Question about Dell E172FP 17" LCD Flat Panel Monitor
Display dies 3 seconds aafter Power on
I have a E172FPb which when powered on the self test display is visable but then then the display dies but the green light on power siwtch stays on.
I would think it is a power supply problem but I have never looked at these units before.
Any ideas?
  • Anonymous Aug 18, 2008
    I'm having the exact same problem, however its a Dell E178FP. Straight out of the box, tried on two seperate computers with same results. I can turn computer on, and I will see 3 seconds of computer activity (boot up, sitting idle ect) then black screen with green power button still on. If I turn computer, power button goes orange. I can turn monitor off then on again and I will see 3 seconds of video, but then it goes black again. Just looking to see if anyone has a solution out here before I contact Dell.
Http://josepino.com/other_projects/?howto-repair-dell.jpc
This is one soution, many more on the net.
You got parts to fix inside the monitor. Inverter problems. The internet is full of this problem. Some say that even if you replace the bad parts, mostly 2sc5707 transistors, you must find out why they are blowing. Many have replaced the parts only to find out that in a couple hours, the parts are bad again. Solutions range from solder joints, transformers, and other transistors.
Good luck, I'm fixing one as soon as the parts arrive.
Gary
Posted on Dec 15, 2008
The adjust temp numbers on my GE side by side fridge went out
Try this 1. First make sure the machine is turned on and running, both fans and compressor should be running. 2.Then unplug the machine for minimum 2 minutes. 3.Restore power to the refrigerator and wait 2 minutes. 4.Control diagnostics test using the display does not use error codes to identify problems. Instead, the temperature display allows access to components or systems to be checked if a problem is detected. 5.The temperature display must be in an active mode before entering the self-diagnosis test. 6.If the display is blank, press any temperature button once, then release it. The display will show actual temperatures.7. Enter the diagnostic mode by pressing both the freezer temperature (COLDER and WARMER) pads and the refrigerator temperature (COLDER and WARMER) pads simultaneously. All four pads must be held for approximately 3 seconds. Blinking "00"s in both the freezer and refrigerator sections of the display indicates the refrigerator has entered the test mode. 8.Remove fingers within 5 seconds and press any pad to lock-in the test mode. The blinking "00"s will change over to solid (non-blinking) "0"s when the test mode is locked in Failure to lock-in the test mode within 30 seconds will time out the test and return the refrigerator to the normal cooling mode. 9.Use the temperature colder or warmer pads to enter 1 in the freezer display and 5 in the fresh food display and press any button. This will cause a system reset.10. Wait 30 seconds and try to adjust the temperatures again. If the problem still exists, remove the cover over the motherboard behind the machine.11. Measure the voltage between J4-2 and J4-3 You should have 12 VDC (do not disconnect the J4 connector).12.If the voltage is correct confirm the voltage on the display board J3-2 and J3-3 I 13.if the voltage is correct, replace the display board. If not replace the motherboard.
Aug 24, 2017 | GE Refrigerators
Tip
ERROR CODE AND SERVICE MODE
Service tool modeHow to access
1. Select [SRV-TOOL] in Service Mode.
2. Press [OK] button on the remote control.
Display of SOS History
SOS History (Number of LED blinking) indication. From left side; Last SOS, before Last, three occurrence before, 2nd occurrence after shipment, 1st occurrence after shipment.
This indication except 2nd and 1st occurrence after shipment will be cleared by [Self-check indication and forced to factory shipment setting].POWER ON TIME/COUNT
Note : To display TIME/COUNT menu, highlight position, then press MUTE for (3sec).
Time : Cumulative power on time, indicated hour : minute by decimal
Count : Number of ON times by decimal
Note : This indication will not be cleared by either of the self-checks or any other command.Exit
1. Disconnect the AC cord from wall outlet.
Hotel mode
1. Purpose
Restrict a function for hotels.
2. Access command to the Hotel mode setup menu In order to display the Hotel mode setup menu, please enter the following command(within 2 second).
[TV] : Vol. [Down] + [REMOTE] : INPUT (3 times)
Then, the Hotel mode setup menu is displayed.
3. To exit the Hotel mode setup menu Disconnect AC power cord from wall outlet.
Troubleshooting Guide
Use the self-check function to test the unit.
1. Checking the IIC bus lines
2. Power LED Blinking timingCheck of the IIC bus linesHow to access
Self-check indication only:
Produce TV reception screen, and while pressing [VOLUME ( - )] button on the main unit, press [OK] button on the remote control for more than 3 seconds.
Self-check indication and forced to factory shipment setting:
Produce TV reception screen, and while pressing [VOLUME ( - )] button on the main unit, press [MENU] button on the remote control for more than 3 seconds.
Exit
Power LED Blinking timing chart
1. Subject
Information of LED Flashing timing chart.
2. Contents
When an abnormality has occurred the unit, the protection circuit operates and reset to the stand by mode. At this time, the defective block can be identified by the number of blinks of the Power LED on the front panel of the unit.
