Question about Olivetti Lettera 25 Typewriter
Olivetti Lettera 22 - carriage jammed
Carriage appears to be stuck, but what the (German) instruction leaflet indicates to be the carriage lock mechanism is not engaged. Typing and the tab and space bars do not solve the problem. There is a tiny bit of give in the carriage - it moves about a millimetre either way when pushed and springs back - the resistance sounds solid and metallic. I've taken the back off but can't figure out what's wrong with it. The carriage is jammed fractionally off-centre (left).
Otherwise seems to be in excellent working order/
Any help extremely gratefully received
  • samanthajayn Aug 18, 2008
    Yeh - I've checked the lock mechanism already - it's not engaged. SO it must be a dfferent problem. But thanks ever so much for trying anyway!
  • fairy_frog Feb 11, 2009
    I have the same problem for a Lettera 22.. Did you ever work it out?
THERE IS A CARRIAGE LOCK ON THE MACHINE IF I REMEMBER RIGHT IT'S SO THE CARRIAGE DOSENT MOVE WHEN IT IN THE CARRING CASE. LOOK ON THE LEFT AND RIGHT END OF THE CARRIAGE JUST BELOW THE PLATEN KNOBS OR IT MAYBE A LEVER ON THE SIDE OF THE KEYBOARD
Posted on Aug 18, 2008
Olivetti Lettera 22 Typewriter carriage does not move
There are two ways to deal with that (before taking you olivetti to an authorized dealer):
  1. There's a lock key under the carriage. Have you unlocked it?
  2. The carriage might have been locked by a piece of paper or something else. Release it (pull it) and clean its passage (there is a button you press in order to release it - proceed with care).
Apr 09, 2016 | Olivetti Office Equipment & Supplies
Olivetti Lettera 32 typwritter carriage doesn't move
If the locking lever is off, then the carriage is bound, or one of the tabs is hung, try releasing all the tabs, pushing the space bar or the tab key while gently moving the carriage.
Try all of the function like shift while gently pushing on the carriage always to the right..
also check the that the margins are not locked.
This could be a lot of different things...
Dec 18, 2009 | Olivetti Lettera 35 L Typewriter
Did anyone answer the problem of unlocking the carriage on the olivetti lettera 22? thankyou
There is a small lever on the right side of the machine under the carriage that is meant to lock the carriage for transport. Press this down.
Nov 08, 2009 | Olivetti Lettera 25 Typewriter
Olivetti Lettera 32 typwritter carriage will not move?
There is a lever in front of the right knob that is used to lock the carriage.
Aug 31, 2009 | Olivetti Lettera 35 L Typewriter
Can't find carriage lock on Olivetti Lettera 25
Learn how to unlock the carriage in Olivetti Lettera 22 Manual posted by Ed Cornish (Carriage Locking Lever 7). It is a different machine model, but the lock/unlock mechanism might be the same.
You can see the full manual at Ed’s Flickr account or you can download it from here: http://dl.getdropbox.com/u/1322442/Olivetti%20Lettera%2022%20Manual.pdf (temporary link)
Aug 28, 2009 | Olivetti Lettera 25 Typewriter
What is carriage lock ?
Carriage lock locks the carriage in the center so that it does not move around when you put it in the carrying case.It should be a metal slide on the frame.
Jan 24, 2009 | Olivetti Lettera 25 Typewriter
Olivetti Lettera 32 - carriage progression problem
Could be the carriage release lever is jammed or worse the escapement dog is broken.
Jul 12, 2008 | Office Equipment & Supplies
Carriage release
try jiggling the carraige around a bit and then try using that lever thats on the right side of the carraige. you might even try both at once to see what frees it up. i had the same problem and it worked for me. That's the right tab, it may be in a jammed position so it wont open properly.
Apr 26, 2007 | Olivetti Lettera 25 Typewriter
How do you unlock a locked carriage?
The solution is not right--there is a carriage return release lever on the far right of the typewriter, that engages a notch on the underside of the roller/carriage return--push it forward to release the lever and you are in business--it has a spoon shaped end and its on the right side
Jan 24, 2006 | Olivetti Lettera 35 L Typewriter
Olivetti Lettera 25 Typewriter Logo
1,049 people viewed this question
Top Olivetti Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
Coss
Are you an Olivetti Office Equipment and Supply Expert? Answer questions, earn points and help others
