Question about GPS
Garmin nuvi 750 won't power up no previos problems noted one min it worked now it won't can't get computer to see it either
  • 7 more comments
  • swtferguson Jan 10, 2009
    Garmin Nuvi was working fine. Left it in my vehicle and when I came back, the device wouldn't turn on. Connected via the cigarette lighter and still cannot get it to turn on.
  • Anonymous Jan 21, 2009
    My Garmin 750 nuvi won't turn on. It was working one minute, turned it off and then went back to my car an hour or so later and it wasn't working. I turn the switch on top to the left and it still doesn't turn on. My computer can't find it either! I don't get it!
  • gapthemind Jan 22, 2009
    same story: worked fine one minute, now won't turn on.
  • Anonymous Mar 08, 2009
    the one i have had only only problem; the voice didnt always speak when the navigation started. then i realized that as weeks passed the time it took to turn it on increased. it used to take no time at all. then 5 minutes. now it takes an average of 25 minutes at least until it turns on!
    My garmin nuvi 750 was working fine yesterday but, I left it in the car and, when I went put there this morning it wouldn't turn on. I tried reseting, I plugged it in to every car outlet I have but, it still isn't working. I even plugged it into my other car. What do I do?
  • alphajoker Mar 19, 2009
    nuvi 780 - second time in 2 months (new) and it will not power up. yesterday it said it was downloading new bluetooth software. i turned it off - and it hasn't come back on since. i tried 'resetting' it ten times, holding the switch to the left for 8 seconds, 10 seconds, 15, 20, 30...nothing works. is this thing a piece of 300$ junk or what?
  • Anonymous Mar 26, 2009
    thank u!!! i have same problem with my gps dont turn but slide the power key and hold for few seconds, is work now!
  • Anonymous Apr 27, 2009
    Same problem, and Andre22's solution worked instantly. Yes, it was a long 8 seconds (I gave directions to my spouse over the phone). Great job Andre22. Thanks.
  • Anonymous May 18, 2009
    Frozen after no warning what so ever - the 8 second reset worked for me! Thank you thank you thank you!
  • 4 Answers
Per the Owner's Manual, slide the Power key to the left and hold for eight seconds. THis will reset the nuvi and it should operate normally after that. Note, I had to do this with my nuvi - it took a "long" eight second but it worked!
Posted on Jan 24, 2009
  • Tim Marx
    Tim Marx Mar 21, 2014
    Right on...thanks. Worked for mine. I did it this way but with it plugged into power source. Thanks again.
I tried this 8 sec way, mine still not able to boot. It's only show garmin and disapear after few sec. Please help.
Posted on May 26, 2010
  • Tim Marx
    Plug it in and then do it.
It worked perfect! I tried a seconds but try 10 if that didnt work. Factory reset worked for me. Thanks Andre22!
Posted on Oct 13, 2009
  • 3 Answers
Mine did the same last night. i turned it off for a few hours and it wuldnt turn back on. i spent several hours trying several things including holding the power button. i read about them having switch issues and battery fade, so i thought i'd open it up but couldnt find a g.nuvi 750 guide and there are no visable screws on the back. finally, i noticed a small dimple on the bottom sticker. BINGO! i thought, i peeled the sticker back to find the screws are "torx" heads. FAIL! i thought. i noticed a small cut out under the sticker as well and pushed it with my screw driver. it felt like it contacted a button. BINGO! a reset button? nothing came on though. so i slid power to on and pushed the tab... SUCCESS, POWER ON, EVERYTHING WORKING NORMAL AGAIN!!!!!
Posted on Jul 25, 2012
I have a Garmin Nuvi 750. It went dead suddenly.
THERES A GOOD CHANCE THAT THE CABLE IS DAMAGED OR EVEN WORST THE CONNECTOR WITHIN THE UNIT IS DAMAGED OR BROKEN. TRY USING THE OTHER CABLE IE THE CAR TO UNIT CABLE OR THE USB TO UNIT CABLE IF EITHER ONE WORKS THE OTHER IS DEFECTIVE, IF NONE OF THEM WORK THERE GOES TROUBLE.
Mar 05, 2010 | Garmin (010-00583-00) for nuvi 750/760/770
Charger does not charge and battery is draining for Garmin Nuvi 750. What is the problem?
Check for power at the cord. Then check for power at the rectacle. If you have good power but it still doesn't charge, send to Garmin for repairs.
Dec 17, 2009 | Garmin nuvi 750 GPS Receiver
I need help downloading my music from comp.to Gps Garmin Nuvi 750
If you open the Nuvi folder in My computer, it could be a mounted drive.
supported file types are MP3, M3U, M3U8
Copy and paste to the folder.
then go to
Menu,tools,media player, source,browse.
In here you will have options too, fwd,rewind,skip, repeat,shuffle etc...
Hope this helps
Regards
Richard.
Apr 09, 2009 | Garmin (010-00583-00) for nuvi 750/760/770
Sound breaks up when direction are spoken
Connect your unit to your computer with the USB cable, go to Garmin.com and update your software from the "SUPPORT" tab. This should fix you sound problem unless it is caused by a broken speaker. Also see http://www.sharc.net/gps_audio_repair.htm for additional information.
Mar 17, 2009 | Garmin nuvi 750 GPS Receiver
No car radio / stereo for use with Garmin nuvi 750 GPS
Every Garmin Nuvi unit I've seen has a (loud) built-in speaker. The only demand our 250s and 265 make of the vehicle is a 12V power supply (and they'll even work without that for a while, until the battery goes flat).
A.
Dec 17, 2008 | Garmin nuvi 750 GPS Receiver
Garmin 750 - 90 days old
Had the same problem-try this- leave your nuvi off for about 4 hours. Push the power button to the right(lock position) and then to the left (power on position) and let go. I suspect temperature (getting overheated is the problem. This worked for me.
Aug 25, 2008 | Garmin (010-00583-00) for nuvi 750/760/770
Can't register my Garmin 750 online
Go to this url and I hope this helps. It worked for my Garmin 750.
http://www.garmin.com/garmin/cms/site/us/support/searchsupport?search_key=nuvi%20750
Aug 01, 2008 | Garmin nuvi 750 GPS Receiver
GPS Logo
3,628 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
