Question about Car Audio & Video
I cant play dvds with out the parking brake on but i have my jensen in my house right now so how do i get the override code to come up
  • 1,586 Answers
I don't know where everyone keeps coming up with the idea that there's a code you can enter to defeat this lockout.
DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On my Jensen, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done.
Posted on Aug 18, 2008
Brake override Jensen vm9212
Are they "burned" DVDs? The brake override will only allow video to come through the screen it won't make the unit not read them.
Mar 01, 2010 | Jensen VM9510 Car DVD Player
Cant play dvd when driving on my jenson VM9312
That is due to the parking brake sensor on most DVD players. Since it is higly illegal to play DVDs while driving, as it provides a distraction to the driver, it is frowned upon. However, you can simply ground the parking brake sensor wire, and that should fix the issue of it not playing when driving. Please remember that it is most likely illegal, though.
Oct 26, 2009 | Car Audio & Video
PARKING BRAKE DISABLE my jensen in dash doesnt want to play dvds its displays a blue screen saying something about the breaks
yes its saying in toorder to play dvd's u must engage parking brake which means the wire is suppose to be hooked up to the parking brake....BUT i know the trick to make it work where u can play dvd's and drive
May 31, 2009 | Audiovox Jensen In-Dash DVD/CD Receiver w/...
How to bypass the parking brake switch for an 06 jensen VM9411
Here is the solution
1/ insert the dvd movie
2/After the disc loads and plays you will seea blue screen telling you "it is unlawful to drive with a movie bla bla bla"
3/Activate the brake sequence and disable the blue screen using the hand brake,the switch method or anything else to give the unit its 3 pulses to disable that freakin blue scrreen.
4/Next,on the main remote press stop twice,then 1,2,6,4.
5/You will now see a hidden menu that says.
Region Code
Brake Override(I know you are droling by now)
Macrovision(Watch all the burned and pirates you want if this option is off)
Loader Version
Model Version
6/Using the right joystick on the unit,navigate to the options of your choice,click on them to toggle
on ,off or witch region code you want.
7/This is what you want.
Region code 1
Brake override ON
Macrovision OFF
When your done,click SYS SETUP on the remote TWICE to save the settings and vingo.
Mar 09, 2009 | Jensen VM9510 Car DVD Player
Parking brake on a phase linear uv8
pulll the unit out there will be a wire marked park brake or most likly pink (remeber coming from the head unit ) next splice it in to the black wire or to a ground
Jan 30, 2009 | Jensen VM9411 Car Video Player
Need bypass code for Jensen VM9311TS
Here it is how brother,insert a dvd movie,next use the toggle switch sequence to get image,next press stop button twice on the remote,then press 1 2 6 4 on the remote,you will now see a menu that says
Regon Code
Brake Override(I know you are drooling by now)
Macrovision
Loader Version
Model Version
Using the right joystick on the unit,navigate to the options of your choice,click on them to toggle on,off or which region code you want.
This wht you want.
Region Code 1
Brake Override ON
Macrovision OFF
When you are done,click SYS SETUP on the main remote TWICE to save the settings and vingo.
Nov 22, 2008 | Jensen VM9510 Car DVD Player
Place the pink wire to a ground. Hope this works for you.
Jun 01, 2008 | Jensen VM9410 Car DVD Player
JENSON VM9512 CODES FOR BRAKE BYPASS
turn on the player, start the radio option, go into the setup menu, tap the language tab, ON THE REMOTE press "stop, stop, 5,4,3,2,1" This will bring up the secret menu, you do not need to connect the pink wire
Mar 10, 2008 | Audiovox VM9512 Car DVD Player
Bypass the parking brake for vm9412 jensen
Hit Setup On Remote.
Select Language.
Get Remote And Hit 5,4,3,2,1,0.
Listen For Beeps. Touch “Hammer/Screwdriver” Logo.
Select Brake Override
Switch To Brake Override “ON”
Now Hit Setup On Remote.
this works thank you for posting this.
derek
Dec 25, 2007 | Jensen VM9510 Car DVD Player
Linear uv7
here's the code. I did this with my remote and it works.
press stop twice(which is also the band button)
press1,2,6,4
press down 1 time(button below the play/enter)
press play/enter 1 time
(you should see the menu now)
brake override should say no
I was told to change macrovision to no
hit system setup twice to save and exit
hope it works like mine did
Dec 07, 2007 | Phase Linear 160W AM/FM/CD Receiver W/...
Car Audio & Video Logo
96 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
