Question about GPX MW3337G
I can't reset my GPX 1 gb device
I wanted to reset my device so i can put in a new playlist. I tried poking the reset button on the back with a thumbtack while it was off and nothing. I tried it while the device was on and nothing. Then i tried it while it was connected to my computer and nothing. And if i try to delete all of my songs on my device, then try to put in my new selection of playlists, the device would put the songs in random order rather than the order i put it in.
  • romostacy Aug 19, 2008
    I am trying to remove songs from my GPX but I keep getting a message that says the songs are protected. I have tried over and over but I continue to get the same message
  • brittanyNW21 Nov 17, 2008
    when I turn it on it say error.
    Sergeant:
  • 213 Answers
Both of you have to do format your mp3 player
because sometimes it not deleting
so just format your device by going to my computer
and right click on it
and format it
and fill your new playlist
Posted on Oct 17, 2008
  • shivam raj
    shivam raj Oct 17, 2008
    any coomment post here
Unable to get satellite connection for nuvi1390
There is a possibility that the antenna is defective or another component of the device. You may need to reach out to Garmin Technical Support for repairs or replacement, however, you can try the steps below to try and resolve the issue.
-Perform a hard reset (this will delete any settings you have on the device. After you perform the hard reset, you want to put the GPS unit outside for about 30 minutes or until it acquires a signal. Afterwards, you want to hook it up to your computer and make sure all the software is up to date.
To perform a hard reset, unplug it from any power source and turn it off. Press and hold the bottom right of the GPS screen continue to hold while you power on the device. Once it is powered on, you should get a prompt asking you if you wish to delete the data. You want to press Yes. Next, leave it outside in a safe place to acquire a Signal. If you want to backup your favorites, see below.
You can backup your favorites by doing the following.
In order to back up your Favorites:
1. Using a USB data cable, plug the device into a computer
2. Double-click the My Computer icon (Mac users can skip this step)
3. Double-click the nuvi drive (Mac users can find this on their desktop)
4. Double-click the Garmin folder1
5. Double-click the GPX folder
6. Copy the current.gpx file
7. Paste this file to another location on your computer
Once you save a copy of the GPX file on your computer, you have successfully backed up the waypoints within your device. Now you can RESET it.
To restore these Favorites on your device:
6. Copy the current.gpx file saved to your computer
7. Paste this file to the GPX folder
8. Unplug the device from the computer
At this time the favorites you backed up should be restored on your device.
Regards,
G33k
May 15, 2011 | Garmin GPS
I want to delete music from my gpx mp3 but it says there is no music on it when there is what do i do?
Press the RESET button located on the back of the device. You will need a ped tip or something similar to press it. It will reset your device making it like new.
Apr 10, 2010 | GPX ML648B MP3 Player
Files in Iriver H10 not appearing in music.
try this...
connect your h10 to the pc using the ums trick with the usb connection..
For 20 GB MTP Models
  • Make sure your H10 is turned off and disconnected from the computer.
  • Poke the "reset" button with a paperclip.
  • Turn on the hold switch (so that you don't accidentally turn the H10 on all the way).
  • Plug the H10 into your computer.
  • Turn on the H10 while holding the "O" button.
  • You will see the message "Emergency Connection" if you have done everything correctly. You can now let go of the "O" button.
download and run EASYh10 software (free playlist maker). It will scan the files in your music folder and build/save a playlist to your h10.
disconnect player and give it a try...
Mar 13, 2009 | iRiver H10 MP3 Player
Want to put music back on my zune,it wouldn't sinc,
May have to reset the zune to factory default settings...
Try this....
Reset Zune: Press and hold the back button while pressing up on the control pad.
Connect Zune to a power source: If the Zune device is in sleep mode, this action will wake the Zune device and turn it on. If the battery does not have a charge, you may have to wait several minutes for the Zune device to turn on.
Also, make sure that the hold button on top of your zune is turned to the off position.
Hope this helps!
Mar 12, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Every time I turn on my iriver h10 it freezes on the artists and won't go anywhere. How do I fix this ? resetting doesn't help
not sure what's wrong but try this..
hook up your h10 via the ums trick...
