Question about Microsoft Xbox 360 Controller
Xbox 360 Wired Controller Busted
Basically, my wired(not wireless) 360 controller is broken. It only turns on for a half a second at a time. If I move the cord in the right spot(spot varies) it'll turn on for a half second. Otherwise it stays off.
A month or so ago it would stay on for a while if I kept the controller wire at the right spot. All the buttons worked fine, there was no problem there. The mic. would work fine as well for XBL. As far as I can tell, nothing is wrong with my controller expect for the fact that it won't stay on.
Any help would be greatly appreciated. Not exactly thrilled about the possibility of having to spend $40 for a new controller, you know?
Thanks!
  • 3 more comments
  • afly_513 Nov 27, 2008
    okay well lets see what happened to mine, was that I was sitting down playing. and I got up, i forgot i had a remote on my lap and when i got up the remote flew and unplugged the controller, i tried to plug it in again but it plugs in fine from what i can tell, but it still won't come on. even on both connection ports, but still nothing. And I'm not too happy getting a brand new controller that breaks a week after i buy it... it did however unplug the break away, so I wonder...
  • Anonymous Jan 05, 2009
    two of my wirless controlls have broken in the last month
  • nikanastaz Feb 02, 2009
    How exactly did you fix it? Did you have to cut a wire?
    I have the same problem
  • flehime Mar 19, 2009
    i have the same problem but my wired remote isnt a microsoft remote its another brand of remote. It worked fine before if it was in the right spot but know it turns on for half a second and then stops flashing Any help would be appreciated
  • afly_513 May 11, 2010
    so FOLP9 I believe I know how you did fix the controller, but may I ask you how you did it just askin' to see if I was correct. Just checkin' that way I don't screw up and completely destroy my controller...
    thanks...
Yeah I foudn the problem. I just found out one of the wires was broken inside, right above where the controler meets the wire. It was a grayish wire, probably the one that turns it on. No wonder it would only turn on if the wire was in a certain position, it was connecting the wires! Problem solved.
Posted on Aug 19, 2008
    New Friend:
When i move my controller it turns off
Posted on Apr 14, 2013
U said u moved the cable and it turned on for half a second so maybe the problem is that a cable inside was cut. its really easy to fix that just take the plastic off from were the cut is and get the cable that is cut and with your fingers put them back together now get your black tape and tape it all around were the cut is and when ur done just put more tape now connect your controller to the xbox 360 and it should work just fine.i had the same problem and i fix it myself.
Posted on Jul 23, 2010
Controller doesnt turn on but batterys are good
Connect a game controller
Solutions
Learn how to connect a wireless or wired controller to your Xbox 360 console.
Connect a wireless Xbox controller
  1. Turn on your console.
  2. Press and hold the Guide button on the controller until the controller turns on.
  1. Press and release the connect button on the console.
Xbox 360 E console fbbfb609-f7ed-4e6e-bd35-7543b1c20d61.png?n=xbox360-connect-m-s.png Xbox 360 S console Original Xbox 360 console 342c6e70-9e56-43d8-bb3a-05f5411040bd.png?v=1#xbox360s-connect-m-m.png 170df81e-0a79-49be-8236-a0fb68eec37b.png?v=1#xbox360-connect-m-m.png
  1. Within 20 seconds, press and release the connect button on the controller.
  1. When the lights surrounding the power button on the console stop flashing, the controller is connected.
On the Xbox 360 S console, each connected controller is assigned to one of four positions. Each position corresponds to a lighted section around the console power button and the controller Guide button. On the 360 E console, a solid green light on the front of the console indicates that the controller is connected. To determine the player position associated with your accessory, look at the ring of light that surrounds the Guide button on the controller.
c9341988-8ed5-4217-9b87-353de50efbec.png?v=1#connect-xbox-controller-m-m.png 5e4ab6ab-8cb0-41e6-a037-b88221a430c7.png?n=connect-xbox-controller-360-m-s.png
71add0b7-ddf2-4439-b4b4-f50f156d92b7.png?v=1#controller-batteries-m-m.png If the controller does not turn on, check the batteries. Insert fresh AA batteries, making sure they are correctly positioned in the battery case.
You can also use the Xbox 360 Play & Charge Kit or the Xbox 360 Quick Charge Kit to power the controller. Learn more about Xbox controllers and chargers.
To connect additional controllers, follow these same steps again. You can connect up to four controllers to the console. Each connected controller is assigned a position that corresponds with the lighted sections that appear around the console's power button and around the Guide button located in the middle of each controller.
  • To disconnect a wireless controller, press and hold the Guide button for three seconds, and then choose to turn the controller off.
  • When you turn off the console, the controller will reconnect the next time you turn on the console.
