Question about Samsung 24.8 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Platinum... Side by Side Refrigerator
Water leak I have a Samsung refrigerator model # RS 2534WW and since I moved, I noticed water coming out of the refrigerator side behind plastic baskets from a plastic tube that runs through the back of the unit.
  • 725 Answers
Unplug the refrigerator, open the door and get a blow dryer and warm up the freezer. wait until the water stop dripping out or about 12 to 24 hours and then you can plug it back in . it will work for 2 to 3 weeks. To unplug the drain.defrost the freezer .remove the back cover. Use a pipe cleaner to clear the drain. pour a few cups of hot water down the drain. the drain hose may be just pulled off ...it must let the water drip in the pan.
Posted on Aug 17, 2008
Water leaking from behind the drawer
in fresh food side or freezer. please describe.
Feb 25, 2014 | Samsung RS2578BB Side by Side Refrigerator
My Samsung RS253BAWW has been collecting water underneath the bottom drawer for some time now. It eventually winds up in the drip tray underneath and then runs out onto the floor. I've replaced the...
Depends if there is plastic tubing running inside fridge compartment. Shut off water to fridge. If that stops it you will have to look inside to see if there is visible plastic water tubing or if you can get to it from inside the fridge. Maybe the water line has a defect or got pinched and somehow split. Then turn on water, find leak and splice in a replacement section.
Jan 28, 2011 | Samsung RS2534 Side by Side Refrigerator
Samsung rs255sl refrigerator leaks water at water filter. Replaced water filter and it still leaks. Leak occurs even when not dispensing water.
The problem is at the water lines behind the kick plate. Remove the 3 screws on the kick plate. You should see too water lines a red and a blue coupling. Push the water lines in rather forcefully towards each other. When looking at the couplings on your left hand side you should see a small gray lip. You need to slide those outwards and insert the red clips (that should have been left in the plastic bag with the allen key used to adjust the door height) in between the lip and the coupling as they are compression fittings. This should fix your problem right up!
Oct 08, 2010 | Samsung RS265LBBP Side by Side...
Model KSRS25FGWH01-water is dripping inside the freezer ice bin.
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Nov 16, 2009 | KitchenAid Superba Architect KSCS25INSS...
Small amount of water leaks from the front of my Samsung R2630SH.
I found out that there is a plastic panel that cools three draws inside the refrigerator. Behind the plastic panel there is an evaporator (coolant childer) that catches the condensation of repeatedly opening and closing the refrigerator door that turns into thick ice. Because of condensation, ice buildup in such a way that the ice pushes the middle draw out causing the door to open. In turn depending on how long the door stays open, melts the ice and the water leaks under the bottom draw out on either side of the front refrigerator door. Also, there is a drain plug that is also iced closed. To solve that problems, the unplug the refrig, put towel under the refrig, removed the panel (unplugging the wires and removing screws) and took a hair blow dryer to melt the ice. Oh, by the way, I used to blow dryer to melt the ice from the panel before I could remove the panel. That job took all day. I removed all the ice and reassembled the panel and replace the drawers. To my amazing, no more leaks and the water dispenser worked for two days and quit. I believed the water tank (plastic container in front of the panel has frooze again. By the way the ice maker did not work after removing the ice.
Aug 16, 2009 | Samsung RS2630SH Side by Side Refrigerator
RS25AWXEW01 side x side refrigerator has leak at ice maker water drips into frozen ice chute and leaks onto floor and also in freezer compartment
Aug 13, 2009 | Roper RS25AEXLQ Side by Side Refrigerator
Samsung fridge is leaking water
Probably one of the plastic tubes under the refrigerator is leaking.
Apr 04, 2009 | Refrigerators
I have a Samsung RM255LASH Side by Side Refrigerator. The ice maker is not making ice correctly. The ice that comes out is half water, like its already melting. Later the same day I noticed water on...
move the fridge out to see if there is water underneath it sounds like a leak in a line some where you might want to have a service tech check it out.
Dec 07, 2008 | Samsung RM255LASH Side by Side...
Samsung refrigerator rs 2534ww
Samsung freezer.
The freezer temp will not go back to the temp it was originally it keeps dropping back 15 degrees below to what i set it.
Sep 04, 2008 | Samsung 24.8 Cu. Ft. Side-by-Side...
Samsung 24.8 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Platinum... Side by Side Refrigerator Logo
158 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
