Question about RCA Lyra RD2762 MP3 Player
FILE SYSTEM CORRUPTED MESSAGE
WHEN I TURN ON MY MP3 IT SAYS LODING AND THEN GOSE TO A SCREEN THAT SAYS FILE SYSTEM CORRUPTED. WHAT DO I DO TO FIX IT OR CAN IT BE FIXED??
  • sundaisy Aug 28, 2008
    When I cut my mp3 player on it Will come up RCA then it saids that it is loading after that it shows up a file system corrupted error & then it cuts off
Go to http://www.rca.com/digitalaudiodownloads/ and select your mp3 model and update the firmware.
Posted on Jan 07, 2009
I've been adding music to my mp3 and one day I used a different site to add music, so ever since that day I couldn't turn on my mp3 player. It turns on to the "go gear vibe" screen then...
Hi theondraw,
I see that you mp3 will not work now after adding Audio from a different site.
It is possible that the format of your mp3 was compromised or shall I say corrupted, that only way is to format the mp3 again and start a fresh audio list all file on your mp3 could be corrupt now.
Reformat your mp3 and try adding audio using only application or program, mp3 players have specific formatting when adding audio and form other site it may be different and could damage the file system.
Waiting for 4 day will really not work that will just let the unit stay rested and not do any fix, Reformat the Unit add Add Audio an try it again, just an advise use only one program/application when adding audio on your mp3 to prevent file corruption.
Have a nice day.
Thank you for choosing Fixya,
mvincentc
Jul 17, 2011 | Philips GoGear ViBE Digital Media Player
File system error: FAT is corrupted
Your hard disk on your media player is corrupted which also does happen on a normal PC/Laptop. To fix it, use windows explorer -> right click on your mouse againt the media player drive -> select properties -> select 'Tools' tab -> select Error checking / Check now -> Tick on 'automatically fix file system errors and recommended also 'scan for and attempt recovery of bad sectors' -> Start.
At this point, you may also need to restart your PC/LAPTOP and then be patient as 120GB is a fairly large drive to repair! Once the FAT has been repaired, depending on the corruptions, you may need to replace some songs, video, photos or other files.
ps. the other 'drastic' option is of course to reformat the whole Media driver drive !!!
Dec 18, 2009 | Archos 5 MP3 Player
Mp3 wont work
If the file system is corrupted, you have put files into the wrong folders.
To fix it, simply copy over all of your files from the mp3 player to your computer, format the mp3 player, then synch the files back onto it.
Oct 14, 2009 | RCA Lyra RD2763 MP3 Player
Startup says file system error
Reset it. Its not good getting that message. It probably means hard drive is corrupted!
Jul 06, 2009 | Philips GoGear HDD1830 MP3 Player
The screen say file system error then turn off
This error message means that the system is corrupted. You need to bring it to the manufacturer for reprogram and for firmware upgrade.
Have a great day!
May 13, 2009 | Philips GOGEAR SA6045 MP3 Player
Rca 2763 fm corrupted file message screen
Ahhh -"file system corrupted" - definitely need a firmware upgrade. If none is available, uninstall and reinstall your player and all software completely.
Jun 18, 2008 | Audio Players & Recorders
..file system corrupted...
if you specify "corrupted" then i may be able to help what exactly happened?
Mar 01, 2008 | RCA Lyra RD2765 MP3 Player
System file corrupted
I actually fixed this!!! Mine had been giving me the "file system corrupted" error. So, I opened it up (unscrew the screw on the back, pry the back cover off with a small flat head screwdriver or a key, etc.) and saw that the connector between the CF drive and the motherboard had come apart.
I re-inserted the cable into the groove of the connector on the motherboard, pushed the broken/separated piece of plastic that serves as a retainer for the cable back down, held it in place, and taped it down with a 1/4 inch wide strip of duct tape (taped all the way around the connector/cable to help keep it in). I put the Lyra back together and then turned it on... and it WORKED! It came right on into the normal menu! Yay!
Good luck other people, I hope that this is the same thing that happened to your player and that you can also fix it! =)
Nov 30, 2007 | RCA Lyra RD2763 MP3 Player
RCA LYRA RD2762B (4 GB ) MP3 Player
I had same issue and found a law office that filed a class action against RCA/Thompson. Here is the result:
Thank you for contacting David P. Meyer & Associates Co., LPA about the action our law firm filed against Thomson regarding RCA mp3 players. The matter was settled on behalf of the individual Plaintiff and the lawsuit was dismissed on October 10, 2007.
If you have a hard disk drive player that is experiencing a file error corrupt or similar error and you meet certain requirements, you may be entitled to a replacement unit at no cost to you. You must contact Thomson at 1-800-587-5518 no later than December 31, 2007.
Best Regards,
Shelly Coffman
Claims Investigator
1320 Dublin Road, Suite 100
Columbus, Ohio 43215
Direct Dial: 614-384-7030
Toll Free: 1-866-827-6537
Fax: (614) 224-6066
E-Mail: shelly@dmlaws.com
Website: www.dmlaws.com
Sep 30, 2007 | RCA Lyra RD2762 MP3 Player
RCA Lyra RD2762 MP3 Player Logo
155 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
