Timer knob old inglis washer won't pull off - Washing Machines
  • 26 Answers
In order to take the knob off first you look behind the timer and in the center there's a white or clear piece of plastic while looking horizontaly at it you will see a space in it like a tab. Get a pair of needlenose pliers and insert it into the hole and be GENTAL you want to pull up or away from the device while at the same time pulling on the knob. If you do this correctly the knob will come off but theirs two more pieces to take off. After the knob is taken off theirs like a round plastic shield that should pop off using your hand then theirs the indicator after that you should use a screw driver a flat head and try to center the screw driver in the center of the piece ( the piece will flex so dont be scared of that but be GENTAL)and be GENTAL but firm when you push down on the screw driver so you lift the piece off the center post and now everyting is free and the timer can be removed from the washer.
This Is for Timer Part #3955765 for WhirlPool Washers.
Hope this helped anyone who found this info useful.
Posted on Feb 25, 2009
I have to replace the timer knob on my whirlpool LTE5243DQ3 combination washer and dryer,but I cannot remove the old one
oh boy these are varied in the way to remove them, but usually under the knob is a pin, or screw and in some cases a u shaped plastic pc that locks timer to knob shaft? in some cases on the back side the shaft has to be pulled up then remove the locking pin or u shape piece to release it and wow it comes off
Aug 19, 2014 | Whirlpool 27 " White Combination Washer...
How to replace timer knob on Maytag PAV 2300 aww, old one snapped off leaving just the stem
This is from another site but does a good job of explaining how to change your timer:
http://www.the-appliance-clinic.com/myttimer.html
The hardest part will be swapping the knob because you have to lift the top of it off and sometimes they can be fiesty.
WORDS OF CAUTION.
DO NOT pull all the wires off of the OLD timer. DO a ONE for ONE wire swap. i.e pull one wire from the old timer... and hook it up to the new one on the exact same terminal as the old timer.
Kelly
Mar 22, 2011 | Maytag PAV2300 Top Load Washer
Spin cycle is hit and miss,
It could be the timer but don't rule out a loose lid switch. You have to remove the knob to get the timer off. To do so you have to pull the retaining rod out a bitdd8bcfd.jpg
To get inside the controls
Apr 19, 2010 | Whirlpool Inglis IP4400 Washer
I have a new timer to replace a broken one and I can't get the of
THE TIMER KNOB CAP REMOVES AND THIRS A CLIP UNDER IT REMOVE CLIP KNOB WILL PULL OFF YOUR SEE A SCREW OR 2 REMOVE TIMER MAKE SURE THE WASHER IS UNPLUG FIRST REMOVE BACK PANEL
Apr 03, 2010 | Maytag LAT3600A Top Load Washer
Kenmore Washer, Loose Timer Knob
There should be a spring clip that holds the timer knob on. It or the timer knob may need replaced. Here is a picture of the timer knob and the spring clip. Sure hope this helps and best wishes.
Jul 23, 2009 | GE WBSR3140DW Top Load Washer
Needing to take off old timer knob and replace with new one
We found this on another web site:
This was super easy. If you can screw and unscrew a nut from a bolt, its that easy.
The Knob assembaly comes as a whole. So once you remove the old knob (unscrew to the Left).
Then replace the new knob assy (screw to the Right) till its a snug fit. As you will see this knob is designed to be a clockwise rotation only - normal operation - sort of a self tightening screw.
May 18, 2009 | Frigidaire Washing Machine Timer Knob -...
Timer Knob
The clip pulls straight up off the shaft directly behind the knob. You can use a small screwdriver or a pair of needlenose pliers to pull it out. Once the clip is removed the knob will slide off the timer shaft.
Apr 21, 2008 | GE WDSR2080D Top Load Washer
GE washer timer knob
I can not set the timer on my GE washer. The knob just turns with out stopping.
Mar 04, 2008 | GE WDSR2080D Top Load Washer
RRemoving the washer starter dial
Yes, stop pulling on it. Axcess the rear of the timer there will be a smaller hole with a black piece of plastic inside where the knob shaft would be if it went all the way through. use needle nose pliers to grab the plastic piece and pull out. it is easier if the knob is pushed in is gets recessed a little more when you pull out the knob. The new timer comes with a new plastic piec pull it out then push back in to lock on the knob again.
Nov 23, 2007 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
421 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
