Question about Dell Inspiron E1505 Notebook
E1505 hi, i'm having the same problem that you had, with the orange light flashing and then the green light flashing once, and the battery will not charge whether or not the comp is off/on... my comp will not even turn on if i don't have it plugged in. did you ever find a viable solution for this?? thanks.
  • Bundasthedog Apr 14, 2009
    I have a Dell Inspirion 5150 with the same problem as this Dell E1505. Laptop will not so much as power up without being plugged in to the AC. Likewise, when it is on, the moment you pull the plug, the computer dies instantly. When plugged in, batter light flashes four (4) quick amber pulses and then flashes one (1) green pulse. I am in the beginning stages of investigating the cause of this problem, but I highly suspect the battery is shot. Over the past 5 months, battery life continually became shorter and shorter until one day I was left with a computer that only worked when plugged in. Another post said Dell's website has a decoder so I can learn what 4 amber pulses plus 1 green pulse means. We'll see... Good luck everyone!
  • augustpjohns May 11, 2009
    I just bought a new 9 cell battery and it flashing from orange or red to green and it wont charge dose anyone know how I can fix this?
    Genius:
  • 2,028 Answers
Start by checking the power supply with an ohm meter for the proper output. Anything higher or low than one volt means the supply is faulty and will need replaced. This could also be a battery issue, if a fail safe in the battery has engaged. Try removing the battery and see if it works properly on the supply only, if so, then the battery will need replaced. Also, remove the memory, and try each chip one at a time in each slot. A faulty memory chip pr slot can have this effect. If these three check good, then I'm afraid the problem is with the power management system on the motherboard, and unfortunately the motherboard will have to be replaced. Since the light is flashing, this indicates a code. You can find a light and sound codes list for your machine at Dell's support site. This may help in identifying the exact problem area.
Posted on Aug 20, 2008
SOURCE:
Alternate green and orange lights flashing, tried to remove battery pack and left off for half hour, still problem, if i hold green button down orange light blinks 15 times which i saw in the manual to...
Hi I have a ip100 portable printer and both green and orange lights flash. Green flashes twice and the orange light flash at what seems to be a random disorder.
May 17, 2011 | Canon iP100 Portable Printer
I have a Dell Inspiron 1525 that won't start. The battery light would flash orange 4 times then blue once, and then start over with the same sequence. Pulled the power board and fixed the solder joints on...
This is directly from the User Manual:
If the computer is connected to an electrical outlet, the Battery light operates as follows:
• Solid green: The battery is charging.
• Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the light operates as follows:
• Off: The battery is adequately charged (or the computer is turned off).
• Flashing orange: The battery charge is low.
• Solid orange: The battery charge is critically low.
Dec 27, 2009 | Dell Inspiron 1525 Notebook
Orange 4 times then green, then black screen
This is telling you that the battery is low, replace the battery.
Mark
Dec 19, 2009 | Dell Latitude C610 Notebook
The printer flashes orange light five times, and green once
Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
This also applies to the i550, i560, i950, i960
Sep 07, 2009 | Canon BubbleJet i560 InkJet Printer
5 orange light flashes and 1 green light flashes ???
Hi There, 5 orange light flashes and 1 green light means that the printer is not recognising the cartridege. Iam having the same problem with mine and Iam currently trying to find out why. I have installed the correct cartridge so I'm not sure why it isn't recognising it. but once i know i will let you know
Jun 12, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Battery Light Flashes Orange and Green
I have had three different laptops, last one an XPS from DELL which did the same thing. Replacing the battery solved all three laptops. How old is the battery you have in there now?
Jun 02, 2009 | Dell Inspiron 6000 Notebook
Blinking lights must mean something, but I don't know what.
Accoding to our DCSE site the blink code 4 Green 1 Amber is a memory problem
May 25, 2009 | Dell Inspiron E1505 Notebook
The Charger light flashes orange 3x and green once but it wont charge
Your battery has died, of a fail safe has kicked in. The orange light indicates that the battery isn't charging properly, and needs replaced. Replace the battery and it will be fine. Keep in mind that batteries are just batteries, they eventually wear out, and some faster than others. Also, the more you use the battery, the faster it will wear out, so I always recommend keeping the machine plugged in when possible.
Aug 25, 2008 | Dell Inspiron 8000 Notebook
Dell latitude D600 battery charge light flashing
my suggestion is that you allow the batteries to fully recharge(which only happens when the computer is fully off, when the battery is deep discharged.
that will take around 6 to 10 hours each..
Mar 10, 2008 | Dell Inspiron E1505 Notebook
Dell Inspiron E1505 Notebook Logo
1,447 people viewed this question
Ekse
Clive
Clive
Alun Cox
