Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
Frigidaire washer door won't open
Not sure how it happened, but the door on our washer won't open today. The Lock light is off and we're able to run it (we tried a couple times to see if that would un-stick it) but the door seems like it's still locked.
I'm not quite sure of where to even begin with the problem.
Thanks!
Tev
  • tev2k3 Aug 17, 2008
    Sorry, I selected Gallery Fridge, but it should have been a clothes washer.
aborcass
  • 2651 Answers
SOURCE: No final spin- washer tub rocks back and forth and times out
e47 i believe is a door lock issue, although its locking shut there are multiple switches in the lock mechanism
Posted on Feb 23, 2008
  • 184 Answers
SOURCE: frigidaire oven door locked
SOME RANGES ARE DESIGNED TO LOCK IF THE CONTROL SENSES A TEMPERATURE EXTREME. IF THERE IS A FAILURE OF THE SENSOR THAT MAKES THE CONTROL THINK THE TEMP IS UP, IT WILL LOCK THE DOOR TO PREVENT INJURY. REMOVE THE BACK PANEL AND FIND THE OVEN SENSOR LEADS COMING OUT THE BACK OF THE OVEN. DISCONNECT THE SENSOR AND CHECK THE RESISTANCE. AT ROOM TEMP IT SHOULD BE SOMEWHERE AROUND 1084 OHMS. IF IT IS NOT CLOSE,
THE SENSOR IS BAD. PLUG IN A NEW SENSOR AT THAT CONNECTOR AND THE DOOR SHOULD UNLOCK. THEN GET INSIDE THE OVEN, REMOVE THE OLD SENSOR, AND REPLACE IT WITH THE ONE PLUGGED IN.
Posted on Apr 04, 2008
  • 1462 Answers
SOURCE: Frigidaire upright freezer door will
no majic to it - just held by a partial vacuum inside. push a small rounded stick thro the seal where it touches cabinet to release the vacuum
Posted on Aug 09, 2008
SOURCE: FRIGIDAIRE FRONT LOAD WASHER
I too had the same problem, I closed the soap tray and a magnet popped out and got stuck to the door. Same problem with it acting like it was going to start and then beeped. This is where the magnet goes, just stick it back in, its held in with pressure (barely) :)
I took the whole control panel off to locate the magnetic reed switch, then just reverse engineered where the magnet is supposed to go on the soap drawer.
Posted on Sep 26, 2008
aborcass
  • 2651 Answers
SOURCE: Frigidaire Affinity Door Lock
under 1st yr warr, sure if thats he issue they would cover, it, a clogged drain pump may cause the same problem though , not being able to drain water , the pump would just hum.
Posted on Dec 03, 2008
Why won't my door lock?
If the door lock will not engage, then the door lock will need to be replaced. Here is the lock to order.
Nov 18, 2012 | Frigidaire ATF6000ES Front Load Washer
Affinity frigidare front load washer won't start. It beeps with message flashing (DR)
Hello zabbster - Typically the DR or DO error code indicates that the door switch is not closed. Make sure that the door lock is completely closed. If the door is closed, make sure the door latch is not broken. If the latch is broken, you may possibly need to replace the door lock switch.
Sep 25, 2012 | Frigidaire Affinity ATF7000E Front Load...
Door lock won`t engage
Hi - I understand that the door won't engaged, however does it show any other symptoms? Try to start a drain spin cycle and let the unit run for approximately 5-7 minutes and press cancel once. If the door opens immediately, unit made have a bad door lock. If you have to wait for the door to release to open, then possibly you have a control or wiring issue.
Sep 15, 2012 | Frigidaire GLTF2940ES Front Load Washer
My Frigidaire frontload washer (model #LTF7000EG0) wont start because Door luck button comes on saying it won't lock. Please Help??
My guess is that being that the lock is electronic, either the lock is defective or there is a problem in the control board in that it's not telling the lock to lock the door. I would have a tech check the board.
May 08, 2012 | Frigidaire Washing Machines
Frigidaire Front Load Washer Model LTF2140FS1. Put clothes in washer, fill detergent dispenser, close it, shut the door, set my cycle hit start then the door lock clicks, clicks again, panel shuts off....
Make sure that the switch for the door is closing properly at all times. If not, unit will not start up or will shut down while operating because the switch has opened.
Sep 12, 2017 | Washing Machines
Door lock light is on door is not locked and
Make sure you are allowing the washer to completely finish its cycle before opening the door. It is normal for the door to lock at the end of a cycle. The locking mechanism keeps owners from opening the door before all of the water has been drained. If the door on the washer is locked, select the "Drain" or "Spin" options on the front-load washer. This will completely drain the water from the system and unlock the door, allowing you to open it.
Thank you !!
Jun 19, 2010 | Frigidaire GLTF1040A Front Load Washer
Frigidaire affinity door will not lock when door is closed or register door is not closed when open
Apr 21, 2010 | Frigidaire ATF6700F Front Load Washer
My frigidaire affinity wont start
Yes, the original issue was the control from the beginning. the control is damaged and it cannot register the latch at this point. this is necessary and , it will fix the issue.
May 29, 2009 | Frigidaire Affinity ATF7000E Front Load...
Dec 03, 2008 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
202 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
