How do I install ink cartridge into HP Photosmart Model C4280 all in one printer. I purchased the black and colored cartridges but can't seem to find any info on how to install.
  • 114 Answers
Step seven: Install the print cartridges
NOTE: The product must be on before you can insert the print cartridges.
  1. Open the print cartridge door. Figure 7: Opening the print cartridge door How do I install ink - c00880893.jpg
  2. Make sure the print carriage moves to the right. If it does not move to the right, turn the device off, then turn it back on again.
  3. Open the packaging and remove the tape from both cartridges. Figure 8: Removing the tape c00880894.jpg CAUTION: Do not touch the copper-colored contacts or re-tape the cartridges.
  4. Hold the cartridges with the HP logo on top.
  5. Insert tri-color cartridge in the left cartridge slot and the black cartridge in the right cartridge slot . Figure 9: Inserting the print cartridges c00880895.jpg
  6. Push the cartridge firmly into the slot until it snaps into place.
  7. Close the print cartridge door.
Posted on Aug 17, 2008
SOURCE:
New black very faint
1. hope you have not touched the contacts or head those protected by pink tape.
2. or the ink is dried up
Replacing Cartridge HP Photosmart C4280 All in One Printer
Apr 06, 2016 | HP Photosmart C4280 Aio Printer
Will lexmark 17 black inkt cartridge and a lexmark 27 color ink cartridge fit in a hp photosmart c4280 all in one printer and work properly?
Negative, but you may want to think about refilling your HP74/75 ink cartridges for your HP PS C4280 printer....it's actually quite affordable.
For additional information on North American ink refill services at a major retailer near you (should you wish to save ~50% on ink costs), general printing problem resolutions or advanced HP printer diagnosis procedures (error bypass/printer reset methods, etc.), please visit Inkjet411:
http://www.inkjet411.com
Jun 12, 2013 | Office Equipment & Supplies
HP Photosmart C4280 All-in-One printer, printing in only black blue and weird pinky red
Replace color ink cartridge ,black cartridge is not required because of black prints are ok..
Sep 04, 2012 | HP Photosmart C4280 All-in-One InkJet...
HOW DO I INSTALL THE INK CARTRIDGE IN PHOTOSMART C4280
Turn on power to printer, then lift the top half of Printer lid, the cart holder will move to centre, place printer cart in the holder rack, press firmly in place.
Jun 07, 2010 | HP PhotoSmart C4280 Laser Printer
My HP photosmart c4280 keeps aligning the cartridge when on!
probably the alignment its not succeed
be cause on of color is missing
check if you see and the 4 colors on paper (yellow cyan magenta black)
if one color is try cleaning , refilling or replacing the cartridge
if you need instructions for refilling check here
http://www.youtube.com/watch?v=Ybj4awp_1ic
May 01, 2010 | HP Photosmart C4240 All-In-One InkJet...
Replacing ink cartridge(s) in my HP Photosmart C4280 All-in-One
had the same problem
I just kept putting it in and taking it out until the msg stopped.
also sometimes when you see this msg you can push the ok button and the printer will go to correct mode.
May 27, 2009 | HP Photosmart C4280 All-in-One InkJet...
How do I install ink cartridge for hp photosmart C4280
To replace the print cartridges
1. Make sure the HP All-in-One is on.
CAUTION: If the HP All-in-One is off when you open the print cartridge door to
access the print cartridges, the HP All-in-One will not release the cartridges for
changing. You might damage the HP All-in-One if the print cartridges are not
docked safely when you try to remove them.
2. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
3. Open the print cartridge door.
The print carriage moves to the far right side of the HP All-in-One.
4. Wait until the print carriage is idle and silent, and then lightly press down on a print
cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the
slot on the left.
If you are replacing the black or photo print cartridge, remove the print cartridge from
the slot on the right.
1 Print cartridge slot for the tri-color print cartridge
2 Print cartridge slot for the black and photo print cartridges
5. Pull the print cartridge toward you out of its slot.
6. If you are removing the black print cartridge in order to install the photo print cartridge,store the black print cartridge in the print cartridge protector or an airtight plastic container.
7. Remove the new print cartridge from its packaging and, being careful to touch only
the black plastic, gently remove the plastic tape by using the pink pull tab.
1 Copper-colored contacts
2 Plastic tape with pink pull tab (must be removed before installing)
3 Ink nozzles under tape
CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching
these parts can result in clogs, ink failure, and bad electrical connections.
8. Slide the new print cartridge forward into the empty slot. Then gently push the upper
part of the print cartridge forward until it clicks into the socket.
If you are installing the tri-color print cartridge, slide it into the left slot.
If you are installing a black or photo print cartridge, slide it into the right slot.
Work with print cartridges 69
Maintain the HP All-in-One
9. Close the print cartridge door.
If you installed a new print cartridge, the HP All-in-One prints a print cartridge
alignment page.
10. When prompted, ensure plain white paper is loaded in the input tray, then press the
button next to OK.
NOTE: If you have colored paper loaded in the input tray when you align the print
cartridges, the alignment will fail. Load unused plain white paper into the input
tray, and then try the alignment again.
11. Place the page print side down on the scanner glass and then press the button next
to OK to scan the page.
When the On
Please Don't forget to rate this solution. Thanks.
Feb 17, 2009 | HP Photosmart C4280 Aio Printer
C4280 printer photo cartridge instalation help
The extra cartridge you bought was probably the number 99 cartridge, if I'm not mistaken.
The cartridge actually replaces your black cartridge. Inside of the cartridge has black ink as well as the special photo ink.
I hope this helps
-Ernest
Mar 07, 2008 | HP PhotoSmart C4280 Laser Printer
Open Questions:
154 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
