Question about Lexmark X1270 All-In-One InkJet Printer
Printing I was using my printer and paper would not feed but i found a pair of toe nail clippers down inside and now the copies i print are coming out poorly and there is no color just black, cartridge levels are full. do you think that something got ruin when the clippers feel inside. i never had this problem before everything worked fine. Any Ideas? Thank You Dave
  • 876 Answers
You can try a simple reset of the paper feed mechanism.
Unplug and turn off the printer
Open the paper jam door
Give the paper roller a gentle push forward until it clicks
Close the door wait a few more minutes before you plug it back in and turn it on.
I hope this works for you. If it doe not, please let me know. Thank You.
Posted on Aug 17, 2008
My printer in printing crooked when i print a lot of papers how do i fix that. It works just fine when i print 2 or 3
first determine if its the paper feed by printing several copies off the glass not using the document feeder. If they are crooked coming from there check the paper cassette and make sure the side quides are snug against the stack. That is the usual problem.
Feb 14, 2011 | Brother MFC9440cn AllInOne Laser Printer
Double printing on pixma mp470
Double printing or double feed??. Double printing means document printed in 2 copies. Double feed means printer feed double paper in one moment. For double printing,please check number of copy of document in printing preference properties.
Double feed occurs when pickup roller fails to pick the paper correctly. It's usually caused by shaft of paper pick up roller which is broken. You should replace drive assembly (include pick up roller) in this case
May 13, 2010 | Canon PIXMA MP470 All-in-One Printer
Printer has been working fine. all of a sudden the paper started to load crooked and jammed. now it continues to do this...why?
Usually it's because something has fallen down the back where the paper goes. One person on here turned her printer upside down and shook it and a Bic pen fell out. I got one last week with a wood screw inside. sometimes I find push pins, candy or jewelry. If nothing comes out try looking inside with a light and small mirror.
Jan 25, 2010 | Lexmark X4650 InkJet Printer
I Have Canon MP600. The paper twists when I start printing copies. Ihave cleaned Paper Feed Rollers. It still twists paper When printing.
You need to look down inside where the paper goes, I use a flashlight and small mirror. I find things like candy,screws, gum wrappers, caught way down where they are hard to remove.
Aug 19, 2009 | Office Equipment & Supplies
Paper goes in but does not come out
I would suggest opening the printer up and taking a good look inside to see if there is any kind of obstruction. Jus a tiny piece of torn paper is enough to cause the whole feed system to jam up. Another thing to look for it that if the paper it getting pulled in straight. If it goes crooked on its way in, your paper feed itself might be the root cause.
May 06, 2009 | Canon PIXMA MP510 All-In-One InkJet...
Printer will not print!
You have a problem with the inner PMX motor inside your printer.
Call HP support
Nov 17, 2008 | HP DeskJet F380 All-In-One Printer
Canon pixma ip 8500 won't feed paper
I have discovered that my problem was a one inch nail which had at some time been dropped into the paper feed slot. It could not be seen from the outside of the printer and was only discovered when I removed the side trim and top cover. When closely inspecting the nylon roller system that feeds the paper out, I saw a tiny piece of metal that looked out of place. Further probing then loosened the nail back to the paper input area.
My printer is now back in full operating condition after spending a couple of careful hours finding out how to remove the trim.
A well worth while exercise in my case.
Oct 15, 2008 | Canon PIXMA iP8500 InkJet Photo Printer
I cant print,scan & copy
try reinstalling the drivers and/or replacing the cables. Also look for any debris or tiny piece of paper that may be stuck between the rollers..
May 09, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Paper feed issues
Yeah i tried the cardboard as well...it didnt work first time. but as i had no other choice, i did it 2-3 more times and eventually i heard a lot of noise and to my surprise my mailbox key popped out covered in ink...
so the cardboard seems to be the magical solution. not only does the printer work again but i also found my key!
Dec 29, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Paper not feeding
Is this a top feed - that is paper loaded on top at the back bottom feed from a tray underneath? Top feed take one sheet of paper and gently push it down whilst the printer is trying to grab it. Tray feed - take tray out make sure no paper fragments are in the tracks and find a nail board and gently abrade the pick up rollers.
May 13, 2007 | Brother MFC-620CN All-In-One InkJet...
Lexmark X1270 All-In-One InkJet Printer Logo
64 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
