Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
Panasonic PT-53TW53G When I turn my Tv on my power comes on for two, three seconds and then itcuts off. The power light blinks 3 times and pauses then blinks 3 times does this until   i unplug the tv. When I turn my Tv on my power comes on for two, three seconds and then it cuts off. The power light blinks 3 times and pauses then blinks 3 times does this until i unplug the tv.
  • 2 more comments
  • Anonymous Aug 19, 2008
    I have identical problem. Have had the TV for 4 years with no problems. Now all of a sudden as I went to turn it on it comes on for about a tenth of a second then goes off and then the LED light goes into a continuous series of three flashes, a brief pause three flashes.
  • Anonymous Nov 26, 2008
    tv does not turn on, on light blinks three times!
  • fantomaas
    fantomaas Dec 19, 2008
    I HAVE THE SAME PROBLEM !!! >>>>When I turn my Tv on my power comes on for two, three seconds and then it
    cuts off. The power light blinks 3 times and pauses then blinks 3 times does this until i unplug the tv. PEOPLE HELP US!!!!
  • Anonymous Feb 20, 2009
    I have the same problem....getting it checked out by a tv specialist...will let you know what i find out
  • Panasonic Master
  • 3,459 Answers
If the front power light is blinking three times then your TV has a problem with the convergence. You can get the correct replacement parts and full step by step photo instructions from www.TvRepairKits.com
Posted on Apr 18, 2010
What are the error codes for a Panasonic PT-47WX 42 TV
3 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Click Part Store to see an image of required chip and price info.
Local tv tech is recommended if you have no experience of working in tv circuit boards.
Thanks.
Apr 18, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-53TW53G 1 Blinking red light, will not stay on.
just got back today for same problem. convergence went out. took to repair shop. $200 part plus $60 labor. second time in a year convergence went out. was told it will happen again.
Mar 19, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic Pt-53TW53G projection tv
5 Blinks means IC4511 thats located on the DG board which is the small board on the left side in front of the signal board looking in from the rear of the set.
Oct 31, 2008 | Televison & Video
Tv trouble
djbone30, you need two STK392-110 convergence amplifiers.
Sep 25, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic 55" PT-53TW53G
Thats a strong possibility that the converegence feed resistors could be open. Also double check the wire connections especially the white bridge connectors that are from one board to the other. Also recheck the IC pins for any sign of bridged pins or inadequate solder.
Jul 08, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic TV not working
The Led should be blinking a certain number of blinks before pausing. IF so what is the number of blinks?
Mar 11, 2008 | Panasonic PT-53WX42 53" Rear Projection...
No Audio or Video, blinking power light
Did you ever find anything out about this? I have a pt-53tw53g with the exact same problem, and I've been unable to find out what the three flashes means.
Aug 02, 2006 | Panasonic PT-56TW53 56" Rear Projection...
Comes on for about 3 seconds and then shuts off!
I have the same problem: It seems the high voltage trasnformer blew which in turn casued the pin cushion?? to blow. It then shuts the tv off to prevent more damage to it. Gonna be about $500 with service charges to get it fixed!
Sep 09, 2005 | Panasonic PT-47WXC43 47" Rear Projection...
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
772 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
