Question about Maytag Atlantis MAV6000 Top Load Washer
MAV Atlantis 6000
Problem with load Clicking sound when in Rinse cycle. And I get a Rubber burning smell . What could I do to fix
  • 943 Answers
Hi. thanks for the question .the clicking sound is something caught, in water pump. the rubber smell is the belt . pull washer away from the wall. small door at the back left corner ,remove pump on the floor. remove 3 3/8 bolts remove. replace . belt underneath washer . replace thanks the appliance doc please rate me
Posted on Oct 01, 2008
6ya staff
SOURCE:
My MayTag Atlantis washer will not spin or drain the water out, when it gets to the rinse cycle or spin cycle , it just makes a buzzing or clicking noise.
The brake mechanism is not releasing properly. The noise your hearing is the motor trying to move but can't. Do not continue to operate the washer or you will burn out the motor...an expensive replacement. See instructions for my other solutions.
Sep 23, 2010 | Maytag Atlantis MAV6000 Top Load Washer
I can smell rubber burning and the washer no longer works. It will not turn-on at all.
Handyman here -
If it sounds like it turns on, but doesn't move then it could be a drive belt or the transmission.
If it doesn't sound like its turning on, then its probably the computer board.
From the 'burning rubber' smell, I would bet on a belt.
Apr 03, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Fisher & paykel GWL11 washer won't rinse
sounds like you have two problems, the burning smell is probably the pump,out of balance is usually due to worn aout suspension rods
Oct 14, 2017 | Fisher and Paykel GWL11 Top Load Washer
Maytag Atlantis shut down during rinse cycle.
Contacted a local repair shop. They told me that if I got it spinning again, the motor was most likely ok. It is protected by a thermal switch that turns it off when it begins to overheat. The smell was to be expected as it was overheating; the difficutly restarting was because it hadn't cooled off enough yet. We have now used it a few times for small loads. Still getting a smell, but the wash cycle is completing ok.
Jul 23, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Grinding sound from washer
the pully is the drain pump they can go bad or may have somthing in it, pump is not bad to replace part us usually 40 -60$ , you could burn belt up and be forced to replace it also, but if you replace pump would not be a bad idea anyway belts are 20-30 $
Mar 30, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Dead mav6000
this is my experience repairing the maytag washer Atlantis mav series 9750 aww, I had to replace the spin bearing since it was making a jet engine noise when it was spinning out the water. its not an easy job for my 1st time taking this machine apart, you literally take it all apart to get to this bearing, but now I can show how to do it with pictures making it easier for you to do it. even if you have to replace something other than the spin bearing, this how to tutorial will show you how to get to most of the parts in this machine, parts are not that expensive, 50-80for bearing kit, here is my site on how to do it http://maytagwasherrepair.googlepages.com/index.html
Mar 09, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
237 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
