Question about Linksys Wireless-G WRT54G Router
No conenction Connection light on linksys 2.4 router is yellow. Internet service works
  • 298 Answers
What is the name of the lights that is yellow? Most of the time the lights on the router is yellow or green.
Posted on Aug 18, 2008
Every so often, my internet seems to crash. On my pc it has a yellow caution sign over the internet. The data send/receive lights on my modem flash but the others don't when this happens. I try un
If it works sometimes ? when you unplug it then replugging it back in something is wrong with the modem / router or they might need to be reset .
or firmware upgrade
Reset linksy router b> One of the most common fixes for Internet connectivity often involves resetting the source of your Internet connection. If you have a DSL or cable Internet connection, you may use a Linksys router to get on the Internet. When you reset a Linksys router, you'll likely solve your connection problem.
Turn off the power to your computer's modem. Use the switch on your cable or DSL modem to disable it while you reset the Linksys router. Find the reset button your Linksys router. Most Linksys models have the reset option on the back of the router. Use a pointed pen or pencil to press in the reset button on your Linksys router. Hold down the reset button for approximately 30 seconds. Watch the lights on the front of the router. After you reset the router, power will get restored to the Linksys router. Once power's available, you can switch the modem back on. Reconfigure your router. After you reset your router, you'll have to log in and reconfigure your settings. The login name is typically left empty with your password as "admin."
Reset a Linksys Wireless Router b> You may need to reset your Linksys wireless router if you are having Internet connectivity issues or other networking problems. You can reset the router to the default factory settings, such as the default IP (Internet protocol) address, username and password. However, after you perform the factory reset, you can follow the initial setup instructions to replace your previous settings.
Write down any important settings you may have--such as the router's password--before you reset the router. Locate the reset button on the router. Some Linksys models have a reset button on the back side. Other Linksys models have a small pinhole you may need to access by using the tip of a pen or pencil. Press and hold the reset button for a minimum of 30 seconds to perform a factory reset on the Linksys router. The Linksys router should lose power. Power on the Linksys router to initiate the configuration wizard. Reconfigure any previous wireless settings on your Linksys router.
Hope this helps.
Dec 28, 2012 | Computers & Internet
Can't use home wifi on iphone
How many wired and wireless computers or devices do you have?
How many are conencted to the wireless network?
How many are actually able to access Internet through wireless connection?
If your wireelss network is secured then make sure that you have the correct wireless network key.
If nothing is working then I think you should try to reset and reconfigure Linksys router.
Create a new wireless network and then try to connect to the new wireless network
See Linkssy router setup
Jan 21, 2012 | Linksys Wireless-G WRT54G Router
My router is connected, but there is no internet connection.
Actually, Linksys WRT160N is meant to be used as a router not an access point. It can be but with at
Jul 26, 2011 | Linksys WRT160N Wireless Router
Wi-fi disconnection
you have two routers in one network this could be the conflict why your network needs to be restart everyday, onece the routers are not used and goes Idle it will have the internet from the modem go idle as well and since you have 2 routers it will have issue on keeping the internet connection running one of your two routers is possibly having conflicts in running the internet conenction once Idle try running your network using one router and monitor if there would be any progress in the internet for your restaurant. also try setting you routers chanel to 11 since this will be a public network ^_^.
Jun 20, 2010 | D-Link DIR-625 (790069292637) Wireless...
I am having problems setting up
Local acces only means that your conenction is ok justthat the network security on your router and laptop is not the same try removing the erouter security or try changing the security in your laptop to match what the router has .........
Jun 04, 2010 | Linksys Wireless-G WRT54GS Router...
Cannot get wirelss connection through my WRT160N wireless router. Was working and now not. I can get internet connection through the LAN ports so I know that the router is working with a fixed cable
by default ip address of linksys is
to star config you need to be connected with ethernet cord rj-45
or conenct via wireless by conencting to linksys on wireless
admin user: blank
admin pws: admin
*choose a protocol on your linksys router on internect conenction type:
check isp protocol :
dhcp: needs serail number of mac address
it picks up automatic
pppoe: needs username and pws from isp
*the ip address has to be diferent from the isp modem:
isp modem linksys incorrect
isp modem linksys correct
change the ip on lan settings on your router
*wireless: ssid by default is linksys
ssid: linksys
wep : none
to setup wireless
access the wireless basic
change the ssid to any network name
enable the wireless password
choose wireless security
enable wep key 10 digit hex pws
make shure you saved settings on every setting
May 04, 2010 | Linksys WRT160N Wireless Router
Yellow port
that port is given for IPTV. so that will different.
Feb 25, 2010 | Linksys WRT160N Wireless Router
Just set up my WRT160N Router and although it shows I have a full wireless connection, I can't open any web pages. Not sure what to do next. Went through the set up process and did everything to a tee....
Are you able to access internet when you are connected with a cable netween your laptop/desktop and router please check if yes then with the same connection go to default username admin and password "admin" and then check in the wireless tab is there any security on the wireless the same code needs to be entered on the laptop also in wirless network connections
Or the issue can be conenctivity between your service provider and router you may need to do some settings as per your service provider on the router for that again you need to open the 192.168.. page
let me know if this help, the below link will help you to check your connection once by one
Dec 01, 2009 | Linksys WRT160N Wireless Router
Linksys Wireless-G BroadBand Router
Who is your ISP (Internet Service Provider)?
If you're using a Cable provider, do the ff. steps. (For Linksys router)
1. Launch Internet Explorer and type
2. It will prompt you for username and password. Leave it blank on username and type admin for the password.
3. Under SETUP tab, click the sub-tab MAC Address Clone. The click the button Clone My PC's MAC. Then click on Save Settings.
4. Unplug the power to the modem and the router for 30 secs. After that, power on the modem first, wait for all lights to go solid then power on the router. Check if the internet works.
Hope this helps.
Jul 19, 2008 | Linksys Wireless-G Broadband Router
Router problem
The router may not be configured yet that's why you cannot connect to the Internet after connecting your computer to the router. You may click on these links for instructions on how to configure the router depending on the type of your Internet provider.
For DSL connection:
For Cable connection:
If the Internet connection still did not work, let me know of the following:
- Internet Service Provider
- model number of the router
- brand or model number of the modem
- operating system of the computer
May 15, 2008 | Computers & Internet
Linksys Wireless-G WRT54G Router Logo
333 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
