The program says that I have no Midi output. How do I get a Midi output.
    Guru:
  • 1,463 Answers
Hi
which program ? tells you this have a look here about about the software MIDI Output | Sygyt Software
riz.
Posted on Aug 17, 2008
While using korg m50 editor using usb data cable there is no sound from my lap.the sound is only from my head phone connected to my keyboard directly?
Are you connecting to the laptop and using it as a midi controller? You can record midi notes from the keyboard and send them to your laptop via USB using any midi sequencer program (reason, logic, etc). Create a midi track, select the input of that track as your keyboard, then hit record to play some midi notes. To hear what you record, you have to set the output of the midi track to whatever midi sounds or instrunents you have installed on your laptop.
If you are trying to record the actual audio sound the keyboard makes, use an audio program such as cubase, sonar, audacity, pro-tools, and either mic the keyboard, or connect one of the other audio outputs (1/4" TRS) to an audio input on your DAW, and record an audio track that way (as opposed to a midi track).
Apr 13, 2012 | Korg M50 61-Key Music Workstation Keyboard...
I bought a usb to midi device for my Casio CTK-491, but none of my VST's or DAW's receive midi information from the keyboard, The programs see that there is a midi input and output but the computer...
what program are you running and did you set up your keyboard with the software so it can recognize it. Depending on what software it is your using as soon as I know I can tell you how to get it working. I use my midi keyboard with everything from reason, Ableton live, pro tools logic logic express vdj traktor basically every software!
May 29, 2011 | Casio Ctk491 Midi Keyboard
I just got my first MP can i use my mac ibook that i have a program call Reaper. i know i have to have scsi but can use a midi to do the same??? thanx
Your Mac should detect your MIDI keyboard automatically. To make sure of this, open "Audio MIDI Setup" and click "Show MIDI Window" in the "Window" menu. In that window you should see your Akai listed as one of the MIDI devices.
Now, open Reaper and open "Preferences". Find the "MIDI Devices" section on the left side and make sure the Akai is listed on the right side. Then make sure that inputs and outputs are enabled.
Once that is done, Reaper will allow your Akai as recording input on any track.
Check the Reaper manual for more specifics on recording in Reaper.
Feb 19, 2011 | Akai LPK25 Laptop Keyboard Controller (...
I have the yamaha dtexpress and a midifase conect but cant get anny sound to the computer??????????????
try a midi loopback device or a viruual midi cable such as sonys virtual midi cable: http://www.johnrofrano.com/tutorials/virtualmidirouter.htm
i dont know if this one will work, you could also search for loopb1 and hubi's midi loopback device, one of these should work.
what you have to do is use one of these programs, or something similar, to connect your midi input to the soundcard's midi wavetable or to your midi/synth/sequencing software's midi input.
also, the drum machine should be set to output to midi channel 10. make sure that your software is set to recieve on midi channel 10, if applicable.
Nov 29, 2010 | Yamaha Dtxpress Iv Special Electronic Drum...
Have a casio px 320 and trying to use it in GarageBand on my Mac OS X. Connecting USB cable from USB output on Casio to USB input on Mac doesn't work. Any help?
use the audio output to send the keyboards internal patch sounds, or use a usb midi adapter to use the keyboard to trigger the garageband midi sounds, if the keyboard has a midi output, that is. the usb output requires software drivers to use, and IS NOT mac compatible. You may have to select a midi source in garage band preferences or settings if you are using midi.
Nov 14, 2010 | Casio Privia Keyboard Case
Is the Boss Dr-5 compatable with the Boss BR-1180 mini studio?
Midi doesn't actually "make sound". If your trying to record the patterns you made on the DR-5 to the recorder you need to use an audio output(I don't remember if they are RCA or 1/4" on the DR-5.) The midi output would be used to"trigger sounds" in another device that has sounds built in, or you could also trigger sounds in a program that supports midi input.
Mar 03, 2009 | Boss Micro BR Digital Recorder
I get Midi Output but no Midi Input
Think you need to associate a player driver to the program. Try meida player as proxy driver
Jan 04, 2018 | Computers & Internet
Playing midi files on Toshiba A100
did you check in control panel ? what sound cart you have?
Aug 15, 2008 | Toshiba Satellite A100-S8111TD Notebook
Tascam 2488mkll echo
I just bought a 2488mkll .I have a keyboard. On my old portastudio
I had to us the headphone output of the keyboard to plug into the portastudio for a signal can I do this with 2488mkll. Also the keyboard has a midi output I'm not familiar with midi cables it's a 5 pin midi can I just plug the midi output of the keyboard into the 2488mkll input or do I need something more?
May 13, 2008 | Tascam 2488 Portastudio Multitrack...
Hi need sound
Certain early models of the Sound Blaster cannot do both MIDI input and wave (audio) output at the same time. Thus, if you've selected "Creative Labs" as a MIDI In device in Cakewalk’s Options | MIDI Devices dialog, wave audio output won't work. Note that MIDI output will work fine along with wave audio output: you can select Creative Labs from the list of MIDI Out devices. The problem occurs only when you've selected the Creative Labs MIDI In device.
Hope that helps!
Dec 08, 2007 | Cakewalk Guitar Tracks Pro 2 Classic
Computers & Internet Logo
David Payne
David Payne
