Question about Kenmore 3.8 cu. ft. HE4t Front Load Washer
HOW DO I CHANGE A MOTOR IN MY KENMORE HE4T MODEL 110.45986402
OK, THROUGH THE HELP OF OTHERS ON THIS WEBSITE I HAVE ISOLATED MY F06 PROBLEM TO MY MOTOR. I HAVE ORDERED A REPLACEMENT MOTOR PART NUMBER 8182793 AND AM WONDERING IF I SHOULD ATTEMPT THIS ONE MYSELF OR SUB IT OUT TO AN APPLIANCE REPAIR PROFESSIONAL. ANYONE KNOW OF A STEP BY STEP GUIDE FOR THIS REPAIR FOR A HOME REPAIR?
  • ONE4BRI Aug 17, 2008
    MODEL NUMBER 110.45986402
  • ONE4BRI Aug 23, 2008
    WOW, IT WAS EASY. I DISCONNECTED A FEW WIRES AND REMOVED THE 1 BOLT. GLAD I DIDNT WASTE MONEY FOR A TECH. THANKS
2 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: Kenmore HE4t washer has an F06 code
"F06" is a motor speed error code. This means there is a problem with either the drive motor, motor control unit (MCU), or interconnecting wiring. The following link explains:
http://www.fixya.com/support/r714929-f06_error_whirlpool_duet_kenmore_elite
I would begin by attempting to reset the Central Control Unit (CCU). This is the main computer for the washer. Sometimes these error codes can be erroneous. If you unplug the washer for at least 30 minutes, this will reset the CCU. Often, this is all that is required to correct momentary glitches. If the error code reappears following a CCU reset, then you have a legitimate problem.
If resetting the CCU doesn't work, verify all your connector plugs on the drive motor and MCU by unplugging and replugging each one (one at a time). Sometimes these connector plugs can vibrate loose.
If these preliminary steps don't work, follow the advice in the link provided. If you have any questions please let me know. I hope this helps you.
Posted on Jul 17, 2009
I have the F06 error code on my he4t washer. I've checked online with all of these "fix it" sites and had an electrician check the motor. All of the connections and the motor are fine. How...
The MCU is the motor control unit its in the lower panel down on the bottom
The CCU is the central control unit and it is up in the top behind the touchpad/cycle selector
Sep 23, 2011 | Kenmore Elite 45986 Front Load Washer
What does F06 mean?
F06 error code indicates a motor tachometer failure on most Kenmore Elite front load washers. There are many different models, so I would need the model number of your washer to be sure.
This type of problem could be caused by loose wiring connections between the motor and the motor control board. It could also be caused by loose wiring connections between the motor control board and the main machine control board. Other problems that could cause this fault code include:
A failed drive motor.
A defective motor control board.
A failed main machine control board.
Hope thie helps (remember to rate and comment this answer)
Jul 02, 2011 | Kenmore Elite 45986 Front Load Washer
Jul 17, 2009 | Kenmore Elite 45986 Front Load Washer
F07 occurs at end of first rinse cycle
F07 - Motor Control Unit (MCU) Error - Disconnect power and unplug unit. Check wire harness connections between drive motor and Motor Control Unit (MCU), and between MCU and the Central Control Unit (CCU). Reconnect power and plug unit in.
Check the MCU by looking for operations of the drive motor, and check drive motor for powered rotations. Replace failed component.
Note: If this failure occurs during high-speed spin, the door will be unlocked after three minutes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 26, 2009 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
HE4t Washer
"F06" is a Motor Speed error. The following link explains how to troubleshoot and some common causes:
The first step to troublehsooting should be to unplug the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). Sometimes this is all that it takes to correct momentary glitches with the unit. If the error code reappears following a computer reset, follow the advice given in the link I provided.
If you have questions, or require additional assistanc, please let me know. I hope this helps you.
Jan 23, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore HE4T Elite F06 problems
Given I had purchased the Extended Warranty, Sears replaced the washer. So, we will see how this one works.....
Jan 04, 2009 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Kenmore Elite he3t model 11045972404
POSSIBLE COMMUNICATION PROBLEM BETWEEN MAIN AND MOTOR CONTROLLER
Nov 22, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
WILL HE4T RUN WITH KICK PANEL AND BACK PANEL OFF?
The washer will run without the panels in place. As a technician it is common practice to troubleshoot with the bottom panel and/or back panel removed in order to see if certain components are working. The "F06" error is a motor speed problem. With this fault, the washer will shut down if the motor speed is not detected, or reach optimum rpms. The fault is usually caused by a failure of the Motor Control Unit (MCU) or Drive Motor. The following link explains how to troubleshoot:
If you require addtional assistance, please let me know. I hope this helps you.
Aug 17, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
HE4T F06 ERROR
Wow. Sounds like you've had your hands full with this one. Well, since you've already gone the route of replacing the CCU and MCU, more than likely you have a wiring harness problem and/or drive motor issue (as you have already explained). The following link explains the "F06" error and how to troublehoot:
Review the information and double check to make sure you have overlooked anything. Unless, you have purchased defective replacement parts, I can only assume the motor and wiring. Unplug the washer and perform resistance checks on the motor windings. If you have a multimeter handy, this would be on the RX1 scale. The pin locations are mentioned in the link provided. Each motor winding should read 6 ohms or less. On another note, the vibration problem you mention, was definitely caused by the shocks not being mounted properly. You may consider replacing them, since you said you're still experiencing vibration issues.
If you are still confused by anything, please let me know. I hope this helps you.
Aug 16, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
KENMORE HE4T STARTED AS BALANCE AND F11 NOW ITS F06
ck all the connectors to both boards and motor you may have inadverantly left 1 loose or knocked one off during previous repair
Kenmore 3.8 cu. ft. HE4t Front Load Washer Logo
Sal DeAngelo
fordexpert
Ed Mac