FOR MODE DETAILS CHECK THE FOLLOWING LINK
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
USE SEARCH TAB TO FIND MODELS OR USE DROP DOWN MENU
on Jun 30, 2015 | Panasonic Tc-50ps14 Tv Power Supply Board...
8550 cold reset
Performing a cold reset 1 Print a configuration page to record the previous printer settings. 2 Turn the printer off. 3 Hold down GO while turning the printer on. Release GO after COLD RESET appears on the printer control panel display. COLD RESET (in English) appears on the display for one second to verify that the key sequence has been recognized, followed by the power-on self-test message. Once the power-on self-test is finished, the message RESTORING FACTORY SETTINGS displays in English.
Sep 22, 2011 | HP Color LaserJet 8550dn Printer
I have just changed the ink in my printer and I have received an error message C18a0206. I can't locate this in my documentation. What is the problem?
PERFORM THE FOLLOWING STEPS:
A. - Press and hold the “*” key.
B. - Press the “#” key and release both keys.
Display should say “Enter Special Key Combo”
C. - Press and release in sequence the “1”, “2” and “3” buttons.
Display should say “Support” and display the FW rev (something like R0631R)
1. Press and release the right arrow button until the display says “System Configuration Menu”.
2. Press and release the “OK” button.
3. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
4. Press and release the “OK” button.
5. Display should say “Hardware failure status: Clear. Press OK to clear”.
6. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
7. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
8. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
9. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
10. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
11. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
12.To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
13. If the error is still there, or reoccurs replace the unit.
May 10, 2010 | HP Photosmart C6180 All-In-One InkJet...
Compaq 615 froze with no display and fan whirring.
1. If the notebook computer is running solely on battery power, plug the AC adapter into the notebook.
2. Shut down the computer if it is running.
3. Press the power button to turn on the computer.
4. Press f10 when the HP/Compaq logo displays.
5. After the BIOS Setup Utility displays, use the Right Arrow key to select the Diagnostics menu.
6. Select HDD Self-Test options .
7. Press enter to display a list of HDD/Self-Test options.
8. Select Notebook Hard Drive and then press f10 to display an Estimated test time .
9. Press f10 to continue. The Hard Drive Self Test executes a Quick test , a Comprehensive test, and a SMART test.
If test reports pass then perform installation of OS
else hard drive has gone bad
Apr 16, 2010 | Compaq Computers & Internet
My monitor keeps going into power save mode
Its not power saver mode, when the display goes black and the power light starts flashing that is a good indication that the power supply is about to die. The Dell E172 monitors are noted for this problem. We have step by step repair guides posted on our web site at: www.ccl-la.com Click on the monitor repair link. The Dell E172 series actually has several sub models, check your specific model, the sticker on the back will have either E172FPb, E172FPc, E172FPf. We have guides for all 3 versions posted.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Dec 30, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Dell model No. 1504FP will turn on for 3 sec then off
THE PROBLEM IS THE MONITOR IT SELF.
IT IS TIME TO BUY A NEW MONITOR. I KNOW ALOT OF OF US CANNOT AFFORD A NEW MONITOR EVERY TIME ONE BRAKES, I HAVE FOUND THAT SECOND HAND STORES SALE THERE MINITORS FROM 1-2 DOLLARS PER INCH, I PICKED UP IBM FLAT SCREEN 20" AROUND 20.00 USD. AND IT STILL RUNNING AND I HAVE HAD IT FOR A YEAR OR MORE NOW.
May 12, 2009 | Dell 1503FP 15" LCD Monitor
E172FPb Flat Panel Color Monitor black screen problem
Your backlight inverter inside the monitor is out. If you are comfortable soldering you can repair it yourself. We have a step by step repair guide on our web site at: www.ccl-la.com/LCDrepair5.htm
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
Mar 15, 2009 | Dell E171FPb 17" TFT LCD Flat Panel...
Information code signals "2E"
birdy, this 2E is the code for voltage to the motor control is either over or under specifications. You might have a harness loose on the motor control board. I have run into a few of these where all it was, is one harness not seated all the way. I believe you can get to it by removing the back center panel and it should be down on the right. Check all the harnesses going to it. Reset them if possible. You can also try putting it through the self test. Press and hold the chime and xtra rinse button together for 3 seconds. When the display shows 0, press and hold the wash/rinse and soil level keys for 3 seconds. It should go in the self test mode. It will check all the componets. If it passes, it will display a PA. If an error exists it will display SC. Look for a code of 91. Catriver..post back
Mar 22, 2007 | Maytag MAH6700AWW Neptune Front-Load...
Oven display won't work
rmedrano, Try pressing and holding the stop-time and cancel pads together for 5 seconds, see if it comes back to life. If not, try the cancel and clock keypads together for 3 seconds. First is the control lock-out funtion and the second is the display blank mode. If these fail to work, you are going to have to test for power at the board. The clock (ERC) has a 3 year warranty incase you have to call for service. Catriver.post back.
Dec 16, 2006 | Maytag MES5770 Electric Kitchen Range
Dell E172FP 17" LCD Flat Panel Monitor Logo
270 people viewed this question
Alun Cox
