Air problem air don't blow out with force. Can't tell if it's cold or not
  • 182 Answers
Check your filter first.if its ok and the blower is running....check the outside unit for ice on the lines.lemme know what ya find.
Posted on Aug 18, 2008
2012 Alpine 3700re. Why is the rear air main air outlet not blowing forced air?
Assuming you are talking about some kind of central forced air and not a roof air conditioner, I would say the hose fell off the outlet or the A/C unit itself. Do all the other vents blow cold air? If yes, remove the wall vent and look. If the hose is attached, go to the A/C unit and check there. Also, remote possibility some kind of critter got inside the hose and built a home, effectively blocking the airflow.
Not enough info on filters. Central air filter? Roof A/C filter? Engine air filter?
Manufacturers put so many different models of sleeper sofas in RVs, it's hard to tell which one you have. Your owner's manual should tell you. If you don't have one, look around. There might be a latch(s) somewhere. Or try pulling up and out or straight up.
Jun 30, 2015 | RVs
Where is the heater control valve on a 2000 Lincoln town car?
you don't have one what is wrong ? no heat? no forceful air coming from the fan? cold air blowing heater functioning? temperature gauge reading very low and as you drive it drops to cold? you must tell me what is wrong and I'll be able to take it from there
Feb 14, 2015 | 2000 Lincoln Town Car
2002 Merc Sable wont blow air
I'd have to say it's the blower motor. Does it blow hot air when the heater is on?
Aug 07, 2012 | 2002 Mercury Sable
My freezer frosted over everything because the door was not shut tight and now it will not clear.
take out all the food out of the freezer,unplug the fridge and get a hair dryer and start melting out all the ice in the freezer,then blow the hot air into the vent holes on the back wall until you don't see any more water dripping down through the slots in the back wall.turn the machine back on,open the fridge door after around 5 or 10 minutes and if you feel cold air blowing into the fridge you fixed the problem,if you don't feel cold air keep hitting the inside back wall with the hair dryer and keep blowing the hot air into the holes in the back wall.all that it does is the freezer gets cold and there's a fan behind the back wall in the freezer,the fan blows the cold air into the fridge side,if the air ducts are frozen the air can't circulate into the fridge section so you have to melt the ice out so the cold air can blow from the freezer to the fridge.good luck,if you have another fridge remove the food and unplug it and leave the doors open for a day and it will melt out.good luck
Jun 16, 2011 | Kenmore 65234 Bottom Freezer Refrigerator
The air conditioning system will only blow cold air. Regardless of the mode, I can only get cold air. Can you give me an idea on how to fix the problem? Thanks Don 615-653-3834 drcamp117@comcast.net
The air conditioning is supposed to blow only cold air. Are you trying to get the heater to blow hot air? Make sure the temperature selector is in the hot position.
Dec 19, 2010 | 2002 Buick LeSabre
My 1999 ford windstar is only blowing cold air and no heat
possable problems:
1. coolant leak (level too low to fill heater core)
2. headgasket leak forcing the coolant out of the overflow.
3. stuck thermostat.
4. bad water pump. if the impelers are broken, coolant wont flow.
5. HVAC malfunction. system may think you selected cold or is unable to move diverter. maybe a fuse,solenoid or vaccum leak? (hvac controler uses vaccume controled soleniods)
6. airlock. if you have resently changed your coolant, you may need to repeatedly squeeze the heater core hose to help force out the air.
May 19, 2010 | 1999 Ford Windstar
Reddy heater blows cold air
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Dec 30, 2008 | Reddy HEATER RLP100 100,000-BTU PORTABLE...
Heating & Cooling Logo
43 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
