Question about Sewing Machines
Singer 6233 - broken bobbin case
My bobbin case broke and I need to replace it. Where's the cheapest place to buy a part and how do I install it once I get it?
You can order one online, I am not sure about shipping costs.
I jsut bought one for $15 at my local sewing store.
Posted on Oct 21, 2008
Bobbin case wont stay in place when I sew
Most bobbin cases have a latch that must be released to remove or install in the machine. Be sure to hold the latch open while you insert the bobbin case into the machine. Rotate the bobbin case slightly until it feels seated. Then release the latch. If the bobbin case is not latched in place, it will continue to fall out whenever you begin to sew.
Apr 01, 2015 | Sewing Machines
Bobbin case
I would recommend using an authentic bobbin case and bobbins for your Bernina. Your dealer will have them. Just be sure to tell them the model you have.
FWIW, you can remove the shuttle hook and bobbin case by turning the 2 little black levers at the bottom right and left in the bobbin area, Once you do that, the circular piece that holds the bobbin mechanism in place can drop down and the bobbin case and shuttle hook can be removed as one unit. You should probably do this frequently to brush out the lint and debris and to oil the "shelf" where the hook resides. Oiling the hook shelf should be done about every 8 hrs of sewing.
Here's the manual for your machine:
The aurora 440 QE sewing machine for everyone and every application
Nov 29, 2017 | Bernina Sewing Machines
I broke a needle while sweng,now my needle hits my bobbin case on my 2030
it's very possible that when you broke the needle it caused the machine to go out of time & would have to be retimed at a sewing machine repair shop
Mar 12, 2012 | PfaFF Tiptronic 2030
I broke a needle and now it wont pick up bobbin tread
Make sure the needle is facing in the correct direction,stitches don't form, or skip badly when the needle is turned around.
Put the bobbin in the bobbin case (right way around) leaving a 2-3" tail.
Thread the top of the machine correctly, leaving a 3-4" tail after threading the needle.
make certain your bobbin in locked into position in it's case and the thread is coming from the bobbin in the correct direction. When holding my metal bobbin in my hand, the thread pulls counter clockwise before placing it into my front loading bobbin case.
Also check if the needle is not properly installed in the needle bar,the machine is not threaded properly or the machine needs adjustment or repair..
Feb 12, 2011 | Euro-Pro 416 Mechanical Sewing Machine
Janome 11000SE - the bobin case keeps spinning and won't stay in place. I am on my 3rd one. I just had it in for a check up and they said nothing was wrong with it. They put in a new bobin case though, and...
Once the bobbin case is damaged you need to replace it or the problem only get worse. If you are on your third case then something is not right. This machine does not have that kind of history of problems with the bobbin case. Typically this kind of problem is caused by the thread not being inserted into the thread take up lever correctly. (this is the lever that moves up and down when you sew and you see it at the top when you thread it) There is a small spring gate that the thread needs to pass thru when you thread it, There could be a problem with the positioning brackets that hold the bobbin case in place so I would explain that you feel three bobbin cases replaced is excessive and you need some help in getting the problem corrected.
I have assumed that the dealer is replacing the cases for you, if you are just buying the case and putting in yourself, then the problem may well be the brackets, Good Luck!
May 25, 2010 | Sewing Machines
Singer 4562 t bobbin case won't fit properly, what am I doing wro
Make sure the bobbin case sets sort of on top and not under the ridge of the metal ring. There is a small latch on the upper left of the bobbin case. It is metal. rotate the latch to cover the bobbin case and this should stabilize the case without making it immobile
Jan 27, 2010 | Singer 7442 Mechanical Sewing Machine
Replaced Singer 5932 bobbin case, need help. *pics*
there may be uneeded friction occuring. are you sure you inserted it correctly? sorry. photos aren;t appearing. but it may be that it is the wrong type or in the wrong place. do some trial and error and fit it into different positions on the bobbin runner
May 11, 2009 | Singer Sewing Machines
Bobbin case is moving out of place
I was having the same problem with my machine and finally the spring broke. I couldn't find any parts for this so my husband made me a new spring out of a coke can! LOL!! Anyway, he messed with it for a while and it kept doing it. He figured out that it was not the spring but the other piece under the spring was not pushed up far enough to keep the bobbin case in place so he took a screw driver and pushed it forward toward the bobbin case and now my bobbin case does not move!! And the machine is sewing perfect! At least for now. Anyway, it's not the spring or the thread adjusting screw!
Jun 06, 2008 | Brother CS6000i Computerized Sewing...
Bobbin case
If your machine is older than 18 months, it needs a free upgrade from your dealer. The plastic see through needle plate needs to be replaced by a newer version that will keep the bobbin down. Further more a bobbin case position finger needs to be installed.
Nov 06, 2007 | Singer CE-200 Quantum Futura Computerized...
Sewing Machines Logo
670 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
