Question about Cameras
The SD card is write protected - how do you change this?
  • Anonymous Apr 13, 2009
    I have been using the same card in my camera since I bought it a little less than a month ago. I took the card from my computer today and put it in my camera and it says "Memory card is protected (reset switch on memory card)" I tried flipping the swich up, and then down again, and back...each time putting the card back in my camera only to get the same result. I put another card in, same message popped up. A third worked, but still neither of the first cards I tried are working.
  • Anonymous May 25, 2009
    THANK YOU IVE JUST HAD THIS PROBLEM WITH MY NIKON COOLPIX THANK GOD FOT THE NET.
    SO SIMPLE MY PROBLEM IS NOW SOLVED
I have the same problem, but my card has no switch...
kdr
Posted on Nov 12, 2008
Ok ok i found a solution. so on the side of the card there should be little switch. Make sure its up
Posted on Aug 28, 2008
This is all because of the external memory. firstly, you check the external memory. In some memory there is a small locking system check that first.If that doesn't work back your file and buy the new memory for the camera. thats all you people need to do.
regards
bms(bibek)
Posted on Mar 28, 2009
  • Anonymous Mar 28, 2009
    or format the memory card using computer(full format)
SOURCE:
Undoing Write Protection On A Micro SD Card
These cards have a switch on them to protect them just change the position and you should be able to format it.
Jan 15, 2013 | Samsung 8GB Sandisk TF Micro SD Card Black
I PURCHASED A KINGSTON MMC MOBILE SD CARD, AND INSERTED INTO THE SLOT OF MY PHONE AND WAS NOT ABLE STORED ANY DATA ON IT, SUGGESTING THAT MAY BE THERE IS A LITTLE PROBLEM WITH MY PHONE, SO I DECIDED TO...
SD cards allow you to store digital information; you can use SD cards with most electronic devices like digital cameras and computers.
An SD card will become write protected if the switch on the card is placed on the "Lock" position. This prevents any information on the card from being altered or deleted.
If you wish to add, delete or change any of the information, you must remove the write protection.
Remove the SD card from the computer or digital device.
Locate a switch on the bottom or side of the SD card.
Move the switch to the "Unlocked" position to remove the write protection.
If you do not have a switch, you will need to remove the write protection with your computer.
Insert the SD card into your computer's card reader or back into the digital device.
You can now save and change information on the card.
Apr 07, 2011 | Kingston 1 GB microSD Card with USB 20...
How to fix write protect from my olympus FE 190 model
Good day,
This tip will explain how to remove the write protect from your SD Card.
This is a easy fix and won't take a minute.
First remove your SD Card from your device. You will see on the side of the SD Card that there is a small switch. If your SD Card complains about being write protected simply put the switch in the opposite position. Some of the SD Cards even have the word LOCK on near the switch indicating the direction the switch must be to LOCK the card.
Once the switch is changed you can put the SD Card back into your device and the problem of write protection would be solved.
Please feel free to let me know if this tip was able to help you!
Regards
Apr 05, 2011 | Olympus FE-190 Digital Camera
How do i take write protect off?
Good day,
Regards
Apr 04, 2011 | Olympus ? 1030SW Digital Camera
Wat is write protect
It's the memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card, allowing the camera (or any other device) to write to the card.
Mar 18, 2011 | GE Cameras
How to remove the write protected micro sd card?
Dec 06, 2010 | Kingston 1 GB microSD Card with USB 20...
How could unlock memory card
Good day,
Regards
Nov 29, 2010 | Nokia Cell Phones
How to remove write-protection
Dear Friend,
  • There is a write-protection tab on the mini sd card HOLDER. Every time you insert this into your PC or card holder, this tab slides to the write protect position. Either keep resetting, inserting & reinserting until it doesn't slide or tape it down.
  • There is nothing wrong with the mini sd card. Simply locate the write protection key and push it.
  • The mini sd card has some error: Go for a low level formatting.
  • The card has virus: Remove the virus.
  • Change the Usb Port(Recommend you to Use Backside Port)
  • Change the Cable
  • Restart PC
  • Still have Problem Change Card Reader..
Hope this Helped you..Thanks for Contacting FixYa...........
May 14, 2010 | PNY 2GB microSD Memory Card
Write protection problem of my mobile memory card
Hi..
To remove the right protection it is very simple, first remove your SD card in your mobile, the observe your SD card back to back, if you can see a small button you need to slide that button to remove right protection, then plug your SD card back to your china mobile and try to copay a folder,
Good luck !!!
Regards
PCmania
Jul 11, 2009 | Nokia N72 Cellular Phone
Cameras Logo
433 people viewed this question
Top Cameras Experts
Ekse
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
