Question about Roper Refrigerators
My 13-yr. old Roper does not self-defrost
Roper runs for long periods of time and ice accumulates; have to manually defrost. I defrosted this morning and it ran all day but just a few minutes ago shut off but I could not hear it defrosting.
  • abbott835 Aug 18, 2008
    Thank you for such a prompt and complete response. We will definitely check into this and hope this will be the solution to our problem. :0)
  • 725 Answers
The defrost systems is:
HEATER-DEFROST
THERMOSTAT-DEFROST
TIMER-DEFROST
Start with the timer. It is just under the front kick plate. there is a knob you can turn it slowly.until it clicks off the compressor. then open the freezer and listen . You should hear the heater come on .. it will sizzle when it comes on ...
You will have to remove the back panel of the freezer to check the heater for and thermostat for continuity. Heater are the lease likely part to go bad... I always change thermostat and timers together.
let me know if this helps or we can chat if you need more help.
Posted on Aug 17, 2008
Why do we hear a water draining noise on kitchenaid superba?
Hello Mari;
My name is Peter. I am a retired field service refrigeration technician.
You have a condensate drain in the back bottom of your freezer for when you go through a self defrost mode. The defrost mode is so gradual there is not enough water flow to make a noise.
What you are hearing is your ice maker filling with water. Your ice maker will fill 8-10 times within a 24 hour period.
Dec 23, 2014 | KitchenAid Refrigerators
Why is water leaking out evey day???
Is the water leaking from the refrigerator compartment or the freezer compartment? Can we assume the "leaking" water is more than some accumulated humidity/moisture (check your door gaskets)? Have you checked all water lines/fittings for the water dispenser/ ice cube maker (if you have one)?
If it is is the freezer section, the problem may be a clogged drain line (is there ice blocking the trough drain hole?) at the bottom of the freezer (evaporator) coils? You may need to defrost the freezer, check for any faulty parts (e.g., defrost time/ADC, defrost thermo, defrost heater), and clean the drain trough/tube. See Refrigerator Defrost Parts for illustrations.
May 22, 2014 | Roper Refrigerators
Admiral ltf2112arw. Freezer fan icing, hitting blades and refrigerator not cooling well
The first thing you want to do is open the freezer and see if the fan inside there is running. The reason is the freezer cools the refrigerator side by circulating air from the freezer. If the fan is running then your problem is one or more parts of the defrost system is malfunctioned and in return your problem arises. There are three parts to the system, the defrost timer or in some cases control board, defrost thermostat also known as a bi-metal, and the defrost heater. The defrost system is set up to operate as so. The defrost timer or control board will turn the machine off, in some cases every 8 hours, some 12. During this time period the defrost heaters, located behind the freezer wall and rest underneath the evaporator, yet wires to them run up the side of it, are energized and emit heat that raises upward to melt the ice that has formed on the evaporator coils. The bi-metal or defrost thermostat is at the top of the evaporator. When the heat from the heater starts to reach the bi-metal, it breaks the circuit turning the heater off. The whole purpose of this is because the freezer cool the refridgerator side by drawing air across the coils and blowing to the other side via the evap fan motor. In my opinion, if you change one part of the defrost system change them all because usually when one part fails another will follow, so save yourself the time and the food loss, the cost difference is minute.
Jun 05, 2012 | Maytag Refrigerators
AMANA ARB 220 ZCW ice build up in freezer compartment
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system: The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited. The defrost timer The defrost thermostat (also called the bi-metal switch)
Aug 22, 2011 | Amana ARB220RCW Bottom Freezer...
The freezer section was icing over so I defrosted it. Of course the lower section had warmed up due to the freezer part icing over. Later I plugged it in and the appliance began cooling. Over an hour...
sounds like it went in to defrost after you plugged it up , if it doesn't come out of defrost after being plugged up for 30min then you need to replace the defrost control which will most likely repair your defrost problem as well
Nov 21, 2010 | Roper Refrigerators
Freezer stopped working
the freezer and refrigerator work from the same coil. you may be accumulating ice on back panel of freezer. most of times the defrost thermostat is bad.while box is cold check for continuity through defrost thermostat. if good check ohms on heater. if good you should have a standard defrost timer replace it.
