Question about HP OfficeJet 6110 All-In-One InkJet Printer
HP 6100 All in One malfuntins when powering up
I recently moved this machine to our loft and when I powered it up it seem to lock on a scanner function and then I get a "Scanner Failure Error" Turn power off then on. When I do this it just does the same thing a gain.
  • 2 more comments
  • pampin7 Aug 21, 2008
  • excelynn Oct 15, 2008
    I "inherited" this machine and was just starting to learn how to use the scanner. I was in the process of several sucessful scans and then I got a scanning error, "cannot connect to PC"!? From that point on I couldn't print either. I am NOT very technical but I decided to remove and reinstall the drivers which got my printing back but not the scanner. I also made a color copy so I know the scanner light can "move" however sometimes when I shut it down and power back up, there is a clicking noise as if a gear is stuck. I've searched the web for suggestions including directly plugging the power cord in to the wall rather than a power strip but nothing has changed. Any help is most welcome.
  • yayita Nov 05, 2008
    my printer says scanner failure i turned it off several times and it continues to do the same thing
  • Mike H Aug 29, 2012
    I had this problem with mine - same clicking noise, same error message. I tried the power off/power on thing multiple times, too, with no luck. It seemed like the scanner light bar was trying to move all the way to the right and that's what was causing it to click. On a whim, I powered down, stood the printer up on its left side (so gravity would help keep the scanner head from going all the way to the right), and powered on. It powered up fine and works again! Your mileage may vary, but it's worth a try...
Posted on Aug 29, 2012
  • peter
    peter Oct 17, 2013
    Wow. That also worked for me... :)
  1. my all in 1 powers up but does nothing
Posted on Oct 28, 2008
  • 28 Answers
Fiend your solution direct from hp. Here is your solution...
http://www.hp.com/printer/prob676ijt65/solution
796
Posted on Feb 28, 2009
  • 35 Answers
Hello!
i have here a link below from hp website.. this a document on how to resolve the scanning error message. click the link below and try to follow the steps...
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00787271&dlc=en&product=79477
Posted on Aug 29, 2008
Thanks, my HP LaserJet 9000MFP is requesting for cable check it say check cables. check scanner lock. cycle power
This error is an indication that the system is unable to move the scanner. This usually happens on new units when someone forgets to unlock the scanner before switching machine. If the printer has worked up till not and just started doing it then there is a good chance that the scanner has failed and will require service. If you just moved the machine then check the scanner locks and make sure the cabling is all connected.
Aug 09, 2011 | HP LaserJet 9000mfp Printer
Workcentre M20i Scanner Locked, I tried flipping the switch still doesn't work.
I am not sure which switch you are talking about.
The machine has a power switch, and a scanner lock switch.
The scanner lock switch is located in the area where you take the copies out of the exit area, it is just above the knuckles of your hand. If you lean over look under the bottom of that scanner, there is a green sliding selector switch with a picture of a pad lock. Power off the machine, then move it to the unlock side. Then turn on the machine, see how it works ok.
Good luck.
Sep 26, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Readoout says
1. Turn machine OFF and unplug electrical cord from wall or power strip.
2. Turn ON printer without the power cord plugged in (this will discharge the power capaciter in the printer).
3. Plug electrical power back in and turn on printer...
4. It should have reset.
Another possibility:
The scanner arm has the physical "lock" switch in the locked possition. Turn OFF printer and move the switch to the unlock position. Turn on printer.
This switch is for whenever the printer is moved to a different location and will protect the scanning bar.
Hope this helps!
Sep 09, 2009 | HP OfficeJet G85 All-In-One InkJet Printer
When I turn on the power to the printer, the print carriage cycles to the right as normal then carriage sticks and begins to continually chatter.....at the same time the light bar on the scanner trys to...
There is usually a sensor on one side or the other of the carriage. When you power up the machine, the carriage will be moved to that end, setting off the sensor. Then it will move back and forth to test carriage motion. If the end sensor is faulty, the carriage will still attempt to move until it triggers the sensor, but when it gets to the extreme end, the motor will continue to attempt to move it, causing the chatter. After a time, it will stop with an error message.
Look at the carriage where the cartridges are, and you should see some kind of tab or ear on it. If it's broken, then you may get the symptoms I mentioned above. Also if you can see the sensor, make sure that it's not broken or moved out of place.
Mar 15, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Scanner Error power on power off
there is a sensor in the paper feeder tray which is also connected to the scanner area that sensor is bit moved from its orignal position or is slightly broken while the paper jam or while removing the paper jam.
please check the sensor.and make it proper.the error will go.
Oct 05, 2008 | HP LaserJet 3330 All-In-One Printer
5470C scanner: on plugging in to ac pwr, getting flashing lights only
yes folks it is the power supply,
replacments are hard to find but you can make your own, see seperate problem on this site. easy if you just want the scanner harder if you need the adf as well
goodluck
kpm
Sep 25, 2008 | HP Scanjet 5470c Flatbed Scanner
Visioneer One Touch 8700 USB Scanner lock mechanism problems
Not sure if your problem is the same as mine, but I encountered the same error and only to find that I plugged in a wrong power adapter so it didn't have enough power to advance the scanner head (My moving caused this mixup). Check your power adapter OUTPUT is 12V (or whatever is specified on the scanner itself, usually found on the label on the bottom or rear).
Jul 25, 2008 | Visioneer One Touch 7600 USB
Trouble shooting
The "car sound" could be an indication that the scanner is locked. Check the lock switch on the bottom of the scanner. Move the switch back and forth a few times and then leave it in the locked position. Another possibility is that you are scanning heavy items such as books. If too much weight is placed on the scanner glass, then pressure could be enough to prevent the scanning element from moving as it should.
The code 201 sometimes can indicate a power issue...meaning the scanner is not getting enough power. Try connecting the usb cable to a different port on the computer (preferrably directly to the computer and not through a USB hub).
May 20, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
HP OfficeJet 6110 All-In-One InkJet Printer Logo
951 people viewed this question
Seeker5211
Seeker5211