  • The controller can be connected to only one console at a time. You can connect the controller to a different console, but the connection to the previously connected console will be lost.
Oct 11, 2013 | Microsoft Xbox 360 Controller
My controller was working one day and then stop working the next day it had fresh battery
Solutions
Jul 31, 2013 | Microsoft Xbox 360 Controller
Ho w to fix x box from controller to x box is really slow how to make it normal
Connect a wired Xbox controller
5fb17f50-7448-45d5-a294-9ea90994f55b.png?v=1#controller-wired-m-m.png Plug the Xbox 360 Wired Controller into a USB port on the Xbox 360 console. There are two USB ports on the front of the console. To disconnect the controller, pull on the connector, not the cable.
cbe46bf0-3a46-4d53-9d8c-6697aa57622a.png?v=1#controller-cable-release-m-m.png The cable on the Xbox 360 Wired Controller has an inline release. The inline release on the controller cable is a safety feature designed to reduce the chance of the Xbox 360 console falling if the cable is pulled.
Wireless controller troubleshooting
If your wireless controller disconnects or cannot connect to your console, see Xbox 360 Wireless Controller disconnects or can't connect.
If your wireless controller does not turn on or loses power, try the following solutions:
Solution 1: Replace the batteries
Insert a new set of AA alkaline batteries into the Xbox 360 Wireless Controller, and then try to turn it on.
Solution 2: Try a different battery pack
If you have another Xbox 360 Wireless Controller, take the battery pack off that controller and attach it to your controller. Then try to turn your controller on.
If your controller works with the different battery pack, your original battery pack might be defective. If your controller is under warranty, you can order a replacement battery pack from Xbox Support . See the Assistance section at the bottom of this page for more information.
If your controller is out of warranty, you can buy a new battery pack from a retail store.
Solution 3: Try a rechargeable battery packIf you or a friend has an Xbox 360 Rechargeable Battery Pack, attach that battery pack to your controller and try to use your controller. If your controller works with the rechargeable battery pack attached, you can buy a new battery pack from a retail store or order a replacement battery pack from Xbox Support. See the Assistance section at the bottom of this page for more information.
Feb 08, 2013 | Microsoft Xbox 360 Controller
How do i reactivate the wireless controller to my xbox 360
How to Configure an Xbox Controller Fotolia.com"> configure-xbox-controller-800x800.jpg Configure you Xbox controller.
The Xbox 360 utilizes two types of controllers: wired and wireless. Like most operations on a video game console, configuring a controller requires little effort. You can either plug the controller into a port on the Xbox 360, or sync a wireless controller using the console's built-in controls.
Difficulty:Easy Instructions
  1. Wired
    • 1 Connect the controller's cable to the in-line release cord. This cord prevents you from accidentally pulling the Xbox 360 along with your controller during game play.
    • 2 Insert the in-line release cord's USB plug into the USB port on the front of the console.
    • 3 Turn on the console to activate the controller automatically.
    Wireless
    • 1 Insert batteries in your wireless controller, if necessary.
    • 2 Hold down the "Guide" button on the controller.
    • 3 Push the Xbox 360's "Connect" button, located on the front of the console.
    • 4 Push the controller's "Connect" button to sync it with the Xbox 360.
Read more: How to Configure an Xbox Controller ' eHow.com http://www.ehow.com/how_7780486_configure-xbox-controller.html#ixzz1PRsAYmUA
here is a video on how to sync your wireless controller to your xbox360 console
http://www.youtube.com/watch?v=GpV-b1de2lM&feature=related
if you think this help please rate me sir thank you so much!!!
Jun 16, 2011 | Microsoft Xbox 360 Console
Xbox 360 wired controller glows green for 2 secs then shuts off
Microsoft software is usually very good about finding mods within their systems. Since you have repaired a wire, it might somehow think it's been modded.
Double-check your repair work, if you used a soldering iron, it could have attached to another wire -causing a short (faking a mod). If you just twisted and taped it, you might want to consider a better fix.
Aug 01, 2009 | Microsoft Xbox 360 Controller
Xbox 360 controller one wireless two wired
The port on the XBox has gone bad or there is dirt or something in the port. Use compressed air to blow out the port and see if it helps. If not the unit needs repair.,, try this out and see...
thank u rate me
Feb 10, 2009 | Microsoft Xbox 360 Controller
Wired controller
If it's wireless no. Just turn on ur 360 and press that X button on the controller. Hold it for like 2 seconds. For wired ones, just hook it in that think slot on the side.
Dec 31, 2008 | Microsoft Xbox 360 Controller
Xbox 360 guitar hero no sound controller 2
goto options with the controller and check if sounds are turned up.
alex
Jul 08, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Controller Logo
2,734 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
