Question about Dell Computers & Internet
I have no volume!!!!
I have looked on the control panel, made sure master volume is as it should be, nothing is muted and I still have no sound! I have no idea what has been pressed or how to put it right, please help!
Many Thanks
A
    President:
  • 2,961 Answers
First thing to do to check that there is a sound chip assigned is click start>run, then type 'dxdiag', then press enter, go to the audio tab and check there are drivers and run the sound test.
Posted on Aug 17, 2008
No sound output device is installed
Check your Volume and make sure you do not have it on mute. If you installed the drivers then the volume must be muted. Right Click on the megaphone at the bottom right near the time and open the volume controls. Make sure there is nothing muted.
You can also get to the sound and audio volume controls by clicking Start/Control Panel and look for Audio or Sound.
May 02, 2012 | Computers & Internet
Optiplix 780 soun problem
What kind of sound problem? Tell us what is happening?
Do you have the speakers plugged in the right port (light green port)? Have you checked to make sure the speakers are turned on and the volume is up? Have you looked at your Audio/Sound Properties to make sure the volume is up and the sound is not muted? Have you checked the device manager to make sure none of your sound/audio devices have a problem?
If you have a megaphone at the bottom right near the time Doubloe Click on it and make sure nothing is muted and volume is turned up. You can also get to the Audio Sound properties in the Control Panel, click Start/Control Panel and look for Audio/Sound. You can get there by clicking Start/Programs/Accessories/Entertainment/Volume Control.
Apr 07, 2012 | Dell OptiPlex 780 MT Desktop Computer...
Hello, im using sony vaio VPCEB3J1E,speaker is not working but head is working,what is the problem?
For Vista/windows 7
Check with volume settings.
Right click on the speaker icon in taskbar and select volume control options.
Put a check mark on "All devices currently playing sound".
Make sure you have "The default communication device unchecked".
Place a check mark on both speakers and headphones.
For Windows XP
- Speakers, Headphones
In "Control Panel", select "Switch to Classic View", and open "Sounds and Audio Devices".
In "Sounds and Audio Devices Properties", click the "Audio" tab, and click the "Volume" of "Sound playback".
On the "Master Volume" screen, click "Properties" in the "Options" menu.
Add a check mark to "Playback" of "Adjust volume for" on the "Properties" screen, and check marks to "Master Volume" and "Wave" for the control to be displayed, and click the "OK" button.
On the "Master Volume" screen, remove the check marks from "Mute all" of "Master Volume" and "Mute" of "Wave".
Note: The settings may differ depending on the PC you are using. Please check items such as sound in the manual for the PC you are using.
May 22, 2011 | Computers & Internet
There is no volume. i have run the diagnostic and still nothing
check all the wiring, make sure it is correctly connected, then go to control panel then sound or volume and it will let you test the sound. Also make sure your headphones are not connected this will impede your sound. Turn on you volume control, take it off mute.
Mar 12, 2011 | Samsung Computers & Internet
HOOKED ALL MY SPEAKERS UP BUT SUB AND CANT GET ANY SOUND FROM FM OR TV THAT I HAVE HOOKED UP AM I MISSING SOMETHING ALSO THERE IS A LIGHT THAT SAYS SOUND MUTE BY FM
From the remote control ONLY:
Press MUTING to mute the sound through all
speakers and headphones connected.
"MUTING" appears on the display and the
volume turns off (the volume level indicator goes
off).
To restore the sound, press MUTING again so that "OFF" appears
on the display.
• Turning MASTER VOLUME on the front panel or pressing
VOLUME +/- on the remote control also restores the sound.
Dec 22, 2010 | JVC RX-778V
Sound is not working
There are some possible reasons why the sound is not working. It could be the volume control is in "MUTE", or the right sound card is not selected in the volume properties, or the speaker is defective.
Here's what you need to do:
1. Try to connect an external 2-channeled PC speaker. The computer should recognize the speaker and the sound should be transferred to the PC speaker. If the sound works on the PC external speaker, then you know that the volume control is NOT in mute and the sound card is selected. It means also that the built-in speakers could be defective.
2. If the same problem occur after connecting an external PC speaker, check the volume control, and make sure that the "MUTE" box is not checked. Then adjust the master volume.
* If everything's properly configured, but there's still no sound, check the volume properties under the Control Panel. Be sure that the correct sound card driver is selected. If that did not help, try to re-install the sound card driver.
* And the last option, contact the manufacturer and have them fix it for you.
Thank you and good luck!
Jun 26, 2010 | Acer Aspire 5535-5050 Notebook
No volume this monitor was given to me the volume is all the way up on desktop and I cant see where any speakers can be put.
Are you sure the monitor can handle speakers? Maybe it has it's own speakers, maybe it has no speakers at all. You can always plug the speakers into your CPU into the sound card, it is usually the green audio port.
That said, some things that you can trouble shoot.
  1. Make sure that the volume is all the way up on the desktop.
  2. Make sure that the volume control is all the way up in the control panel sound option
  3. Make sure that nothing has been muted, the control panel allows you to selectively mute a single device.
Apr 15, 2010 | Samsung 226BW Monitor
I have an ABS laptop. I have gone into control
First make sure nothing is muted.
Start>Control Panel > Sounds and Audio Devices
If nothing is muted, and your volumes are up and still no sound, try updating your audio drivers,
Start>Control Panel > System > Hardware > Device Manager > Sound Video and Game Controllers
Right click your audio drive and select Update driver.
Dec 06, 2009 | Ultimate Sound COMPUTER ABS | Ultimate V1...
Have external gateway speakers
First make sure your sound cards are working properly. 1) Check the master volume of your PC. Go to start menu, control panel, sounds speech and audio devices, sounds and audio devices - i) In volume tab click the speaker volume and check whether all the left, right, etc.. volumes are in medium or high. ii) In audio tab click the volume tab of sound playback and make sure that the master volume is not in mute and all the volumes are either in medium level or at 100%. After making these changes try playing any music. Even if the problem persists go and get your sound card checked in an authorised service centre.
Thanks & Regards,
Shiva
Sep 11, 2009 | HP (ZD929AA) Computer Speakers
Computer cd player problem
If you have already install the sound driver then make sure you have uncheck the "Mute" on Master Volume. To open it go to All Progrms> Accessories>Entertainment>Volume Control.
Here if Volume Master doesnt pop up then you will need to install Sound Driver.
Dec 02, 2008 | Computers & Internet
Computers & Internet Logo
Alun Cox
