Compaq Visual Fortran Professional Edition 6.6 (QB-5UDAB-PA) for PC Logo
Posted on May 12, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Installed my Compaq Visual Fortran Professional Edition Version 6.5 on my laptop PC with Windows Vista - tried to create executables for my existing Fortran files (on Windows XP everything works perfect). Compilation - runs O.K. Linking fails: Linking... libc.lib(wincrt0.obj) : error LNK2001: unresolved external symbol _WinMain@16 Debug/mat_prj_test.exe : fatal error LNK1120: 1 unresolved externals Error executing link.exe. mat_prj_test.exe - 2 error(s), 3 warning(s) Any idea how to overcome the problem.
Larry Ng
Level 3:
Top Expert:
  • Compaq Master 14,561 Answers
  • Posted on Jun 28, 2017
Larry Ng
Compaq Master
Level 3:
Top Expert:
Answers
14561
Questions
0
Helped
3272303
Points
66455
Be like the first FORTAN, post ever in 25 years, wow, what a BLAST FROM THE PAST !
ID say you are missing some FORTARN LIBRARY"s
join a Fortran form? with old retired guys, there. form prime time circa 1970? or older?
this is a very old math based (formula) complied language.
It is a very limited and near useless Language. (used by bankers)
its totally obsolete now, finding all the pieces to make it work can be hard. for sure old long gone now, Libraries.
at link time those are RESOLVED.
yours fails there, it can find them.
id read the source and find those eternal links.
then see if the poor old sod put comments there.
like (this is advanced Trig functions in lib, xxxxx , sold by zzzzz0
it can be anything, the purpose of the program was not stated.
1 Related Answer
gewiz
Rob Hill
  • 1480 Answers
  • Posted on Jun 13, 2009
SOURCE: errors after building
ok DIALOGSET is referenced in your code but where is it declared , or defined, could be a class or structure etc.
I am trying to install fortran 6.5, but appears the message..."C:/windows/system32/*,* is ready only....but when I try to unread at this folder is not possible. I really would appreciate any help with...
If you are running windows vista or 7, try to launch installer as administrator. to do this right click on installation .exe file and select "Run as administrator".
I have installed compaq visual fortran 6.6 on my Laptop with the OS Win7 64bit Ultimate, but it doesnt work properly. The error message is: Microsoft (R) Developer Studio has stopped working.
I have successfully installed PGI visual fortran on my Laptop with the OS Win7 64bit Ultimate,and finally I have found how to build and execute programe on it.You can try PGI visual fortran. v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} p\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} v\:textbox {display:none;}
Visual fortran 6.0 won't work in windows xp sp2
whe runnig the setup right click on setup.exe >properties >select compatblitiy >select windows 2000 and install the fortan
or if you have allready installes
and righ click on FORTRAN shortcut set the compatibility mode same as above for windows 2000 good luck
please rate this solution...big help
7helpful
I have compaq visual fortran professional edition 6.6 for win32x86 systems (year 2001). I am trying to install it on my new windows 64 bit Dell desktop. It does not install. When I click the setup.exe, I...
Click Start
Click All Programs
Click Accessories
Click Program Compatibility Wizard
Tell Windows (64-bit) that you are trying to install a 32-bit application.
Or, upgrade to the latest version of Compaq's Fortran system.
1helpful
4answers
96% setup was unable to create the program folder
I had the same problem, to solve it I repeat the installation and when the message "Setup was unable to create the program folder" I went to installation directory "C:\Program Files\Microsoft Visual Studio" and I made a copy of the whole directory to another location in my hard drive. Then I back to installation screen and I accepted the message box. As it was expected original installation folder disappeared. I restored installation folder from the copy I had made previously. At last I created a short cut to "C:\Program Files\Microsoft Visual Studio\Common\MSDEV98\BIN\DFDEV.EXE" and started Visual Fortran from this shell without any problem. I hope this tip could be useful, regards. tbeltran
nd search for the
2answers
Compatibility issues between Compaq Fortran and Vista
hi,
i ill ask u to simply use a xp os, so that u wil not have such a problem occurring again. or partition you hard drive so as to install both xp and vista os.
6helpful
3answers
Reinstallation problem
Same error here. Compaq Visual Fortran 6.5/6.6.
I think is a problem related to Windows XP SP3.
- Solution:
Re-install Windows XP SP3 (integrated).
Right after installation (no reboot) run the CVF installer. It will work.
Then do normall installation stuff.
If you have Windows XP SP2 you won't have any problem.
Hope it helps.
Couldn't find ANY solution with SP3 installed before CVF installation.
13helpful
4answers
Problem with Compaq Fortran & Vista
I found the solution fortunately:
It's enough to do a right click on the bottom: "Developer Studio" instead of double click, and select: "Run as Administrator" , then select: "Allow" and so on..
Try it, it works!
Compiling and linking in vista
Vista's not my favorite yet, either.
There could be a million reasons why it won't run, many of which you won't be able to do anything about.
That said, perhaps turning off the UAC security, defining another user as an administrator, and trying to run Fortran might help. At least you won't be running into the whole "run as administrator" nightmare.
But, here's another thought...
If you're machine is powerful enough, maybe you could use Virtual PC or VMWare to build an XP machine where it will run.
(I cut my programming teeth on Fortran, a looong time ago!)
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