The UMS trick is a great thing to know how to do. With it, you can transfer music, or treat your H10 as a harddrive to put anything you want on.
The UMS trick will also allow you to use your H10 with virtually any OS.
For 5/6 GB MTP Models
  • Take out the battery, wait a second, and put the battery back in.
  • You will see the message "UMS Mode" if you have done everything correctly. You can now let go of the "O" button.
For UMS Models UMS models do not need this trick because they are always in UMS mode!
download and run the free playlist maker software called EASYh10. It will scan the music files on the h10 music folder and save a new playlist to your player.
Mar 03, 2009 | iRiver H10 MP3 Player
I can't add tracks to any of the playlists that I've created!
Are you creating playlists with Musicmatch or are you creating them directly on the DJ?
Let's say you have a playlist on your DJ and want to add a track to it. First, play the playlist. While it is playing, go to Music Library, find the track you want to add, select it with the thumbwheel, one of your choices in the menu that comes up is "Add to Selected". Select "Add to Selected". Now when the DJ reverts back to the screen showing the track being played. Hit the thumbwheel twice. A menu comes up. Select "Save as Playlist". Name it. Then delete your previous version of the playlist. Your new version will include the track (or tracks) you added.
Okay, that answered your specific question, but let me tell you it is much easier to build and organize, and yes, edit and/or add to your playlists from musicmatch.
After loading musicmatch, up near the top is a button called playlists. On its menu, select Playlist Manager. The window that opens has buttons that will let you create new playlists or modify old ones. You can dock your dj and edit the playlists on it from here or build playlists and then Send them to Portable Device (your DJ) Fairly easy.
Mar 01, 2009 | Dell DJ MP3 Player
Gpx 2 gb mp3 problem
There is a reset button on the back of the MP3 player. Use a paper clip and reset the player. It will keep everything and should "wake it up". Try plugging it back into the computer now.
Hope this helps!
Jan 02, 2009 | GPX MW-3847 MP3 Player
Cant get songs onto ipod shuffle.(daughter has ipod touch)
When you go into the ipod section on iTunes, click the music tab, make sure 'sync music' is checked and 'selected playlists:' is also, then check the playlist you want to use. Click 'sync' button
If that don't work go back to the summary tab and hit 'restore' and follow the instructions to reset the ipod, resync and all should be fine.
All the best
Sean
PiDigital
Dec 31, 2008 | Apple iPod shuffle Second Gen. Silver (1...
Sansa m250 playlists
First you need to set your Sansa m250 mp3 player to MTP mode:
) Tap your menu button and select "Settings" > "USB".
2) On this screen, make sure that there is a check next to "Auto Detect" and NOT "MSC".
Note: Music that was transferred to the player in "MSC" (Mass Storage Class) mode will not be accessible once the player is put into MTP mode.
However, the music can still be accessed by switching the player back to MSC mode.
To transfer a playlist using Windows Media Player version 10:
- Make sure device is showing as an "audio device" and in MTP mode
- Create a playlist by right clicking a song in the library, add to>additional playlists>new or by saving a now playing list
- Select the Sync tab and click "Sync settings"
- Check "Synchronize device automatically"
- Set "View" to "All Playlists"
- Place a check next to the playlists they want to transfer to device
- Media Player should then sync those lists once you hit OK.
Once you Sync for the first time a new folder "Playlists" will appear in your m250 using Windows Explorer. Once that folder is created you can even use Windows Explorer alone to create playlists, all you have to do is right click on a song and choose create a playlist. Double click on playlist > Reference Tab, on the window you simply drag and drop your songs.
Hope this helps
Aug 28, 2008 | SanDisk Sansa m250 MP3 Player
GPX MW3837 Malfunction
Let it recharge for a few hours - when an mp3 player won't turn off, use the reset button instead of letting the power drain down. Actually, i take it back - this is the worst most godawful manual I have ever seen - this is the first Mp3 player I have ever seen without a reset button.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Jun 18, 2008 | GPX MW3837 MP3 Player
GPX MW3337G Logo
288 people viewed this question
Top GPX Audio Players & Recorders Experts
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
