Cars & Trucks Logo
Posted on Jun 03, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why does its wheel turns to the left when i step on the gasoline?
Joseph Clark
Level 2:
Scholar:
  • Expert 95 Answers
  • Posted on Jun 03, 2011
Joseph Clark
Expert
Level 2:
Scholar:
Answers
95
Questions
0
Helped
28813
Points
290
This is called Torque Steer. It happens when more power is transferred to one wheel versus the other in Front Wheel Drive Cars.
Just keep both hands on the wheel and drive straight, you will be fine!
If the Torque Steer is too noticeable, and hard to control, you may have an issue where you're getting almost no power to your left wheel. Have a transmission mechanic take a look at it then as your Trans-axle may be in disrepair.
Anonymous
Level 3:
  • Master 4,399 Answers
Anonymous
Master
Level 3:
Answers
4399
Questions
Helped
876516
Points
13003
Thanks for choosing FixYa and welcome. This means your car is out of alignment. You need to make sure all the tires are the same weight. If they are, they may need balanced. Usually, it will pull the same direction as which tires are low. Check the left side tires, front and back.
What kind of transmission ssangyong musso 2001
2.3 Gasoline: All wheel drive, manual 5 speed
3.2V6 gasoline, AWD, automatic 4 speed
2.3 TD All wheel drive, manual 5 speed
2.9 TD All wheel drive, manual 5 speed
How do i unlock my steering wheel on my 2005 Ford 500
Try stepping on the break and turning the wheel to the left or right while trying to turn the ignition, I know it is locked but if u turn it hard as ur trying to turn the ignition switch it will let go
1992 GMC sierra two wheel drive 4.3l V6 Have a vibration or rubbing noise when I turn the steering wheel sharply to the left at parking lot speeds.
If you let go of steering wheel and step on brakes does the wheel vibrate?
I'd say its either warped rotors, power steering malfunction, or possible wheel bearing, although if wheel bearing you should feel/hear a hum which would get louder depending on which way you turn the vehicle.
1999 xjr outside gasoline smell
A rusted out fuel tube on top of fuel tank,
rotted & leaking hose or bad Evap System
Solenoid
If you smell it,it is leaking,fuel or fumes
C70 not starting
If it cranks and engine turns you have electricity and no gasoline going to the engine.If no crank and no electricity check battery first for electrical power or follow the positive red wire to the starter and check the little red wire on top of the starters solenoid which is the part that is attached right on top of the battery and see if its touching or loose or cut. The battery starts the starter, the starter turns the fly wheel, the ignition gives spark in the combustion chamber with compressed air and gasoline that goes by the lifters intake and exhaust valve. If you have electricity please take off the fuel pump relay to an auto mechanic which is located in the main fuse compartment to check if its faulty and if it's not then you have no electricity going to the fuel pump or the fuel filter is clogged or fuel injectors have problems. My suggestion is that you take it to a mechanic auto shop for a base check and after they fix it you can buy yourself a Chilton's repair manual to learn how your vehicle functions step by step by the letter and how to be able to troubleshoot your own vehicle when problems like this arise!
2answers
Makes noise when i turn left and right
depending on what type of noise, wors't case it could be bad cv joints. Try turning the wheel all the way left and step on the gas to see if the noise is there, then try right turn.
4helpful
What do the symbols on the fuse guide stand for?
Fuse Locations & Functions
1. Washer nozzle heaters, glove compartment light (10A).
2. Turn signal lights (10A).
3. Fog light relay, instrument panel light dimmer switch (5A).
4. License plate light (5A).
5. Comfort system, cruise control, A/C, steering wheel module (7.5A).
6. Central locking system (5A).
7. Back-up lights, speedometer vehicle speed sensor (VSS) (10A).
8. Open
9. Anti-lock brake system (ABS) (5A).
10. Engine control module (ECM): gasoline engine (10A)
11. Instrument cluster, shift lock solenoid (5A).
12. Data Link Connector (DLC) power supply (7.5A).
13. Brake tail lights (10A).
14. Interior lights, central locking system (10A).
15. Instrument cluster, transmission control module (TCM) (5A).
16. A/C clutch, after-run coolant pump (10A).
17. Open.
18. Headlight high beam, right (10A).
19. Headlight high beam, left (10A).
20. Headlight low beam, right (15A).
21. Headlight low beam, left (15A).
22. Parking lights right, side marker right (5A).
23. Parking lights left, side marker left (5A).
24. Windshield washer pump, windshield wiper motor (20A).
25. Fresh air blower, A/C (25A).
26. Rear window defogger (25A).
27. Motor for rear windshield wiper (15A). (if equipped)
28. Fuel pump (FP) (15A).
29. Engine control module (ECM) gasoline engine (15A)
30. Power sunroof control module (20A).
31. Transmission control module (TCM) (20A).
32. Injectors: gasoline engine (10A)
33. Headlight washer system (20A).
34. Engine control elements (10A).
35. 12 V power outlet (in luggage compartment) (30A).
36. Fog lights (15A). (if equipped)
37. Terminal (86S) on radio, Instrument cluster (10A).
38. Central locking system (w/ power windows), Trunk light, fuel door, Trunk lid (15A).
39. Emergency flashers (15A).
40. Dual tone horn (20A).
41. Cigarette lighter (15A).
42. Radio (25A).
43. Engine control elements (10A).
44. Heated seats (15A). (if equipped)
Fuse arrangements in fuse bracket/battery:
S162. Glow plugs (coolant) (50A).
S163. Fuel pump (FP) relay/glow plug relay (50A).
S164. Coolant fan control (FC) control module/coolant fan (40A).
S176. Relays panel interior (110A).
S177. Generator (GEN) (90 Amp.) (110A). Generator (GEN) (120 Amp.) (150A).
S178. ABS (hydraulic pump) (30A).
S179. ABS (30A).
S180. Coolant fan (30A).
Cigarette lighter fuse
Here is the fuse relay diagram:
MKIV FUSE LIST
1. Washer nozzle heaters, glove compartment light, memory seat control module (10A).
5. Comfort system, cruise control, Climatronic, A/C, heated seat control modules, automatic day/night interior mirror, control module for multi-function steering wheel, control unit in steering wheel (7.5A).
8. Open
10. Engine control module (ECM): gasoline engine (10A); diesel engine, Model Year 2000 > (5A).
17. Open.
24. Windshield and rear window washer pump, windshield wiper motor (20A).
25. Fresh air blower, Climatronic, A/C (25A).
29. Engine control module (ECM) gasoline engine (15A); diesel engine (10A).
32. Injectors: gasoline engine (10A); diesel engine (15A).
38. Central locking system (with power windows), luggage compartment light, remote/fuel tank door, motor to unlock rear lid (15A).
42. Radio (25A).
Fuse arangements in fuse bracket/battery:
S179. ABS (30A).
S180. Coolant fan (30A). Source(s): http://forums.tdiclub.com/showthread.php?t=122606 fame !
2helpful
2answers
2003 Volkswagen Golf Problem
it should be number 42
MKIV FUSE LIST
8. Open
17. Open.
42. Radio (25A).
S179. ABS (30A).
Top Honda Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Honda Expert? Answer questions, earn points and help others
