Question about Belkin Computers & Internet
Help me get my router set up on my notebook - Belkin Computers & Internet
    Guru:
  • 1,463 Answers
Have you tried the routers web site they will have some info .
as you dont say which router you have ?
riz.
Posted on Aug 17, 2008
I have a Linksys WRT320N wireless router connecting my PC and 3 netbooks. 3 netbooks stuck "acquiring network address" after establishing wi-fi protected set up for my BlackBerry Torch. How do I...
If your 3 notebooks were already configured with router and then you used WPS to connect your blackberry, then it must have changed the wireless settings of the router, due to which the router and the 3 notebooks are not able to communicate now and due to that, the notebooks are showing acquring network address as they are not able to get an IP address of the router.
Solution: You need to open the interface of the router and check the new wireless settings and then put those wireless settings into your 3 notebooks. You may use this link for detailed instructions, or you may also chat with the technician available for chat on that website. Check or Change WirelessPassword
Jul 10, 2011 | Linksys Computers & Internet
My desktop PC is currently connected to the Internet wirelesly without a problem. Also my notebook ASUS N61Jv has connection to the Internet but only by wire. I wish to have access to the internet...
The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, it needs the router'swireless settings configured ie SSID, WPA or WPA2 encryption key and also thewireless cards in all the laptops and or computers needs to be configured withthese router's wireless settings. Then the laptops and desktop computers cancommunicate with your wireless router.
Mar 11, 2011 | Computers & Internet
My wnr834b router is about 2 1/2 years old. Suddenly I can't connect wirelessly--my notebook doesn't detect a wireless network--my desk PC is wired to the router and works fine. My notebook works fine...
So the desktop is working with the wired connection. That means the wired part of the router is working . you will need to check the wireless settings of the router. For this you will need to access the router set up page. When you try to connect to the wireless network , Do you get any message ? Or you are not able to see any wireless network ? The message will be important to identify the problem. First try to connect to the wireless network on the laptop. Try to change the wireless channel on the router. That may help you. I hope the following link will help you Click Here for more info
Nov 17, 2009 | Computers & Internet
2 Notebooks without router acces at the same time
Under the DHCP settings, make sure that there is enough IP addresses for the router to assign. Although DHCP is somewhat "automatic" if there is not a sufficient range of IP addresses for the DHCP server to assign, then only a small number of clients can connect. See this page here: http://support.dlink.com/emulators/di524/h_dhcp.html
Also make sure that your notebooks are not set to the same static IP address, only one device can connect to a specific IP address. To check this under Windows XP, Right-click your wireless network connection and select "Status" then "Properties". Highlight the "Internet Protocol TCP/IP" and select "Properties". Make sure that the radio buttons "Obtain IP address automatically" and "Obtain DNS server address automatically" are selected. Click OK and OK to close the windows and save the settings.
I would also unplug the router, wait 60 seconds, then plug it back in and try to reconnect. Sometimes for whatever reason, the routers memory can get corrupted, (just like a computer) and need to be restarted.
Sep 06, 2009 | D-Link AirPlus DI-524 Wireless Router
Setting linksys WRT54GX Ver2 with D-Link DSL-2450T ADSL2+router
Your router needs to be configured. Call Linksys Technical Support. If they cannot help you try this http://technicalsupport.blog.friendster.com
Feb 15, 2009 | Linksys Wireless-G WRT54GX Router...
Lg r 405 will not recognize wireless signal from lynksys wrt350n
hi i would suggest to access your routers setuppage and set the channel to channel 11.
make sure also if your wireless network is secured, type the correct key those things are case sensitive.
to access the routers setuppage go to a computers that is connected to your linksys router (wired) then launch IE on the address bar type 192.168.1.1(this is the routers ip) then it will ask you for username and password for the username dont type any thing for the password type admin.
when your on the setuppage click on wireless tab. while on the wireless page set the channel to 11.
after that click apply or save settings on the page.
then after that try to connect to your wireless network on your laptop.
for further help you can call linksys hot line 1800-3267114
they will surely help you with this.
hope this helps.
Oct 19, 2008 | LG X-Note LM50 Notebook
Wifi set-up for a toshiba notebook
First is to turn on the physical WIFI switch on the notebook. Usually for sattelite it is in the front of the unit. Then after, since I believe it is on vista (or even on XP) you will click on start, then connect to, then it should give you a window that you could see your router, highlight your router, click on connect, it will ask for a passphrase or network key if your router is secured, just type it in and it should be connected successfully. That should be it.
Hope this helps.
Jul 23, 2008 | Computers & Internet
Wireless router compatability
I think yo should do this first before replacing:
To reset the router to factory defaults, connect the Ethernet cable to the router and check and set the settings.
This should allow you to get into the routers menu and see status and information to help you.
You also have to be sure whether or not you have 'allow windows to manage my wireless connection' checked or not
(In you Network setting)
Let me know what happens after that & I'll be glad to help
Apr 03, 2008 | Acer Aspire 5315 Notebook
CWR-854 router
Type in the address of your router - you say that is set to192.168.1.254 and you will see the config page( after logging in ) for your router. This is more usually 192.168.1.1 though .
Jan 18, 2008 | Cnet CWR-854 Router
Computers & Internet Logo
14 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
