How do i use a fast ethernet 5 port network hub? i just purchased one and it came with no instructions
  • angnkali Aug 18, 2008
    thank you so much...now this may be a stupid question but am i using a phone cable or an ethernet cable?
    Scholar:
  • 65 Answers
Plug the cable running your connection to the port the says link. the run a cabel to your computer from the hub port 1, exetera. also it would be wise to be sure to leave one port open ( usually the one next to the link port) to help cloging the network.
hope this helps
Posted on Aug 17, 2008
  • matthew carroll
    matthew carroll Aug 18, 2008
    an ethernet or "cat 5" cable is what your looking for.
    they look like phone cables but the heads are wider.
    if you have anymore questions please ask
INTELLINET+523301+power+light+is+yellow
Try the connection directly to your pc.
If works possible solutions are :
1-The device is fry
2-Update the firmware
3-call your ISP
Feb 04, 2014 | Intellinet Network Solutions Intellinet...
I am trying to set up a switch between my PS3 and my PC. I have an external DSL modem. I purchased a 5 port switch(Rosewill RC405-x) but no luck. Can I use an ethernet splitter instead?
You did not explainhaow you connected all your equipment together.
Connect your PC and PS3 into the 5 port switch.
Connect your DSL modem into the 5 port switch, if there is a WAN/internet port on the 5 port switch then connect the DSL model into this port.
You may need to power off the 5 port switch wait a 1 min and power up the 5 port switch again so it can setup an IP address table for the connected ports.
If this still does not work the replace the 5 port switch with a normal 5 port hub.
Mar 20, 2012 | Rosewill RC-405 - Switch - 5 ports -...
What wires go into the back of the Dynex 5 Port 10/100 Fast Ethernet Switch?
A switch is a device for networking computers printers or other devices with an ethernet port. Most common scenario would be to hook a cat5 cable from your broadband router's lan port to Port 1 and then connect your other ethernet devices to the remaining ports. In order for the devices to cmmunicate you'll want to make sure that they are on the same ip subnet. Usually, 192.168.1.x.
Your router may be 192.168.1.1, your PC 192.168.1.100 Printer 192.168.1.101. Each device needs a unique IP address.
Hope that helps.
Oct 21, 2010 | Dynex 5 Port 10/100 Ethernet Switch...
Tutorials On How to configure a D-Link DES-1008D Ethernet Swich
There really isn't much to setting up an ethernet switch hub. Plug a network cable into your router LAN connection and into port 1 or uplink port of your switch. All other computers will attach to ports 2 to 8. If you have an Uplink port and port 1, they usually can only be used singlely. That is to say use either the Uplink or port 1 Using both disables the switch hub.
Jun 01, 2009 | D-Link Computers & Internet
Instsll the switch
You will find the manual here:
http://www.dynexproducts.com/pc-185-4-dynex-5-port-10100-ethernet-switch.aspx
Usualy this type of device is very simple to install.
Feb 16, 2008 | Dynex 5 Port 10/100 Ethernet Switch...
Connection problem between modem router and hub
Sounds like you may need what is called a "Crossover Cable' connecting your router to your hub, or if either device has an uplink port, use it on one device to connect to normal port on other device. Here are instructions for making your own cables: http://www.lanshack.com/make-cat5E.aspx
Dec 08, 2006 | Kingston EtheRx Networking Switch
Computers & Internet Logo
David Payne
David Payne
