Question about KitchenAid KESA907PSS Electric Kitchen Range
Kitchen Aid Range purchased 1/06. Had to replace (very expensive over $350) the touchpad in 1/08. Now it's 6/08 and the touchpad is not working again - most buttons works but the off button doesn't so you have to throw the breaker to turn off stove. Ever heard of that? I am having the same problem with my oven controls. All other functions work properly. The only way I can turn off the oven, though, is to unplug the unit for a couple seconds.
  • akbarhussain Dec 06, 2008
    I have exactly the same problem. I bought the range brand new from sears in dec'05. the first time the "off switch" stopped working was in sep 07. I only then discovered that unlike everything else on the range the touchpad was not covered under the warranty, so I ended up footing the bill for $330.00
    Anyhow, just 12 months and 20 days after the replacement, the exact same problem has occured (just 20 days after my warranty expired on the replacement) I am quite shocked and upset that a premium brand such as KitchenAid has failed to make a recall on this product, which clearly has a manufacturing defect.
  • 25 Answers
Sorry but it sounds like the panel again.. i replaced mine after a boil-over and when i replaced it, i added a silicone bead under the panel along the top to stop the problem from recurring..
i've never seen engineering so poor.. there's no way that the engineers are this stupid so they must have done it on purpose to keep their repair network in business.. lol
good luck
Posted on Jul 22, 2009
  • madann904 Apr 30, 2011
    I bought a new panel due to the same problem, but depsite losening all the bottom screws can't remove the panel. Can you let me know how to get it off without breaking anything?
Kitchen Aid range KGRA806PSSOO it was in the self cleaning mode touchpad went black and door is locked ,what happened ?
Check to be sure that the unit did not trip the breakers. If the breakers are good, you will need to replace the control board. Here is the part to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 25, 2012 | Kitchen Ranges
Kitchen Aid range: error code F1E0 replace oven UI
F1-E0 = EEPROM communication error
1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock). If you bought this control board used I am afraid it is bad. That error is only for a bad control board.
Here is a new board you may purchase. It is a little expensive but the supplier has a 365 day, any reason, any part return policy and you can be certain that you have a quality part.
Nov 10, 2012 | Kitchen Ranges
Purchased GE Profile dual fuel range 6 months ago. Clock has always run fast and today the entire touchpad control went dead. The oven light works as does the gas burners. I am not sure if I inadvertly...
Unplug the unit and wait 2 FULL MINUTES before plugging it back in. That will reset the circuit board and you should be good to go. If it doesn't work, my bad!!!!!!
Apr 17, 2011 | GE Profile JGSP44 Dual Fuel (Electric and...
My Kitchen Aid modelKGRC608LSS is not working on
Well it sounds like it is either the control key pad or the ERC(control module) is defective. The first thing you will need to verify is the condition of the ribbon cable that goes from the control pad to the ERC. You will need to unplug the range from the electrical outlet and then remove the back panel of the range. Now inspect the ribbon cable for any visible defects to it. Sometimes the cable will arc across itself and cause a short. Inspect each one of the lines(wires) on the ribbon cable and make sure they are not shorted. Now check to make sure the cable is found properly seated. If it is found loose or mis-aligned then remove and re-install it properly. You can also use a pencil eraser to clean the contacts on the ribbon cable while you have it dis-connected. Also verify that the wiring harness is properly seated and there is voltage going to the ERC. Hopefully these steps might get the range working again. The top burners/igniters can still work even if the touchpad or ERC is bad because they do not control the circuits for the igniters(they are mechanical switches) and mechanical burner valves. If not you might need to replace both the ERC and the Touchpad in combination to get the range to work again.
Apr 11, 2010 | KitchenAid KGRC608LSS Gas Kitchen Range
Kitchen-Aid Electric control panel buttons stopped working
This may sound facetious, so don't get offended.
Did you set your clock to the correct time?
Did you clear any and all preset timers?
If none of that helps you can usually find roaches in the strangest places. If you have no roaches, then moisture and heat are the likely culprits which means that your blister pads are simply worn out. Unfortunately these are coated with graphite and don't last forever, so a timer replacement would be your only option unless your touchpad is separate from your timer.
Mar 05, 2010 | KitchenAid KERC507 Electric Kitchen Range
Dacor PGR 30 oven does not heat
I have had the same miserable experience - replacing the brain, touchpad, expensive parts - for this supposedly high-end appliance.
Have you checked the ignitor bar? See a good explanation of that at
and also
Nov 23, 2009 | Dacor Preference PGR30 Gas Kitchen Range
LG Range Touchpad Not Working
The touch mebrane is faulty and needs to be replaced.
Sep 03, 2009 | LG LRE30451 Electric Kitchen Range
Large element burns high
The problem is in the switch not the element.
Mar 24, 2009 | KitchenAid KERC507 Electric Kitchen Range
Kitchen Aid KESC 307 hbs4 electric range control
oven not workin very well might be a control issue, but top elements work completly seperate from oven control, and theres 2 electronics there $200 for touchpad galss assy and $375 for electronic timer, and switches for the burner might be make sure I trusted the repairman's diag before proceding
Feb 23, 2008 | KitchenAid KESC307 Electric Kitchen Range
I hate to say it, but the touchpad or computer board needs to be replaced. VERY expensive...goodluck
Nov 21, 2007 | Frigidaire FEF455BB Electric Kitchen Range
KitchenAid KESA907PSS Electric Kitchen Range Logo
149 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
