Question about Fujitsu fi-5650C Path-Through Scanner
We have a Fujitsu FI-5650 that is omitting parts of colors from the scanned documents. If a solde yellow document is scanned, it will leave our vertical bands of the color. We are thinking it is possibly the scanner assembly
SOURCE:
SOURCE: how to scanning double sided document in fujitsu 5120c scanner
You may want to try using Laser Fiche. This scanning software allows you to select "Duplex" which allows you to scan double sided document
Posted on Nov 29, 2007
mohanchennai
  • 490 Answers
SOURCE: scanner inserts vertical line on some documents
Clean the glass with IsoPropyl Alcohol. Dont use any other solvent. A speck of dust stuck to the glass can give a continuous line in the output
S. Mohan
Posted on Mar 18, 2008
shaggyrat
  • 1224 Answers
SOURCE: scanning document
i had the same thing happen to me i went threw every thing and cleaned and still was there i came to realize that it wasnt the scanner but the software pdf that was being used the seriously took me by surprise so i went out and installed a fresh copy of pdf writer this resolved my problem with the pink markings
i hope this was of some use
Posted on May 26, 2008
  • 15 Answers
SOURCE: fi=5120c conflict with another scanner
Check in the order as i had written.
1. Is both the scanners are connected in usb, then this problem will arise. Connect fujistu in scsi and check it. And connect only the cannon and check. because there is a chance of usb port or usb cable problem.
2. Then it depends up on the driver you are selecting. whether you may be selecting fujitsu and giving scan .
3. Check is the driver for cannon is properly installed and also have a check in the device manager is there is any question mark is showing in the driver for particular scanner.
4. If you are using any certain application like scandall application you can select the scanner whichyou want it to scan by selecting the SELECT SCANNER.
5. Is your driver is a new version. If new version is available then update the driver and check it out.
If you have any other problem you can contact me .Regd. the fujistu i can help you.
My mail id is : [email protected].
Posted on Nov 11, 2008
dragon_sun25
  • 107 Answers
SOURCE: Will the Fujitsu ScanSnap FI-4110EOX2 scanner work with Vista
Vista is not listed as a supported os.
Posted on Dec 10, 2008
5650c not scanned. making paper jam. rollers replaced. making big noise.document page stop halfway through
PDF]fi-5650C Image Scanner Operator's Guide P3PC ... - Fujitsu
www.fujitsu.com/downloads/.../scanners/.../fi-5650c_ops-guide.pd...
FujitsuThank you for purchasing the fi-5650C fi-5650C duplex color scanner product. ... 6.1 Removing jammed documents ..... store where you purchased the scanner or an authorized FUJITSU Image Scanner service provider to make repairs to this .... It is adjusted to the width of the paper in order not to scanned skewed pages. 5.
Okidata User's Guide OKIFAX 5650 Error Messagesmy.okidata.com/man-OF5650.../006B738F6240C3BF8525678500678C...Make sure a new drum is available, and replace the drum ... to be faxed or scanned hasjammed in the scanner. Refer to the "Problem Solving, Clearing aTroubleshooting - Oki Printing Solutions in New Zealandwww.oki.co.nz/support/printer/.../index.aspxOki Electric Industry... MB491 ES4191. FAQ: Paper Jam Clearing MB451 MB471 MB491 ES4191 ...MC361 MC362 MC561 MC562 How to setup scan to email. Open the attached ..... Can I disable Colour Copying and make only B+W Copying available? No, it not possible to disable Color Mode when copying via the Scanner Operator Panel.
Jan 29, 2016 | Office Equipment & Supplies
Fujitu FI 6670 service manual
Fujitsu has documentation for all of their products on their website.
Here is a list of all the scanner docs:
http://www.fujitsu.com/us/services/computing/peripherals/scanners/support/docs.html
For the FI-6670 they link to 3 different documents:
Datasheet [587KB]
Getting Started Guide [1.39MB]
Operator's Guide [12.7MB]
Jan 31, 2014 | Fujitsu fi Office Equipment & Supplies
Fujitsu fi-5650C Error U1
Hello Ismail,
Error U1 referes to Frequent paper jam in Fujitsu fi-5650c scanner. In order to troubleshoot your scanner issue, you are advised to follow the steps provided below:
1. Do the documents satisfy the paper specification?
2. Have the documents been prepared properly?
- Align the edge of documents for stable paper feeding.
- Remove documents with creases or dog-ear corners.
- Scanning different widths documents may cause skew and result in paper jam.
3. Is the imprinter EXT cable connected to the scanner properly? (only when the imprinter is installed)
4. Clean the Pick roller, the Separation roller, the Brake roller and the Chute roller and see if the error is resolved.
5. Clean the Feed rollers and the Plastic rollers and see if the error is resolved.
6. Replace the Pick roller, the Brake roller and the Chute roller, and see if the error is resolved.
- Check the consumable counter in the software operation panel. When the counter exceeds the values, replace the Pick roller or the Brake roller.
If the above steps do not help, then yuo are recommended to contact the nearest Fujitsu service center for assistance.
Thanks & regads,
ScanCare
Dec 16, 2013 | Fujitsu fi-5750C Flatbed Scanner
After scanning several pages, I don't know how to save it as one file.
After you scan the first page, click on add another page or add more, or ahatever your particular program asks for to add another page. When you save as, the pages will all be in one document. If you scan each page, individually as a separate document, they will be just that, separate documents.
Jan 17, 2013 | Fujitsu fi-6130z - Document scanner -...
Hello, I work for a doctor's office and we scan a lot of documents. Lately we are getting a code ds42003 on a fijitsu scanner, what should i do this code is on the fi-4010cu, we also have a fi-5120c...
it is logical that in an office where document scanning is important and vital, you would call in the service technicians to fix it so that the interruption is minimal
Nov 28, 2017 | Fujitsu fi-5120C
Fujitsu fi-4530C
Hi
F at power on is a ROM Error. sounds like a main board issue. check for dry joints, but may need the whole board replacing.
Sep 04, 2008 | Fujitsu fi-4530C Pass-Through Scanner
Scanning document
Apr 24, 2008 | Fujitsu fi-5120C
DR 2050C
This has something to do the brightness chosen. In the manual mode, if you choose a dark output, the output will have tis area also; if you choose, lighter output, it will omit. In the auto scan mode, the scanner decides what is the best output.
S. Mohan
Dec 19, 2007 | Canon DR-2050C Path-Through Scanner
How to scanning double sided document in fujitsu 5120c scanner
Oct 23, 2007 | Fujitsu fi-5120C
Fi-4990c problems- front optical sensor
fi-41990 scanner cleans after scanning 100,000 sheet for paper roller the pad cleans after scanning 100,000 sheets feeding path cleans after 200,000 sheets http://www.fujitsu-europe.com/support/scanner/manuals/consumable-option_3-5-8.pdf
Aug 09, 2007 | Fujitsu fi-4990C Path-Through Scanner
Fujitsu fi-5650C Path-Through Scanner Logo
Top Fujitsu Office Equipment & Supplies Experts
Smidler
Level 1 Expert
Vincent G
Vincent G
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
