Question about Panasonic PT-47WX49 47" Rear Projection Television
Thanks Thank you for the information for my panansonic projecton tv. I hope that it works out. It is a relief to know that I don't need to change the resistors! Thanks, Renee Smith
  • Panasonic Master
  • 8,617 Answers
That model will usually just need new ICs as long as the set didnt shutdown and not power up.
Posted on Aug 17, 2008
Unlock code panansonic tv
0038,6668. Try these codes.For more information http://electrohelponline.blogspot.com/Setup procedure, and setup code list to many popular remote controls are given.Pull up older posts.
Nov 30, 2013 | RCA L32HD31 32 in. LCD HDTV
My remote won't change from AUX to Tv and all of the buttons don't work on AUX except for the volume and mute, how do I get it back on tv? Thank you
Try to push the TV button that is lit red at top middle of remote for 5 seconds in stead of hitting input. In other words by holding the tv button down it might trigger it to respond better. Thanks Mike
Apr 07, 2013 | Televison & Video
Hello, i just bought an lcd Tv converter made by manhattan. the model is 176156. the problem is in the video section, don't let me change the standards (NTSC, PAL, PAL-NC, etc) want to know if there
I think you press the wrong button that change the settings of your TV to restore it original settings kindly go to menu and find factory settings then press enter..
hope it helps..
Dec 11, 2011 | Manhattan LCD TV Converter/Tuner (176156)...
Lost User manual for Panansonic DMR BW750 Blu-ray recroder
You can download and print the instruction manual for Panasonic DMR BW750 in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
Jul 28, 2011 | Televison & Video
Is it possible to clean the inner side of the glass front screen from my panansonic TH42-PZ80
Anything is possible! It would be a lot of work because you have to totally disassemble the tv to get it broken down far enough to do that - and also make sure you dont break either of the glass when disassembling or reassembling.
thanks,
Michael
Apr 05, 2011 | Panasonic Viera TH-50PX80U Plasma TV
The TV just shut off and won't turn on, only a year and half old panansonic th-42px80u
Usually when TV sets just go off and refuse to come on it usually is a problem with the power unit of the set. Would be best refered to an expert to help trace the exact conduit which is burnt. Should just take a little replacement of a conductor and you set will be working fine as before.
Hope this solution has been helpful?
Nov 28, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
Connect Bose System to Panansonic TV
in the tv setup menu there should be an item that will allow you to change the volume from variable to fixed on the output of the tv
Dec 07, 2009 | Panasonic Audio Players & Recorders
Tv won't come on
I had the same problem took it to the repair shop and they replaced the bulb.Works fine now.
Bulb cost 199.00
Jan 25, 2009 | Hitachi 60V710 60" Rear Projection HDTV
Connections on back of TV
You can download the manual from the link below: http://www.emersonaudiovideo.com/pdf/om/EWL3706.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 16, 2007 | Emerson EWL3706 37 in. LCD Television
Panasonic PT-47WX49 47" Rear Projection Television Logo
24 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
