Question about Gateway FPD2275W LCD Monitor
Im constantly getting an error code of 800 32 704
Certain programmes that i try to open in my computer i get an error code of 80032704 and so am unable to go into quite a few programmes on my computer i have tried to look up the code but i find everything help wise so un helpful and confusing
  • 981 Answers
LOL what is the title of the message box?  It's obviously not a problem with your monitor. In general it would be your OS, security policies, and antivirus or VM controls responsible for that code.
     Moreover, it would be the fact that you don't know to what code 800 32 704 corresponds.  I can't help but think this relates to the problem where 14,000 laptops go missing in airports every week (seen in El Reg, I think) and that you've found yourself with some Emir's work in your lap.  So fat luck to you both.
Posted on Aug 18, 2008
6ya staff
SOURCE:
Zanussi zdt 6053 usually will not run full cycle (on any cycle) but stops with constant error beeps. But it is draining ok and sometimes goes full cycle (not often) Any ideas?
Could be anything!
If you suspect that there is a fault then it will be displayed by blinking LED "END OF CYCLE". As the display of failure in hexadecimal code it can flash up to max. 15 times than short pause and after that repeat fault code. You must to count the number of times the LED "END OF CYCLE" flash up.
Example from user manual: Anti-flood device is activated.
- continuous flashing of the indicator light of the running programme
- 3 intermittent audible signals
- 3 flashes of the END OF CYCLE indicator light
(which means "i30" fault code, the cycle is interrupted and the
drain pump switches on).
Possible causes:
Water leakage from the tub - sump and various connections
(pump, upper spray arm duct etc.); floating sensor blocked
mechanically; microswitch faulty; fill solenoid blocked
mechanically; circuit board faulty (solenoid triac short-circuited);
wiring faulty.
26226179-aipk5px1bmfkdpsmrgevaqwn-3-1.jpg Could be also:
To cancel a washing programme in progress:
- Open the dishwasher's door.
- Press the programme selection/cancel button for about 3 seconds,
until the indicator light of the running programme turns off and the
END OF CYCLE indicator light flashes, indicating that the running
programme has been cancelled and that the machine has
returned to setting mode. It is now possible to select another
washing programme. If a new washing programme will be
selected, check that there is detergent in the detergent dispenser.
NOTE: only during the drying phase, if the dishwasher's door will be opened and remains open for more then 30 seconds, the running programme will be automatically cancelled and the machine will return to setting mode. This will happen, always only during the drying phase, also when the machine is switched off by pressing the
On/Off button and remains switched off for more then 30 seconds.
Dado
Jun 26, 2016 | Zanussi Dishwashers
Why does dishwasher rinse light keeps flashing and sounds like its draining. ?cant put another programme on
the flashing rinse light is a error code but i need a model number to know exactly what it means, constant draining with an error normally indicates an issue with water either its filling up to much and leaking into the base or it has a leak from somewhere in the dishwasher i.e. a hole in hose or a leaking seal, constant draining is a default response to a leak for all dishwashers often continuing draining even when the door is opened
Oct 08, 2014 | Dishwashers
Im getting an 8001050f error code for my ps3, can
Sony Network is experiencing sporadic outages in certain areas today.
It may be a scheduled system upgrade or maintenance - but be assured you are not the only one facing this issue.
No UP time has been announced by Sony - they are working to get the system up and running as soon as possible.
The problem is not on your end.
Keep trying to connect.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 01, 2010 | Video Game Consoles & Games
My Toshiba Laptop
click Start>>Run>> (type)Msconfig>>Click ok
System configuration utility window will open up
U will see few tabs at the top like General,Startup
Click on startup tab
At the bottom click disable all>>Close>>It will ask for restart
Restart the computer
when the computer restarts you will get the message
You have used the system configuration utility
Check the box at the bottom Do not Show this Message Again and click ok
Now you wont see the icons that use to load up on the right bottom of your system,however they have not been deleted just hidden,if you want to access any of those programmes that use to appear before
Click start>>All Programmes>>and clik the application you need to open.
May 25, 2008 | Toshiba Satellite A105 Notebook
Ergh
im a filipino programmer. you can hired me. have you try some application on it?
Mar 27, 2008 | Computers & Internet
Magix CD & DVD slideshow transition errors
Try to reinstall the problem or repair it. Maybe it works, but if not, it maybe not ba compatible to your Operating System or you got a fake serial number. If it is it, try to call your dealer so it can fix your problem.
Feb 25, 2008 | Computers & Internet
I found code error 88780078
Remove the sound card from the computer if it's a PCI card in a desktop, then restart the computer and reinstall the driver a fresh. . If unremovable from the motherboard, try reinstalling the driver afresh.
Also, please provide more specs on your type of computer
Feb 17, 2008 | Computers & Internet
Code for remote control
was the tv function working before or not as sometimes the controll will only work certain tv if it did work before is it a controll that can be programmed to work different appliances or not let me know and if you need the code for the remote i will try and get them for you post back and let me know the make and model of ctrl and make and model of the telly you want to programme the controll for ...............................
Nov 17, 2007 | Televison & Video
Code number for sky remote
Hi! I have the same TV and nearly gave up on this but by trial and error found 0206 works! Hope this works for you!
Sep 07, 2007 | Televison & Video
Pro 5000
depending on your IM programme, make sure the camera is allowed to be seen by others in the setup or options. You may also need to re install the software to see if that solves it. Assuming your camera is showing you your picture you know that the cam is working so it is something that needs to be set in the IM programme. If you cannot see yourself try making a short recording in windows movie maker 2 which comes with windows XP, as there are certain things the programme checks regarding you camera.
May 06, 2007 | Logitech QuickCam Pro 5000 Webcam
Gateway FPD2275W LCD Monitor Logo
56 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Thomas F. Schneider
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
