The TV does not come on. When I try to turn it on the power indicator light at the on/off switch blinks on and off three times.
  • 54 Answers
This "blinking" is a service code. In other words something is wrong with your set and its telling you this. You need to have the set looked at by a professional. Usually you can call a repair shop and they can give you an estimated price over the phone. Good luck!!
Posted on Aug 17, 2008
LG 32LM3400 turns on and light flashes three time but no picture
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Jun 24, 2016 | LG 32LM3400 32" LED TV 1366x768, 100 Hz,...
How do I fix my KDL55HX750? It will not turn on. No sound or picture. Just 3 blinking red lights. What should I do next?!?
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
Jan 26, 2016 | Televison & Video
My standby light blinks three times but tv never comes on
These blinks are fault indication, and known as blinking codes.From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV.This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/.If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC.
Dec 22, 2013 | Sony KDL55EX620 55 inch BRAVIA 1080p LED...
My tv wont turn on by power button or remote. white light keep blinking.
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/. If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC.
Dec 14, 2013 | Sharp AQUOS LC-60LE632U 60-inch 1080p LED...
Why doesn't it turn on?
Dec 10, 2013 | Toshiba 42TL515U 42 in. 3D TV
Samsung DLP HL-55086W lamp light flashing slowing just after replacing lamp
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
Aug 15, 2017 | Televison & Video
Heard a pop , bulb blew out , replaced bulb , it worked for two days , now red light blinks three times pauses then three times and so on , tv won't turn off light won't turn off unless I unplug...
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Oct 26, 2011 | Sony KDF-E42A10 42 in. LCD Television
Sony 3 lcd rear projection tv hd w/ wega gate. kdf-e42a10. tv will atempt to turn, shuts down, greem power light blinks 12 times on average. red standby light blinks 4 times. i replaced lamp [ xl 2400...
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Mar 02, 2011 | Sony KDF-E42A10 42 in. LCD Television
TV turns off but standby still blinking
Hello
Blinking of standby light in Sony sets are fault indications. Just count the number of blinks occur at a time, after switch OFF and switch ON your TV with its FRONT PANEL POWER CONTRO SWITCH. Make this test at least three times, and count the number of blinks keenly and inform me though Fixya. It will help me a great to rach to the faulty section, or even to the exact fault point sometimes. OK.
Feb 17, 2011 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
I have Sony 40inch breviary. My tv is not turning on I reset tv but it still not working. Stand by light keep blinking but tv is not turning
Hello
Blinking of standby light in Sony telivisions are fault indications. You just count the number of blinks occur at a time when the set is switched On with its FRONT PANEL POWER SWITCH. Count it three or more times, and make sure about its number of blinks and inform me through Fixya. From that number, I can get into the fault section, sometimes more accurate to the location of the fault. Count it Keenly for at least three times and make sure before reporting. OK.
Jan 18, 2011 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