Aug 04, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
In-door water dispenser not working. tried lowering temp in frig to thaw line. Worked, but now line seems frozen again. ice in icemaker holder seems to be thawing and freezer is accumulating frost/frozen...
Defrost the freezer completely. Make sure the doors are sealed completely when shut. After defrosting plug back in and make sure the fan and the self defroster is functioning (your owner's manual should tell you how to reset the defrost timer). the problem may lay within the defrost system, and/or door seals and/or interior circulating fan.
Apr 30, 2010 | Refrigerators
I have a GB2SHTXTB00. The freezer is icing and the top mount refrigerator is not cooling correctly. This is the second time in less than 1 year for this problem. I initially called a repairman and they...
I have provided you with some liinks that will help you understand how your refrigerator works, courtesy of, www.repairclinic.com A manual defrost usually consists of a hot air blower which will melt accumulated frost or ice so that normal air flow can be attained. This does not repair the unit, but it will allow temporary operation until a servicer can be scheduled. Automatic defrost Years ago, all refrigerators had to be defrosted manually. You would turn the refrigerator off, open the door(s), and allow any frost build-up to melt. When the frost had completely melted away, you would turn the refrigerator back on.
Today, all but the smaller, apartment-sized refrigerators are self-defrosting. Self-defrosting means what it implies--though frost continues to accumulate inside the refrigerator, it melts automatically. The self-defrosting system has three functional components:
1.Defrost heater
2.Defrost thermostat.
3.Electronic Control
4.Thermistor
1. Defrost heater The defrost heater is similar to the burners on an electric stove. It's located just beneath the cooling coils, which are concealed behind a panel in the freezer compartment. The heater gets hot. And, because it's close to the cooling coils, any ice or frost build-up melts.
As the frost and ice melt, the resulting water drips into a trough. The trough is connected to a tube that drains the water into a shallow pan at the bottom of the refrigerator. The water is then evaporated by a fan that blows warm air from the compressor motor over the pan and out the front of the refrigerator.
2.Defrost thermostat The process ends after either the amount of time specified on the timer or when the defrost thermostat near the cooling coils senses that the heat near the coils has reached a specific temperature.
This part controls all functions and may be the number 1 item causing the problem. You will need to locate the trouble-shooting instructions, (usually in a shipping envelope somewhere behind the toe plate, under the freezer compartment)
4. Thermistor
This is a monitoring device and is usually not a suspect part.
http://www.repairclinic.com/Refrigerator-Freezer-On-Bottom-Appliance-Diagram
1. Defrost Heater
http://www.repairclinic.com/SSPartDetail.aspx?s=t-GB2SHTXTB00-%3d%3di1022690&PartID=1022690
2. Defrost Thermostat
http://www.repairclinic.com/SSPartDetail.aspx?s=t-GB2SHTXTB00-%3d%3di1033990&PartID=1033990
3.Electronic control
http://www.repairclinic.com/SSPartDetail.aspx?s=t-GB2SHTXTB00-%3d%3di1394438&PartID=1394438
4.Thermistor
http://www.repairclinic.com/SSPartDetail.aspx?s=t-GB2SHTXTB00-%3d%3di1057227&PartID=1057227
Aug 14, 2009 | Whirlpool Refrigerators
Loud noise from refrig.
The defrost timer is faulty. replace it asap.
Jun 25, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
No Defrost
call service center for the repair of your refrigerator, they will bring it to their repair shop,because they need to dismantalled the unit to replaced the heater`s thermestor. the thermestor was been busted that cause the heater not work out,then in conteneous operation of compressor will cause of ice build up.
Nov 20, 2007 | Refrigerators
Refrigerators Logo
151 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
