or bad drive controller.
One way to see is to load your operating system disc in your CD-rom and see if the computer sees the drive and boots up. If it boots, try to locate your "C" drive. If you can't locate the harddrive, it's a good bet it's damaged.
If the CD-rom doesn't boot, it is most likely a bad drive controller or cable.
Dec 30, 2009 | Computers & Internet
Primary disk drive not found
Check the connection of your hard drive and make sure it's plugged properly On The Motherboard.
Is this a SATA drive? Has it ever operated properly? If worse comes to worse, you'll have to reload windows from scratch.
Nov 11, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
No bootable devices-strike F1 to retry boot,F2 for setup utillity
Is there a hard disk installed inside the computer? try reconnecting it.
The motherboard, the hard drive, or the connector could be faulty in this case.
Remember to unplug and remove battery if you open the laptop, the hard drive is in most cases in the bottom under a cover with few screws or in some dells its on the side with few screws and comes out from the side instead from the bottom.
May 22, 2009 | Dell Latitude C600 Notebook
No boot device available
Make sure all the connections to the Hard Drive are tight and secure. Then see if it will boot. If not then try loading a windows cd and see if it detects the Hard drive. If it does not the hard drive is no good if it does try running the automated system recovery you may have a corrupt MBR file.
Dec 22, 2008 | Dell Dimension 4400 PC Desktop
The first thing to try is removing and reseating the hard drive. Sometimes the drive just looses it's connection with the motherboard, reseating can resolve that.
If that doesn't work, you can get a 2.5 in USB hard drive enclosure, and see if you can read the drive in another system, and recover you files that way.
Most likely though is the hard drive has failed. If this has occurred, then your options are limited. You can contact a data recovery service, but that is expensive. Http://www.ontrack.com or http://www.drivesavers.com are a couple options. You can contact them and get an estimate of the cost if the other options do not work.
Jun 08, 2008 | Dell Inspiron 6400 Notebook
Dell latitude c640. comes up with error immediately after ram check displays... "primary hard disk drive 0 not found no boot device available - no bootable devices--strike F1 to retry boot, F2...
Seems to be a problem while detecting the hard disk. Please contact customer service if the laptop is in warranty.
Let me know what happens.
Apr 30, 2008 | Computers & Internet
I am using the dell system at XPS710 and i kept getting the bios error:
I tried to hit F1, then i get that message again. I hit F2, then it i didn't see the problem.
PLEASE HELP! 16x16_smiley-mad.gif No ignores!
Apr 27, 2008 | Dell Latitude C640 Notebook
Dell Latitude CpX Laptop PIII 500 Mhz 13.3" TFT 10 GB HD 128 MB RAM CD Floppy 56K Modem Internet and... (DCPX500CD) PC Notebook Logo
252 people viewed this question
Alun Cox
