Question about Lands Phones
My i phone is frozen when i try to restore it comes up o the screen as there is an error 1604
    Genius:
  • 1,689 Answers
For this kind of error, you will have to resort to restoring the phone. just follow the link below to solve your problem.
http://support.apple.com/kb/TS1275
hope you get this working
Posted on Aug 17, 2008
Tried to update now ipod doesn't work at all!
download lastest ipod lastest firmware from http://www.felixbruns.de/iPod/firmware/
restore your ipod using that firmware.
here is howto do it tutorial
http://iphoners.org/shift-restore.itunes/
Dec 27, 2011 | Apple Ipod Touch 4
I dropped my iphone 2g 16GB in a toilet bowl last month. I managed to dry it out but currently having problems in restoring it. ITunes just keep giving me errors like 1611, 1604, 23 and so on. I tried to...
Hey Chee, Usually an iphone with liquid damage may cause damage to internals that may go unnoticed if it is able to work. Depending on the error message you get when restoring with itunes may mean different things.
  • 1604 is just to check your usb cable to make sure its directly (not through a hub) connected to a usb 2.0
  • 1611 and 23 are usually hardware issues that cannot be solved with a restore
Mar 08, 2011 | Cell Phones
Help on frozen iphone 3.1.3...want to restore
just switch off your phone and press home button and connect to cable and restore it from there it would get solved
May 25, 2010 | Apple iPhone 3G
Lock up after trying to install 3.0
There are a lot of suggested solutions on different forums for the 1604 (including on the Apple support site) - most blame a faulty / corrupted itunes and suggest reinstalling, or blame the USB port you're using and suggest either trying a different port (ideally at the back of your HD) or different computer. None of those things worked for me when it happened to me. My issue was that the 'preparing to restore' phase of restoration became looped and eventually it crashed citing error 1604.
However, there was a solution at: http://daggle.com/iphone-upgrade-fail-701 which did work for me.
For convenience:
1. Start the restore process (whatever way you can).
2. When it seems to be stuck in the loop (and possibly your iPhone just shows a blank screen) use CTRL+ALT+DEL and end task to kill the iTunes application.
3. Restart the restore process.
Jun 18, 2009 | Apple iPhone Smartphone
Error 1604 and Kernel Panic
confirm that your firmware is compatable with your iphone.
if you have a 2G the firmware should start with 1.1 if you have a 3G the firmware should start with 1.2
apparently unlocked or jailbroken phones with the wrong firmware will brick in this manner.
not to worry, your not the only one.
do a web search for error 1604 and you will see solutions such as this below.
  • Problem: I cant restore my custom firmware. I just get error 6, 1, 2, (something low).
    Solution: This has multiple causes. Generally, you are not in DFU mode. See DFU guide. Winpwn solution after ruling out the above: Delete the device file (x12220000_4_Recovery.ipsw) in your iTunes folder. (Search for the file). This can also be caused by using the incorrect firmware image (a 3g on a 2g for example).
  • Problem: I am in DFU mode and I just get error 1604, 1602, 1601 (some 160x). I am pulling my hair out! What do I do?!
    Solution: This one sucks. There’s no single answer for it. Here are some possible suggestions:
    • Validate you are using the correct firmware. You can get this if you are using an incompatible firmware (3g for 2g for example).
    • Restart your computer and try again.
    • Try another computer
    • Try switching USB ports
    • Uninstall and reinstall iTunes 7.7
If you are not able to get out of DFU mode even after trying one of the above fixes, click here to follow the comments on BigBoss’s website.
Apr 17, 2009 | Apple iPhone 3G Black Smartphone
Lg ce 0168 mobile phone screen problems
To clear virus from mobile nead to formate code
Dec 02, 2008 | Cell Phones
Iphone cannot restore with itunes
Try the following links:
http://amountaintop.com/error-1604-when-upgrading-your-iphone-version-1-1-1
http://support.apple.com/kb/TS1458
Oct 22, 2008 | Apple iPhone Smartphone
I cannot make or receive calls in my iphone
press and hold the top power button and the menu button on the front simultaniasly until the iphone symbol comes back up. this performes a reset
Jun 16, 2008 | Apple iPhone Smartphone
IPod Nano 3rd Gen. Frozen on main screen. will restart (menu+select) but goes back to being frozen on main screen help asap pleaase
yes it can if it will load in to my computer? look for divce g right click and format it you will lose every thing but it should solve your problem when done use itunes to restore settings ? let me no how you get on
Jan 24, 2008 | Apple iPod nano 3rd Generation
Monitor will not start up!!
It may be a corrupt backup you are trying to install, but if there is a corrupt file you will need to borrow a genuine XP disc off a friend to repair it. You can use your own license number for the copy so your friend shouldnt be concerned with piracy. You may get the pc running by locating on the motherboard either the 3 pin JBAT1 terminal and put jumper from pins 1-2 to pins 2-3 then back to 1-2, or short both pins if you have a 'CLRCMOS', 'CLRRTC' or 'RTC' 2 pin terminals with a jumper cap. Restart pc and it should make you press F1 to set the cmos time and date and hopefully boot into windows, but if not the first paragraph will be the solution to the problem.
Apr 25, 2007 | Acer Aspire T310 PC Desktop
Lands Phones Logo
132 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
