Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA D52W20 Resetting Factory Setttings to Get Clear Picture
I have a RCA D52W20. The flyback went out and was fixed correctly. However, the settings are all out of whack and focus. Does anyone know how to get the correct factory settings, so the picture will look how it suppossed to. Any assistance would be greatly appreciated.
  • jfjuett Aug 20, 2008
    my tv has a convergence problem there is and extra red and blue tint to all immages and the picture arcs on all four sides and i cant get the picture to change formats at all plus the sound seems to be snowy!! i bought my tv new from walmart and its only a year old!! i wonder how much repairs would run me (in home)
  • Anonymous Sep 26, 2008
    I can't see part of the screen
First, I'm no expert, just a retired navy electronics tech.
I BELIEVE that your model can have one of two different chassis. If you have the Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} ITC222 chassis, then look at http://home.austin.rr.com/doctorjoe/ITC222align.pdf
for the alignment instructions.
SAFETY NOTE: While you should not be touching any enegergized components while performing this procedure, you will be working in the presence of and right next to EXTREMELY HIGH and DANGEROUS VOLTAGES that can exceed 30,000 Volts. If you're not familar with the electrical safety precautions for this type of procedure, please have a technician perform this task.
That said, hope I helped and best of luck.
Posted on Aug 20, 2008
I have a RCA d52w20 that's giving me a 3d affect
The part if near the flyback will kill the convergence adjustment being seen in the menu.
Set has issues (three similar parts) for bad solder connections at the flyback and a kit is available for the protect part (includes that part and a filter cap and diode with instructions-----------
Not a easy set to work on in many ways............
May 20, 2012 | RCA Televison & Video
I have an RCA D52W20. Went to turn it on and the power blinked 2 or 3 times but will not turn on.
Thats a very comon and easy repair. The Flyback and CP150 and CP114 need to be replaced. The flyback is number 259296. The following link has the replacement parts and provide free installation instructions with detailed pictures.
http://servicemanuals.vstore.ca/
Jun 13, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52w20 No picture
I dont believe that you need a new CRT. It sounds like you have a solder issue around the flyback, thats a common problem with the ITC222 chassis when the symptoms your describing are present. I would try resoldering the flyback and surrounding components and see if that doesnt correct your problem.
Aug 04, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca 61 projection not powering on
what is the issue? The flyback is the transformer that generates the high voltage needed for the picture tubes. the itc222 rca chasis can have problems with flyback but they are notoruis to trouble shoot. if if it is you flyback then you will possible have other issue like the horizontal ouput transistor. I work with these alot here at the shop. what is set doing .. does the led flash .. give me some more information and lets see if we can fix this
Jul 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 flyback question
If your model number is D52W20 you need flyback number 259296 and you can get a new flyback at the following link and they will givce free online tech support to walk you through the removal and replacement procedure.
Jul 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Green light blinking 3 times....
If your model number is the D52W20 RCA the 259296 is the flyback that your model uses. They just dont list all the models that the 259296 uses. The 265409 is the same flyback but for GE models the mounting tabs are a little different but they are both the same elctrically but the 259296 is for the ITC222 chassis which is the D52W20. They dont have a link for flyback instructions what they do is sign you up for instant messageing when you order a flyback so they can explain the proceedure while youre doing the repair, as a flyback is simply unsolder the old and solder in the new. It takes only a few minutes to do the job.
Jul 08, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
A rca d52w20 hdtv
If you can solder you can fix it ! solder all pins around flyback transfomer.
ThankYou for using FixYa. Have a Nice Day.
Feb 05, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HD27F754T Has sound and no Picture. Any ideas?
YES RCA has big problem with these sets bad flybacks,high voltage tripplers and convergence problems ! Ive got 2 of them in shop now one started out with only convergence problem solder around flyback pins now set will not come back on.as soon as i learn more i will post it!
Jan 13, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
165 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
